i am thinking a 3 prong switch
1 prong ground
1 prong trigger
1 prong green ebrake wire
can someone confirm ?
thanks
1 prong ground
1 prong trigger
thanks
Alpine 9886
Digital Design 9515G
Digital Design W6.5 Mid Bass
Digital Design DD-A 5.25 Mid Range
Digital Design T2 Tweeters CDT 560I Crossovers
Crunch Ground Pounder 3000D-Pro
Rockford Fosgate T5002
Stinger Battery w/HO Alt
Stinger RCA
Stinger Wire
If you are using a switch with an LED, you will need to use a relay to give you a negative trigger. If you hook the brake wire to the switch directly, you have the possibility of popping electrical components in the stereo. LED rocker switches are designed to provide a posetive source.
If it is a two place toggle switch, if you hook the common to ground, then either position on the switch will give you the wiring you need.
Alpine 9886
Stinger RCA
Stinger Wire
Exactly. One wire goes to the green wire on the HU, then ground the other one.
I had a Lighted LED switch on my video system and hated it. It was a bright blue LED right in my face. It was mounted right underneath the stereo. I traded it out for a simple off on switch. Works like a charm, and no tricky wiring required.
If you plan to leave the brake override on all the time, after you start your movie, you will need to pulse the park brake off, then back on. So start your dvd, it won't let it play, turn your switch off then back on.
There is a way to make it so you don't have to wire a switch at all but that requires multiple relays, I can help you find a diagram on the internet if you are interested in doing it that way. Unless you are technically inclined, I wouldn't recommend playing with wiring as tricky as that though.
gonna take your advice
2 prong
and the switch can remain in the off position
in the event he watches a movie
than he can activate the switch
thank you
Alpine 9886
Stinger RCA
Stinger Wire
Why dont you just use a relay and have it click on automatically?
Hittin harder than chris brown.
Bookmarks
