Results 1 to 6 of 6
Reload Thread: Kenwood kdc-x789 face place
    maritoze's Avatar
    maritoze is offline Jedi Master
    Jan 2007
    CA
    331
    I recently purchased thise head unit off the forum.And it was working perfectly fine. Yesterday along the whole screen there was wertical lines when it was on and made the display completely unreadable. I took the face plate off and waited a few minutes and it went away. then today it started to do the same thing. Does anyone have a clue of whats wrong. Do I need a new facelate thing? Any help would be appreciated
    sorry ment to write "FACEPLATE" And couldnt edit the title.
    edzy's Avatar
    edzy is offline SPL Ninja
    Feb 2007
    Where you live
    2,188
    Re: Kenwood kdc-x789 face place
    Maybe a bad connection to the faceplate. Or the faceplate may be on its way out. Is it very cold? that can cause issues sometimes with the display.
    Nothing to see here, Move along.
    maritoze's Avatar
    Jan 2007
    CA
    331
    Its actually very warm right now...When you say bad connection , do you mean between the faceplate and the unit itself or somewhere in the harness?
    edzy's Avatar
    Feb 2007
    Where you live
    2,188
    like on the face plate. There should be like 5-8 brass connectors. Use a pencil erasure to clean them. They should be shiny. The ones in the HU are hard to clean, cause they are like pin slots, so I wouldnt try.
    maritoze's Avatar
    Jan 2007
    CA
    331
    IT works!!! Thanks man
    edzy's Avatar
    Feb 2007
    Where you live
    2,188
    No Problem. Glad it was an easy fix for you.
