Results 1 to 4 of 4
Reload Thread: Pioneer eq settings
    bassaholic's Avatar
    bassaholic is offline Whats Jl stands for??
    Dec 2005
    its very hot here
    116
    Pioneer eq settings
    ok i have a pioneer 4600 it has 3 adjustments for eq low/mid/high if i boost the mids and the highs at lets say +2 every thing sounds good but the bass if i boost the lows it sounds crappy so i leave it flat.If i drop the mids and highs flat or under my bass sounds awesome again but the highs doesnt sound half as good i mess with the parametric eq and all that same thing happens is this normal? I probly gotta make a change to a better sounding deck
    bassaholic's Avatar
    Dec 2005
    its very hot here
    116
    Re: Pioneer eq settings
    Well after a hour or 2 of mess with the deck i finally get the bass how i want it had to set lows at 3+ then drop the lpf on the amp lower sounds smooth and more accurate now i guess this deck ***** at bass output never had to boost the lows by so much b4 on any deck i had any comments?
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    um
    this is how i set my radio
    the low(40hz) mid(2k hz) high(10k hz) is set at 0
    the bass and treble is set at 0
    80
    bassaholic's Avatar
    Dec 2005
    its very hot here
    116
    it sounds like you have your eq flat since u set everything to 0 and ur bass might sound awesome too since you own the great epicenter. Im planning to get something like that but its gonna be the soundstream digital bass machine functions similar to the epicenter.What model pioneer deck you have inches?
  1. CDA-9853 Crossover/Parametric EQ settings???
    By tirtul in forum Head Units
    Last Post: 02-10-2006, 02:56 AM
  2. Wtb -alpine Or Pioneer Eq
    By masterp3864 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 05-19-2005, 11:09 PM
  3. Your EQ settings?
    By linksyz in forum General Discussion
    Last Post: 07-06-2004, 12:34 AM
  4. Pioneer headunit does not save SETTINGS
    By qwkracer in forum Wiring, Electrical and Installation Help
    Last Post: 03-28-2004, 05:02 PM
  5. Setting up a HU and EQ?
    By Efrain in forum General Discussion
    Last Post: 02-12-2003, 09:03 PM
