Results 1 to 12 of 12
Reload Thread: P880 wont turn on
    Trey803's Avatar
    Trey803 is offline GAMECOCKS
    Jan 2006
    SC
    5,717
    56 Post(s)
    P880 wont turn on
    I got my P880 today brand new. I figured hooking the only the power and ground wire would be enough to just turn it on since I am short on time today. I hook it up and BAM nothing happened. ANy ideas?
    HU: DEH-80PRS
    Doors Deadened
    Front Stage: Rainbow SLC 265
    Front Stage Amp: Image Dynamics i2600
    Sub: Dayton RSS210HF-4 8"
    Sub Amp: Image Dynamics i2300
    Wire: Knu
    faulkton's Avatar
    faulkton is offline CarAudio.com Veteran
    Jul 2005
    neverland
    22,097
    8 Post(s)
    Re: P880 wont turn on
    did you hook up the yellow, red and black wires?
    Power, acc and ground?
    pretty funnay eugy
    Jonahdude's Avatar
    Jonahdude is offline ?????
    Feb 2004
    Florissant, MO
    29
    717
    Ignition turn-on wire?
    New setup in the works:
    Vehicle: 1999 Ford Windstar
    Head Unit: Pioneer Premier DEH-P860MP
    Signal Processing: Profile Q100 3-Way active crossover, set to 80hz and 3.5khz
    High Pass: the legendary Aura tweeters powered by a Pioneer GM-3000T
    Band Pass: Ascendant Audio 6.5" Poly Midwoofers powered by a Pioneer GM-5000T
    Low Pass: Elemental Designs 19Ov.2 in 3ft^3 tuned to 30hz, powered by a Power Acoustik 2APC-1400
    Trey803's Avatar
    Jan 2006
    SC
    5,717
    56 Post(s)
    I didnt hook up the acc wire.....isnt this an accesory power wire?
    HU: DEH-80PRS
    Doors Deadened
    Wire: Knu
    faulkton's Avatar
    Jul 2005
    neverland
    22,097
    8 Post(s)
    yes.
    you need to hook up all three.
    pretty funnay eugy
    Trey803's Avatar
    Jan 2006
    SC
    5,717
    56 Post(s)
    Im not using the wiring harness right now just direct connect to the battery....does the acc go into the positive terminal
    HU: DEH-80PRS
    Doors Deadened
    Wire: Knu
    Aug 2004
    Lubbock, TX
    32
    2,932
    yep, gotta have all three
    generally, the constant power wire is just for memory purposes, so it can retain where you are on a CD, your stored radio stations
    have you ever been able to turn on a CD player without the keys in the ignition at least turned forward a little? nope; its the accessory power wire that tells the CD player when to turn on
    2006 Chevrolet Silverado - Crew Cab Z71
    Kicker ZX 750.1
    Four 8" RE RE's
    Bought from: Jamaica2G, Ayrton, Prowler573, netherland24, tRiGgEr, BassBEAST88, HCCAfan, HOAX_1
    Sold to: James Bang, dkguitarist, Scoobydoo, ~Magick_Man~, BigEM, lostsoul, sephiroth619, Skip01, squeak12, CELLERBR, bvr_j_0969, OneKrazyKeebler, negativezeroz
    Traded with: Apollyon, zachzchw, jmanpc
    eBay: pmk0024 - 100% positive
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    29
    717
    Sources say no, you need to hook it up to something that receives power when the car is turned on. The stock stereo should have something of the sort, to allow to stereo to only turn on when the car is in ACC mode or running.
  9. #9
    Aug 2004
    Lubbock, TX
    32
    2,932
    no, it goes into the corresponding wire.
    do it right once or don't do it at all.
    trying to take shortcuts, especially when you don't know what you're doing, is only gonna lead to problems
    would you rather spend 10 minutes more on a headunit install or fry your deck?
    Kicker ZX 750.1
    Four 8" RE RE's
  10. #10
    faulkton's Avatar
    Jul 2005
    neverland
    22,097
    8 Post(s)
    Quote Originally Posted by Trey803 View Post
    yes. red/yellow 12v+
    pretty funnay eugy
  11. #11
    Trey803's Avatar
    Jan 2006
    SC
    5,717
    56 Post(s)
    I dont think yall understood. I will hook it up right. I just got it and wanted to pop my hood and hook it up long enough to see what the screen was like and all. I will definatley be correctly sauldering the wiring harness so no worries there. But ya I got it to work thanx.
    HU: DEH-80PRS
    Doors Deadened
    Wire: Knu
  12. #12
    fenderskirt66's Avatar
    fenderskirt66 is offline Junior Member
    Oct 2006
    Kansas
    20
    Hey Trey803, let us know if you experience the grounding problem that some folks have reported on the 880.
    Thanks!
