Results 1 to 6 of 6
Reload Thread: Need a little help, please.
    Rideredder's Avatar
    Rideredder is offline Member
    Nov 2007
    Cornell, IL
    85
    Can anyone help me find a fit kit for a 2001 Jetta? I've been looking all night and haven't found one yet. I found a couple at Crutchfield.com but when I add them to the cart it says they won't fit. Also the universal one I found on eBay is the same one as on Crutchfield, so that won't work. I'll keep looking though.
    Ref: scissors (AKA Chad Lee from Ecoustics.com)
    Rideredder's Avatar
    Nov 2007
    Cornell, IL
    85
    Re: Need a little help, please.
    Or does it even need a fit kit?
    MetalHead888's Avatar
    MetalHead888 is offline MetalHead
    Jan 2006
    NJ
    171
    Quote Originally Posted by Rideredder View Post
    it should definatlly have a kit. type in 2001 volkswagon jetta dash kit on ebay and crutchfield.com im sure youll find it,
    nuugen's Avatar
    nuugen is offline Member
    Jan 2006
    Cleveland
    74
    You have a double-din OEM right? The only "kit" for a Jetta is a din-sized pocket, you would install it into the bottom of the radio cavity and install the radio into the leftover din-sized hole above it(or vice-versa)..Metra makes a pocket, part #88-00-9008
    If you have a single-din OEM the you don't need any kit at all, just a harness and antenna adaptor..
    Go here for kit/harness info:
    http://www.metraonline.com/fit.aspx
    People who are driving faster than you are maniacs, and people driving slower are morons...
    http://www.caraudio.com/forum/image.php?type=sigpic&userid=25289&dateline=124426  2226
    Rideredder's Avatar
    Nov 2007
    Cornell, IL
    85
    Quote Originally Posted by nuugen View Post
    I'm not really sure. It's my friends car and I haven't looked at it yet. I saw the pocket kits, but I don't know if he needs it. The only other mounts I seen was what looked like just a trim ring that goes around the HU for a single DIN, but Crutchfield says that it won't fit.
    nuugen's Avatar
    Jan 2006
    Cleveland
    74
    If it is a single-din OEM, just lock the cage in and slide the HU in..If it is double din, then grab one of those pockets and you are good to go..Easy Peasy
