Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 15 of 101
Reload Thread: Anything comparable to the DEX-P9?
    JonJT's Avatar
    JonJT is offline CarAudio.com Elite
    May 2005
    Jersey
    568
    So, is the P9 still king of the hill when it comes to Head Units? Its the only head unit I know with the processing required to properly set up a 4 way system with horns. Has any company equalled or bested th is unit in terms or processing power and audio quality?
    youngfu's Avatar
    youngfu is offline Member
    Jan 2007
    Guatemala
    94
    Re: Anything comparable to the DEX-P9?
    I think DXZ-9255 is comparable to P9 for audio quality.
    JonJT's Avatar
    May 2005
    Jersey
    568
    But not processing abilit........ Although I would expect a such for onl 800 dollars new.
    Babs's Avatar
    Babs is offline Senior VIP Member
    Mar 2006
    NC
    364
    It would be a interesting comparison from one of the newer alpine A/V head units with digital out to a H701 processor.. All the same processing power, with added control, multi-channel formatting and DVD capabilities.. But for pure SQ, I'd be interested if they could hang with the P9 or DRZ.. and if not, between the two, which would be the best..
    At that point in a car, either would be beyond diminishing returns unless the sound-deadening and acoustic tuning and all other components were equally top-notch.
    With other cheaper components it would be like having a home theater with all Krell or Levinson front end equipment playing through crap speakers in a non-acoustically treated room with lots of windows and poor cabling and calibration.. I'd rather have mid-fi in a well treated room and excellent speakers, personally.
    JonJT's Avatar
    May 2005
    Jersey
    568
    Multichannel doesnt interest me, but this APline HU and H701 combination does. Do you know if the H701 can handle 4 way crossovers. I see it has the necessary eqs but it doesn't say how many crossovers it has.
    It doesn't seem to have any time alignment or path length compensation that I think the P9 has though.
    Babs's Avatar
    Mar 2006
    NC
    364
    Probably the most detailed specs I've seen on the H701 are here:
    http://www.crutchfield.com/S-ik5IBZI...500PXAH701#Tab
    jluv's Avatar
    jluv is offline CarAudio.com Elite
    May 2006
    DFW, TX
    562
    Quote Originally Posted by JonJT View Post
    It does have time correction.
    It has 8 channel output (3 sets of stereo out and two mono outs).
    You can set the high and low pass filters, adjust the slope (6-30db) and use graphic or parametric eq for each channel individually.
    It also has Dolby and DTS decoding and can create a "phantom" center channel.
    I love the crap out of mine.
    Babs's Avatar
    Mar 2006
    NC
    364
    From what I understand, the 701 has "a" burr-brown dac as well.. Not sure if it's at the level of the 9255 dual 24bit/96khz processing though, but I imagine it's gotta be pretty decent.
    If you think about it, the H701 is not only a DAC, processor, EQ and crossover.. but it's also a preamp.. From what I've read about what makes the 9255 so great, it's in good power supply as well.. Supplying a good 8guage line to the DC/DC converter with the toroidial power chokes is probably one reason that unit is such a beast, ontop of the excellent processing. If I were installing a 701, I'd use a nice thick power line and ground, personally.
  9. #9
    Rich B's Avatar
    Rich B is offline CarAudio.com Veteran
    Oct 2006
    *under the rainbow*
    6,201
    19 Post(s)
    My only problem with the 701 is that its so old now it should be selling for less money than Alpine wants for it.
    In every other consumer electronics market, after a product has been out for a year or two without a revision the price is lowered because the chips used inside are a generation (or more) behind the newest versions, and cost the manufacturer substancially less.
    Oh well............
    <img src=http://img.photobucket.com/albums/v81/pintobean/feliz_ano_novo.jpg border=0 alt= />
  10. #10
    JonJT's Avatar
    May 2005
    Jersey
    568
    Quote Originally Posted by Babs View Post
    I'll check that, thanks.
  11. #11
    jluv's Avatar
    May 2006
    DFW, TX
    562
    Quote Originally Posted by Rich B View Post
    Oh well............
    IMO, the 701 is still pretty inexpensive for what it does.
  12. #12
    JonJT's Avatar
    May 2005
    Jersey
    568
    Quote Originally Posted by jluv View Post
    Alright so it has time correction but, how many filters can I impliment per input channel? I need one high pass, two bandpass and a low pass filter for every input channel from the digital out of the HU. Thats two channels alltogether so 8 filters total; 4 per channel. Can the H701 do this?
  13. #13
    Hintzyboy's Avatar
    Hintzyboy is offline Sparks mean its working!
    Feb 2006
    Baraboo, WI
    7,519
    The DRZ9255 has built-in 4-way crossovers. You have to have both the DEX-P9 and the DEQ-P9 to have any kind of processing.
    Refs:
    CarAudio.com: SlickRick, CubanAffection, trevor87, BigBirney420, Apollyon, Dinty01, TeamPSI, QtrHorse (x2), 6spdcoupe, Siddle, Smokingachicken, MisterGrubbs, Fast1One, MiniVanMan(x2), Jntar, blackbonnie, tigerf117, kasimo420, blaze383, XaznKewLguyX, SRim23, RidnClean, Team H&K, djvi0lent, jeeper07, turboaudi
    DIYMA: snaimpally
    CA.com Feedback: http://www.caraudio.com/forum/showthread.php?t=327860
    Ebay Feedback http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback&userid=hintzyboy79
  14. #14
    JonJT's Avatar
    May 2005
    Jersey
    568
    Being that the H701 is old, it probably isn't up to par with the bleeding edge. I don't quite know how "bad" it is though so I will have to investigate more.
    As for power supply and ground wire gauge, it gets to the point of diminishing returns fast. The H701 can't draw anymore than 5 amps at 12 volts which isn't much power at all. Your supply wires don't have to be that large. You can even calculate the power losses for size and type of wire you are using. You don't NEED huge wire to transmit power effectively for this unit.
  15. #15
    jluv's Avatar
    May 2006
    DFW, TX
    562
    4 filters per channel? Sorry man. I don't understand what you mean by that or what you're trying to do. I know my way inside and out of the 701, but just don't grasp what you are asking.
