Results 1 to 4 of 4
Reload Thread: replacing the screen on a eclipse in dash dvd player?
    hdj20's Avatar
    hdj20 is offline F*CK SONY
    Apr 2008
    wisconsin
    780
    is this possible?
    REFS : Jamaica2G | lysfys | blaze383 | garrettpf | GearGuy2001 |
    Torgus's Avatar
    Torgus is offline Maxima.org
    Oct 2006
    Boston
    387
    Re: replacing the screen on a eclipse in dash dvd player?
    yes.
    2003 Maxima: Bodykit, 19'' Rims, Alarm, Eclipse AVN5500 DVD/NAV, Rainbow Profi Vandiums(front), Boston pro60s(rear doors), 2 12'' Sealed Type Rs, 0 guage, HiFonics & Diamond Amps, Optima, Suspension Work, Cleared 8k HIDs w/ DDE Angel Eyes, 8k HID fogs, Berk Intake, Phenolic Intake Spacers, Greddy SS Exhaust, Custom 2 Tone Leather Interior, Radar Detector, bunch of other stuff...oh and only 40k miles
    MAXIMA.ORG
    Pickler's Avatar
    Pickler is offline CarAudio.com Veteran
    Jul 2006
    Flagstaff/Las Vegas
    2,032
    2 Post(s)
    Quote Originally Posted by Torgus View Post
    yes.
    /thread
    DDc 6.5" comps
    4 Sundown e8s
    refs-
    http://www.caraudio.com/forum/showthread.php?p=4720749
    jdowney's Avatar
    jdowney is offline Member
    Sep 2003
    Bay Area, California
    60
    2 Post(s)
    here is a post i used to do this on a AVN 5500
    http://www.canadiancaraudio.com/onli...tml#post341496
    here is the text in case it gets deleted:
    The image displayed on the opening screen (which is displayed when the power is turned on) can be changed to a Jpeg image stored on a CD-R/RW.
    Step 1> "When storing the image data in a CD-R/RW disc make a text file named "CSM.txt" (any content /text is OK) and store it together with the image data.
    To create this necessary file, open Microsoft Notepad In Accessories. The text data within the file does not matter. Simply save the file as "CSM.txt" and Include the file on the same disc with the image or images you wish to use for the Opening Screen.
    Tip: If you need to modify the image to fit the AVN screen, you can use Microsoft Paint in Accessories or any other image adjustment software.
    Format for the disc and image data:
    - File size: smaller than 100KB
    - File name: ISO9660 standard (keep file name less than 18 characters)
    - File extension: .jpg
    - Max image size: 416(W) x 240(H) pixels
    Step 2> Burn the image or images you want to the CD-R/RW along with the CSM.txt file. Keep the files on the root of the CD – do not store them in folders.
    Changing the Welcome screen
    Eject your DVD disc from the AVN unit and insert your newly created CD-R/RW disc. It will only take a few seconds to read the image data. DO NOT turn off the ignition key or power down your AVN unit during this time.
    A screen will come up saying “Opening Image Change” – touch that button. The names of the images you burned to the disc should now be visible in a list. Simply touch the name of the image you want to use as your Welcome screen. The screen will change to confirm your selection. Confirm your change by pressing “OK”.
    Be sure to remove your image disc before turning your AVN unit off.
    hope that helps, been searching like crazy to find other codes or advice like this to change any other options.
