Results 1 to 6 of 6
Reload Thread: Pioneer AVHP5900DVD
    bwillis1's Avatar
    bwillis1 is offline Junior Member
    Feb 2008
    Seattle, Wa
    14
    Pioneer AVHP5900DVD
    Can You bypass a Pioneer AVHP5900DVD or a Pioneer
    Pioneer AVHP7800DVD ?
    I have not bought either but I can get a pretty good price on both. Any suggestions?
    Thanks for your suggestions
    Willis
    Haden's Avatar
    Haden is offline Dr Gibbles
    Sep 2007
    Here
    595
    Re: Pioneer AVHP5900DVD
    yeah on older ones you can just ground the wire that youre supposed to hook up to the parking brake. On newer ones you have to put a switch on the wire before you ground it because it can detect if its always grounded and wont work
    Truck- Dodge Ram
    HU- Kenwood KVT-717DVD
    Amp- MTX 1501D
    Subs- Dual MTX 8000s
    Refs- JT1979, nbudros
    MTX TE1501D FOR SALE PM ME
    cheese
    Haden's Avatar
    Sep 2007
    Here
    595
    and you just have to flip the switch every time you drive
    Truck- Dodge Ram
    Amp- MTX 1501D
    cheese
    bwillis1's Avatar
    Feb 2008
    Seattle, Wa
    14
    Let me ask this also. I know there is something about the newer model vehicles needing a special wire harness. The wire harness goes through the ecm or something. So here is my questions.
    If I want to first just replace my deck and use the factory amps and speakers which harness do I buy?
    And will that same harness work in the future when I want to add my amps, new speakers, and sub and go away from all the factory equipment?
    Also anyone have any experience with the shallow pioneer subs that go under the front seat?
    I dont know if you need the info but I drive a 07 Dodge Ram 2500 Quad cab.
    Thanks again for the help
    richierich75's Avatar
    richierich75 is offline CarAudio.com Elite
    Feb 2008
    BMORE
    683
    originally posted by someone else, but this is the link I used for finding what I needed for the AVH-P6600 http://metraonline.com/vehicleguide.aspx
    you should be able to pick your specific harness up from a local shop $$ 100.00 +/- I got mine from Best Buy.
    You'll need the harness, dash kit and possibly the antenna adapter.
    The harness will work as long as your h/u has the additional outputs. In the future if you plan on bypassing the stock amp/speakers you would disconnect the outputs to the harness and connect the new to your new amps and run new speaker wires etc...
    Feb 2008
    BMORE
    683
    I also bought a seperate "switch" off of ebay, but I don't need it for my h/u. I paid $25 bucks for it and it should work on yours if you are interested.
