Results 1 to 12 of 12
Reload Thread: 2006 chevy cobalt
    budahbuddy803's Avatar
    budahbuddy803 is offline CarAudio.com Veteran
    Feb 2006
    Clemson, SC
    4,708
    14
    2006 chevy cobalt
    well installed everything for an amp and two subs. I love the stock trunk location for the battery. Running all the wires was easy, but after connecting the wiring harness the HU wouldnt power up so my step brother took it to the local audio shop and they said you either had to buy a $120 piece or you can place a fuse on the power wire,
    He doesnt have a job or anything so he doesnt have the $120 to spend. He wants me to put a fuse on the power wire and he thinks that will make it work. I dont understand how putting a fuse on the wire will work.... Will it? I think ill try it for him inless some one says it wont work.
    blue93corsica's Avatar
    blue93corsica is offline Senior VIP Member
    Jan 2006
    ontario
    321
    Re: 2006 chevy cobalt
    the colbalt doesn't have an acc pwr source at the factory radio harness location, a switched 12v source much be located, i usualy tap a relay from the ign. harness and use that.
    For all your fiberglassing needs, come check out Fiberglassforums.com
    Feb 2006
    Clemson, SC
    4,708
    14
    so run from ign. to switch and then 12volt wire to the switch?
    hemi=22s's Avatar
    hemi=22s is offline I Pop Bottles
    Jul 2007
    west palm beach, fl
    3,130
    use a test light find a wire that only has power when acc is on tap in and run a wire to the ac wire on the radio put a inline fuse holder in there just for safety (autoparts store for 4 or 5 bucks if ur radio doesnt have one)
    FEEDBACK IN LINKS BELOW TOO BIG FOR SIG
    http://www.caraudio.com/forum/showthread.php?t=323932
    http://www.caraudio.com/forum/showth...28#post4856428
    sold: goose, krisfnbz, dubb designs, 2000gator(x2), oxsign, aesoj, viveet(X2),
    mike437,flossinon24s,mxracer591,riffyb, bsean63(x2),nycking23,bryce-man,fastimes(x2),
    boltpride, r-sosa,fusion_freak,siacarman,kcdc30
    prodgod, toasted1,newageking,nmbr1spt,projectnutz(P),DeViOu SoNe,
    traded with: davet, teddyunited, rockmo, spikee, rdaudioman1256, SPY
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    GF has an '06 Cobalt so I'm familiar with the lack of ACC wire. I tapped into the fuse block with no problems. Pull the plastic panel on the pass side by the driveline hump and you'll find it there. I believe I used the "wiper" fuse as that's hot when ignition is on...
    Feb 2006
    Clemson, SC
    4,708
    14
    wow fellas that helped me out a bunch thank you!
    mlstrass's Avatar
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    cool, glad you got it sorted out...
    Jan 2006
    ontario
    321
    Quote Originally Posted by mlstrass View Post
    does that wire provide 12v tho when its in acc and not just ign?
  9. #9
    05gliguy's Avatar
    05gliguy is offline CarAudio.com Elite
    Jan 2007
    Olive Branch, MS
    1,278
    Test it, turn on the key so the engine is off and try your wipers, if they don't work then you might want to try coming off a different fuse.
    2008 USACi World Finals, 2nd Place Stock 601-1800
    2007 USACi World Finals, 4th Place Stock 601-1800
    Team Sweep
    Team Kicker
    Team Cactus Sounds
    Refs: shiipseki, VarsityBumper, btnhfan, 02parkave, oxsign, Toxic Tuan, djman37, goose2, revrider1, Intensity, FI15INCH, Mazdaspl, vitveet, solo1, KickerRex
  10. #10
    Feb 2006
    Clemson, SC
    4,708
    14
    i dont understand. When you say tap into the fuse do you mean just stick the wire in and then the fuse back on top? or do you somehow get to the back of the fuse panel and tap into an existing wire. I have the panel off and am to stupid to figure this thing out. Please a little more help.
  11. #11
    05gliguy's Avatar
    Jan 2007
    Olive Branch, MS
    1,278
    you could do either, take some wire and wrap it around one of the prongs of the fuse and push it back in
    Team Sweep
    Team Kicker
    Team Cactus Sounds
  12. #12
    Twistid's Avatar
    Twistid is offline 150.5
    Jun 2004
    in a space out of sound
    9,595
    i suppose you could just put the wire in the slot then put the fuse in over the wire...
    give it a tug or 2 and see if it comes loose
    "A modest little person, with much to be modest about."
    Winston Churchill
    REFS: Spicmonster(buyer), playa1(buyer), splthunder(buyer), 949runner (seller), dbman150 (trade), pbulous (trade), bumpin97jeep(trade) , spudracer326 (seller) , 99stanggt (seller) , xplicitACTS (trade) ... and forgetting a few others
    BHCSAOWKF
