Results 1 to 11 of 11
Reload Thread: 9887 tuning ?
    crfrider's Avatar
    crfrider is offline Senior VIP Member
    Apr 2009
    Oklahoma
    451
    9887 tuning ?
    a yes im looking at the alpine cda-9887, im going to be running a passive crossover setup to my componet speakers, runing my head unit to a kicker 4 channel amp, then to the crossovers to each set of componets, then to the speakers, now my question is, is how would i go about tuning my system, will i be able to use the headunit to control the eqs of the stereo, or will i have to use the amp to set the eqs? ill also have a mono sub amp to my subs, thanks
    alxmlr789's Avatar
    alxmlr789 is offline 6>5
    Dec 2006
    FL
    23
    4,876
    Re: 9887 tuning ?
    Personally, i wouldnt buy the 9887 if you aren't gonna be running active. You can save some $ and go with a 9886 and still have a decent equalizer.
    Bought: Tweet02 (x2), bjfish11, pboulos(x3), baseballer1100, ibanender, Duece212, gitusum, jmanjr, Dalucifer, KPR10is, Megalomaniac, oxsign, jmanpc, hoss, 2002xlt, mobeious
    Sold: Mike dressure, Dejawiz, Lax916, Calikid, 88irocZ, lammy, Oxsign, Jblanford, JohnnyBASS, Rocky 59, Megalomaniac, tRdoc, 350_regal, oxsign, sundownz, dont smoke crack, Good*bad*Ugly*, ryanroma, 96TL, VQ35max, Deuce212, darkist240sx, Jhughes, SPY, Gongos, 04silverz, SirJoseph8989, Theothermike (x2), sgdenny, mgbcs, uncfanforlife07, NMBR1SPT, Nukeitall (x2), glasjaw, NeedDirections
    Traded: Rtilaree, mike dressure, megalomaniac, wheeler
    Feedback thread = http://www.caraudio.com/forum/showthread.php?t=224101
    crfrider's Avatar
    Apr 2009
    Oklahoma
    451
    Re: 9887 tuning ?
    so the 9886 would be a better choice, is there much difference in the two? so the eq on the head unit would be pointless since im running passive
    nineball's Avatar
    nineball is offline too many toys...
    Feb 2008
    home
    1,924
    Re: 9887 tuning ?
    no, the eq and crossover settings still control your sound. you can use the ones on the hu or the ones on the amp. i would use which ever one was a better quality product.
    Quote Originally Posted by eharri3 View Post
    I have 4 12s getting 2K watts rms and my front stage is 4 Walmart JVC coaxials running off 16 watts rms of head unit power. My sub sounds fine but my mids and highs don't sound very clear and start to distort long before my subs do. Anybody know why? Any suggestions?
    alxmlr789's Avatar
    Dec 2006
    FL
    23
    4,876
    Re: 9887 tuning ?
    Not so much the equalizer, but the fact that it has a 3 way crossover built into it, You are paying an extra what, 100 or so bucks for those crossovers.
    The equalizer is still pretty good on the 9886. I personally own a 9887 and love it, but then again, I spent the money on it to run active
    The only reason I would buy a 9887 in your position is if you wanted to go active in the future. I recommend it
    crfrider's Avatar
    Apr 2009
    Oklahoma
    451
    Re: 9887 tuning ?
    is active a better way to run you stereo, i heard it is harder cause you have to tune alot more, is passive still good sounding?
    alxmlr789's Avatar
    Dec 2006
    FL
    23
    4,876
    Re: 9887 tuning ?
    There is just more fine tuning when you are active. It isn't necessarily harder if you know what to tune.
    jdc753's Avatar
    jdc753 is offline Truck Brigade
    Nov 2006
    Mass
    28
    1,891
    Re: 9887 tuning ?
    x2 on everything alxmlr said. Get a 9886 if your gonna run passive, unless you plan on going active in the future. I believe the only difference between the two units is the 9887 has the built in crossovers and time correction. Even the time correction would be useless unless you were going to at least bi-amp your passive crossovers.
    Personally I would go for the 9886 for your case and use the HU's EQ to fine tune things.
    2005 F350 crew cab diesel 4x4
    -Work in Progress-
    HU: Alpine 9887 linked to 10.4" TS TruckPC
    Front Stage: Polk SR6500 Active
    Front Amp: Sundown Sax100.4
    Sub: Stereo Integrity Magnum V4 in the center console
    Sub amp: Sundown Saz-1500D
    Refs: low_end, Relax, SSon22s, Johnson, tyroneshoes, twisztdpunisher, flakko, djhn9, KINGDELL91, amoffitt, Justin89T, 01 S 10, Mazzasec
  9. #9
    nineball's Avatar
    Feb 2008
    home
    1,924
    Re: 9887 tuning ?
    Quote Originally Posted by alxmlr789 View Post
    what eq does the 9886 have? according to the alpine website, without the pxa-h100 you only get:
    Sound Tuning
    * Subwoofer Level Adjustment: -15dB to 0dB (1dB steps)
    * Bass Center Frequency: 60/80/100/200Hz (Selectable)
    * Bass Band Width Adjustment (Q): 4 choices (1 =narrow, 4 =wide)
    * Bass Level Control Range: A?14dB at 100Hz
    * Treble Center Frequency: 10k/12.5k/15k/17.5kHz (Selectable)
    * Treble Level Control Range: A?14dB at 10kHz
  10. #10
    ejschultz's Avatar
    ejschultz is offline CarAudio.com Veteran
    Nov 2008
    Schererville, IN
    2,921
    19 Post(s)
    Re: 9887 tuning ?
    the 9887 is basically a 9886 with the pxa-h100 built in. some other features as well like a 24 bit DAC. there are also some cosmetic differences. 349.99 for 9886, 149.99 for pxa-h100 or 449.99 for 9887. seems like if you want the tuning features like a 5 band parametric eq or 7 band graphic eq, time alignment, or the ability to run active later on, the 9887 is worth the extra hundred. otherwise, down the road, you've got to spend an extra 150. i'd get the 9887 if i wanted an alpine.
    all prices are from crutchfield. i didn't feel like shopping around at unauthorized dealers to find other prices for compairison reasons. i support authorized dealers because i used to work for one.
    94 Caprice Classic LS: DEH-P800PRS, TS-C720PRS, MRV-F545, MRD-M1005, 2 REF-TM12.4 in 2.5 net cubes sealed; 97 Grand Cherokee TSi: CDA-9855, TS-D1720C, MRV-F345, MRD-M605, SWX-1043D in .54 net cubes sealed
    Resident Jeep Expert, Mother Fucker
  11. #11
    eharri3's Avatar
    eharri3 is offline CarAudio.com Elite
    May 2008
    philly
    756
    Re: 9887 tuning ?
    Quote Originally Posted by nineball View Post
    Sound Tuning
    Umm yeah it's a 2 band with loudness. I am trying to figure out what in peoples' eyes makes that 'good' in comparison to any other SQ unit. I had one. Aside from 4 volts/channel and imprint capability there really wasn't much there feature-wise that I couldn't have gotten for 120 bucks at WALMART. Active or no the 9887 has a 5/7 band EQ and time alignment. When properly adjusted just these two things can have a tremendous effect on your sound. And if you learn about going active later and decide you want to try it you'll already have a head unit.
    Re: whats some good components?
    Quote:
    Originally Posted by deathpenalty18
    Not an sq set up just want good sq speakers and tweets not interested in mids! And my sub is a fcking ia dp 18 with a memphis 4kw
    Originally Posted by x1le
    mids ARE speakers.
    A component set = pair of midwoofer's and a pair of tweeter's
    and nobody cares what your sub is.
