Results 1 to 11 of 11
Reload Thread: Info on the CDA-9887
    R05Nismo's Avatar
    R05Nismo is offline Senior VIP Member
    Dec 2007
    PA
    455
    I was going to get the Alpine 9886 but for 100 bucks more I've been looking into the 9887. It says the crossover is adjustable from 20-200 Hz for high/low pass. How close can you select each point? 50,55,60, etc? Also is the crossover in the head unit better than a built in crossover on an amp? (Zapco Reference with 12db slope) I read about people using this h/u for an active setup, I know thats for high/low pass but not for tweeter crossover as they need crossed around 4K?
    mikey7182's Avatar
    mikey7182 is offline CarAudio.com Elite
    Oct 2007
    Mesa, AZ
    814
    Re: Info on the CDA-9887
    It can be used actively... Low/Band(mid)/High passes are all available when set to 3 way mode. I don't know the octave increments, but down low, I think it goes 50/63/80/100/125/160, etc. Been awhile since i have checked mine. Also as far as I know the slope is either 0, 6, 12, 18, or 24dB/octave. It is definitely worth the extra $100.
    Quote Originally Posted by alex6999 View Post
    ...and speaker should take all power that i give to him...
    maybe you know models of speaker special for jackasses? 500 rms and 100 db sens?
    PayPal- email is mikey7182@yahoo.com ... 20 Verified Positive Transactions
    ebay id is mikeg7182 - 100% positive feedback (29)
    R05Nismo's Avatar
    Dec 2007
    PA
    455
    Anyone know for sure what the crossover adjustments are for sure? Could I fine tune the crossover better with an amp? I might run a set of Hertz HSK's active using this H/U.
    Ohh, the guy from Crutchfield told me that you cant adjust the actual crossover point. Just the slope from 20-200Hz That ended the convo...
    99StangGt's Avatar
    99StangGt is offline CarAudio.com Elite
    Mar 2005
    Oregon
    48
    1,303
    I dont know what the exact freqs are but yes you can run active with the tweeters around 4k. I use the old 9835 and it has a lot of freqs to choose from for the tweeters. 2k, 2.5k, 3k, on so on. There should be someone on here that can check theres on 3-way set up to give you the exact numbers. Yes you can adjust the crossover points and the slope. Here is a link to the manual, doesnt give you all the freqs for the crossover but does show how it works.
    http://support.alpine-usa.com/produc...M_CDA-9887.PDF
    nismos14's Avatar
    nismos14 is online now CarAudio.com Veteran
    Dec 2006
    Jersey
    32
    14,167
    3 Post(s)
    Quote Originally Posted by R05Nismo View Post
    Crutchfield sales advisors aren't the brightest bunch anymore....
    Car audio IS an addiction.
    C.A.A.A Member #1
    (Car Audio Addicts Anonymous)
    Refs http://www.caraudio.com/forums/buyer-seller-feedback/278560-nismos14-feedback-refs-thread.html
    R05Nismo's Avatar
    Dec 2007
    PA
    455
    Is it worth getting the 9887 over the 9886 if i'm not going to run my fronts active?
    Also with the time correction would it still work if the tweeters and mids are on the same amp? And would it make it sound worse for the passenger?
    References: Gixxer9, Mikey7182, Crea78, GTSLVR4, Vitveet, Nycking23
    Alpine 9887 -SOLD
    Phoenix Gold Ti500.4 -SOLD
    Boston Pro60's Active SOLD
    Phoenix Gold Ti600.2 -SOLD
    Fi Audio SSD10- SOLD
    KnuKonceptz wire- STILL FOR SALE
    Optima YT
    - SOLD
    crea78's Avatar
    crea78 is offline Senior VIP Member
    Apr 2005
    Charlotte, NC
    155
    Nismo, I think it's worth the extra $100 if you value a SQ HU with 24-bit Burr Brown D/A converter. Also, if you are planning on using the Imprint system, then the CDA-9887 is the only HU available from Alpine that is capable of this. If you're looking for slightly used, I got mine with an iPod cable for $340 shipped which is $65+ below MSRP.
    Upcoming System: Alpine CDA-9887 w/ Imprint + 80GB iPod | Rainbow Germaniums (bi-amped) | Zapco 200.2 (tweeters) | Zapco 360.4 (mids) | (2) IDQ10v3 | Zapco 500.1 (subwoofer) | Second Skin deadening
    References: CA.com: 3.5Max6Spd | lyttleviet | R05Nismo ; DIYMA: Puffhead | simplicityinsound | sonic_purity | BooneinCO | blacklabel | F150 Truckin'
    nismos14's Avatar
    Dec 2006
    Jersey
    32
    14,167
    3 Post(s)
    9886 can use imprint as well. Just the new imprint is not out yet.
    C.A.A.A Member #1
  9. #9
    bass_lover1's Avatar
    bass_lover1 is offline Metal Head \m/ \m/
    Jun 2004
    NPR, FL
    26
    1,574
    As far as I know, the 9886 is pretty much useless unless you have the Imprint. The 9886 unit alone cannot adjust the EQ or the crossovers, it requires Imprint. The 9887 on the other hand can use the features by it self, the Imprint is used for Auto TA and EQ.
    - Alpine CDA-9887 - AudioControl DQS - Linear Power 652I - B&G Neo3 - Clarion DPX 2251 - Vifa XT18 - Clarion DPX 1851 - Alpine SWX-1243D -
  10. #10
    nismos14's Avatar
    Dec 2006
    Jersey
    32
    14,167
    3 Post(s)
    It has simple bass and treble controls. It also has 24bit dacs so its worth it for those things if you are a more simple user who still wants great sound.
    C.A.A.A Member #1
  11. #11
    Jun 2004
    NPR, FL
    26
    1,574
    Quote Originally Posted by nismos14 View Post
    Good call. I should have worded my statement, that it's worthless for an active setup by it self, it will require the Imprint to access those features.
