Results 1 to 2 of 2
Reload Thread: 880 Prs grounding
    klepto's Avatar
    klepto is offline Perveyor of Filth
    Feb 2003
    San Jose, CA
    942
    880 Prs grounding
    I have had an 880prs sitting in my room for the last year and now I want to install it in my new ride. I know they have had problems in the past with these units getting an alternator whine when not grounded properly, so I read that lots of people make separate grounds for these units to ground to the car chassis. I fashioned one of these, but had one question as to where to ground it. Is it ok to put both the origional PRS ground and the gound that I made in the same place in the chassis of the car or should they be separate? Thanks. Here is a pic to illustrate the new ground that I made.
    Also, is it necessary that I run the yellow battery cable all of the way to my battery or can it simply be connected to the wiring harness that I purchased.
    05 Subaru WRX Wagon
    Pioneer DEH-P880PRS
    SI Mag 12''
    2.25 cubes @ 32Hz
    Massive Audio P1000.1
    Crystal SSCS6
    Massive Audio 400.4
    KnuKonceptz 0 guage
    RAAMmat
    Justin89T's Avatar
    Justin89T is offline I Drive A Supra
    Aug 2004
    The Third Island of China
    33
    751
    Re: 880 Prs grounding
    Connect the yellow to your harness.
    Connect the ground in the harness to the car side harness.
    Connect your additional ground elsewhere.
