Results 1 to 3 of 3
Reload Thread: alpine 9887 turning off internal amp and sub control?
    specie's Avatar
    specie is offline Member
    Aug 2004
    Clearwater,FL
    71
    I was looking at the manual but I didn't see the instructions for turning off the Internal amp.
    Also, I'm running a jl sub with an older ppi a600 amp (no eq), there is some vocal coming from the sub. Is it possible to setup the Alpine eq to keep the sub from producing that freq? I only had a few minutes to mess with the hu, but couldn't get it the way I want it. Any tips on tuning with this hu?
    Thanks.
    jacka's Avatar
    jacka is offline CarAudio.com Elite
    May 2006
    CA
    1,244
    Re: alpine 9887 turning off internal amp and sub control?
    to turn off the amp you gotta hold down the func./setup button and go to general and to Power IC. turn that off you will turn the internal amplifier off.
    References:
    Sold to: nauticagmo, 808bmw, hustler904, protocol_droid, latina33, dub22, morgans432, BassmentJack, Sr SQ (diymobileaudio), macxx (diymobileaudio)
    Bought from: sundownz, bjfish11, 6spdcoupe, 02TurboA4, ngsm13
    BEAVER.989's Avatar
    BEAVER.989 is offline CarAudio.com Elite
    Apr 2006
    Michigan
    779
    x2 on power ic. As for the vocals in the sub... Set the x-over lower.
    Alpine CDA-9887 - PG Xenon 100.4 - PG Xenon 600.1 - IDQ10V3(1.3cft. @ 28hz) - Polk SR6501 mids - Seas Neo's - Knuconceptz - RAAMAudio
    Common sense is far from common.
