Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Reload Thread: 9887 time correction confusion...
    groggy23's Avatar
    groggy23 is offline Senior VIP Member
    Jan 2007
    north VA
    258
    So I was reading the manual for the CDA-9887 specifically about time correction. I understand the concept but having trouble figuring out what exactly to calculate. I understand that you can adjust each individual channel. I have a current 3-way setup, front stage, no rears. Following Example 1 in the manual for front left seat. You take the distance between the listener and the closest/farthest speaker. Take farthest - closest = difference and calculate that into the time correction formula. Take that value and input that as the front left channel. Here is where my questions come in. Do I need to input a time correction value for each channel including subwoofer? If so, how do I do the calculate for each channel? For example for the front right that is my farthest already, so I would come up with a negative value to input for the time correction calculation? *scratches head*
    2004 Nissan Altima - Kenwood x-889 - DLS UR36i - eD 11Ov.2 - Arc Audio 4050xxk - iPod video
    Refs: hc3_cuz, dumple, LS-Coupe, bikinpunk, Bloodstalker999(x2), mschief02 on ebay
    bikinpunk's Avatar
    bikinpunk is offline G-g-g-g-g-unity!
    May 2006
    Alabama
    3,224
    2 Post(s)
    Re: 9887 time correction confusion...
    #1. measure distance of all speakers.
    #2. Pick the furthest speaker. This will be your reference point.
    #3. Take the difference of each speaker from the furthest speaker.
    The furthest speaker (usually subwoofer) will be 0.00ms on the t/a, so basically you do no time correction for the furthest speaker. The closest speaker to you should have the most t/a since that's the largest difference.
    This is based on temperature since speed of sound is based on temperature, fyi. But, just assume some temperature for the sake of measurements.
    For example, the subwoofer is 66 inches and is the furthest speaker. The following is from an excel sheet I made. 2nd number is distance in inches, and 3rd number is time correction in milliseconds (ms).
    Subwoofer: 66 0
    Drivers Tweeter: 35 2.295628013
    Passengers Tweeter: 49 1.258892782
    Drivers Midrange: 37.5 2.110496722
    Passengers Midrange: 51 1.110787748
    Drivers Midbass: 41.25 1.832799785
    Passenger's Midbass: 55 0.814577682
    So, you see that the driver's side tweeter (which is the closest speaker to you) has the most t/a @ 2.29ms. The subwoofer has 0 t/a.
    One thing to keep in mind is reflection. If you have a speaker firing at the windshield you'll want to add some extra distance to account for that the best you can. Also, the excel sheet I use is just to give you an idea of where to start. You should play with the t/a a bit and listen to what you think sounds the best.
    Also, I actually added about 8ms to every t/a value I calculated so that the sub has plenty of time to get "up front" and doesn't sound like it's coming from behind as much.
    If you want a copy of the excel file I'll be happy to e-mail you one.
    2006 Civic LX Sedan
    Pioneer P9. Audison BitOne. JL Audio HD. Scanspeak. Acoustic Elegance.
    DIYma Refs:
    http://www.diymobileaudio.com/forum/itrader.php?u=1891
    Caraudio.com refs:
    Groggy23, Radridd, bdubs767, 6spdcoupe, Cahm Rohn, Soydeedo, Lil_KB
    E-bay Feedback: bikinpunk
    groggy23's Avatar
    Jan 2007
    north VA
    258
    Thanks a bunch bikinipunk, that really cleared things up. So on step #3 wouldn't the farthest speaker always be the subwoofer?
    bikinpunk's Avatar
    May 2006
    Alabama
    3,224
    2 Post(s)
    Quote Originally Posted by groggy23 View Post
    More than likely, but not necessarily.
    I suppose you could say that if you have the sub under you or in your center console as I've seen, then it's closer than anything on the passenger's side.
    2006 Civic LX Sedan
    DIYma Refs:
    Caraudio.com refs:
    whitemax's Avatar
    whitemax is offline CarAudio.com Elite
    Dec 2006
    San Diego
    762
    71 Post(s)
    Each click of the dial (increment) is the same as a 1ms....
    2010 Nissan Maxima SV Premium with OEM DVD/Navigation HU
    AudioControl: LC2i
    Precision Power: DEQ.8
    Scan-Speak: Illuminator R3004/6020-00
    Scan-Speak: Discovery 10F/4424G-00
    Scan-Speak: Revelator 18W/4531G-00
    Audiomobile: MASS 2012 S24
    Rockford Fosgate: Power T800-4ad, Power T400-4, Power T1000-1bdCP
    groggy23's Avatar
    Jan 2007
    north VA
    258
    Thanks guys, got things cleared up
    grampi's Avatar
    grampi is offline CarAudio.com Elite
    Aug 2002
    Cheyenne
    724
    1 Post(s)
    I found the easiest way to do it is to use the difference between the two front speakers and dial that time correction into your front left side, then just dial in the time correction for the sub while you're listening to it until it sounds like it's coming from the front.
    groggy23's Avatar
    Jan 2007
    north VA
    258
    Thanks for the tip grampi.
  9. #9
    groggy23's Avatar
    Jan 2007
    north VA
    258
    nevermind.
  10. #10
    groggy23's Avatar
    Jan 2007
    north VA
    258
    Ok, getting a little confused now. On the 9887 unit, I see you can input #'s in distance cm or inches for each channel. So I'll just take the distance for each speaker to my head and input that?
  11. #11
    bikinpunk's Avatar
    May 2006
    Alabama
    3,224
    2 Post(s)
    Yea. I was looking over the 9887 one day after I posted my response. A friend wanted it and I was doing the research for him and I noticed that they don't do t/a in ms like the other h/u's do, and rather you just input the distance. That makes things much simpler.
    2006 Civic LX Sedan
    DIYma Refs:
    Caraudio.com refs:
  12. #12
    groggy23's Avatar
    Jan 2007
    north VA
    258
    Alright, that's what I figured. But here's the kicker. I think it wants you to input "L" which is the following equation, not the actual distance from listener to each speaker.
    L = (distance of farthest speaker) - (distance of speaker you want to adjust)
    Then you input L into the channels you want to adjust.
    From how I understand is you adjust only the ones close to you and by playing around that's what sounded right to me. So I ended up adjusting my drivers tweet/mid/midbass, and leaving the rest at 0.
    Because I tried inputing the numbers just by the distances alone and everything sounded way out of alignment. I got around 20cm for my tweet/mid and
  13. #13
    bikinpunk's Avatar
    May 2006
    Alabama
    3,224
    2 Post(s)
    You will adjust EVERYTHING except the furthermost speaker.
    Like I explained above, you will have a delta x (difference of distance) for every point based on the furthest driver as the reference driver.
    2006 Civic LX Sedan
    DIYma Refs:
    Caraudio.com refs:
  14. #14
    groggy23's Avatar
    Jan 2007
    north VA
    258
    Ah I see, so I assume the only one I won't adjust is the subwoofer. Also, The distance I input for each driver is the distance from me to that speaker?
  15. #15
    bikinpunk's Avatar
    May 2006
    Alabama
    3,224
    2 Post(s)
    Unless the manual states otherwise, I would assume this is true.
    2006 Civic LX Sedan
    DIYma Refs:
    Caraudio.com refs:
