Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: Eclipse 8053 advice needed
    khail19's Avatar
    khail19 is offline Subaru Nut
    Feb 2006
    Reno, NV
    545
    So I just bought this used for a good price, I am upgrading from an Eclipse 3424. Everything about the 8053 is great except for one thing. The radio reception is awful, as in it seems like the antenna is unplugged. But it isn't, I checked already. Has anyone experienced this problem? My old 3424 had great reception, and I can't believe a deck this nice would be so much worse. I'm just wondering if it's something that can be fixed, or if I'm just going to have to live with it for now. My car is a 2002 Impreza, if that makes any difference. Thanks in advance.
    Sold to:
    LowLinc (BA subs), ClinesSelect (MBQ amp), soul05 (Xtant sub), jmanpc (Kenwood sub), sbcaprice305 (PPI sub), DMDAKOTA (CDT KA-61), UndercoverPunk (A/D/S PQ8), hondacr125 (Pioneer DEH-1500), jciu (Clarion XDZ-716), vipervin (Eclipse 5423), LopezEL (Eclipse 8053), skydeaner (Hex mids), Raven (BP150.1), BigJoker (Clarion APA4320)
    Bought from:
    iceteebone (Eclipse 8053 & 87101), NE14MX (MBQ amp), jmiller0526 (ED 9kv2), excelerater (Hex mids), JoeHemi57 (Bravox comps), LivinLife (Sony deck & Boston sub), jciu ( EU700s & plate amp)
    May 2004
    Dramaville
    19,671
    Re: Eclipse 8053 advice needed
    Quote Originally Posted by khail19
    I get great reception out of mine. Are you sure that it is hooked up? maybe the plug is bad.
    Beat_Dominator's Avatar
    Beat_Dominator is offline Yea, thats Mecha Godzilla
    Mar 2005
    Phoenix Arizona
    30
    21,987
    My 8443 gets crazy good reception.
    Comming Spring 2009
    I make rear-loaded, double crabshell, isobaric enclosures.
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    never used the antenna. either listened to cd's or xm
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    My radio reception was always A+.
    Never had any problems with it.
    khail19's Avatar
    Feb 2006
    Reno, NV
    545
    So do you guys think it is fixable? Maybe it's just a loose connection inside?
    Sold to:
    Bought from:
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    could be loose connection. i had to use an adapter cause my oem antenna was smaller then the one for the eclipse deck, so i had to make it bigger
    khail19's Avatar
    Feb 2006
    Reno, NV
    545
    Quote Originally Posted by iceteebone
    So you're saying you enlarged the antenna receptacle on the deck? Did you just stretch it out with something? I should be able to just to squeeze it back down then, right?
    Sold to:
    Bought from:
  9. #9
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    the antenna plug in the car was smaller then the antenna input on the deck, so an adapter was needed. if that is the case, the antenna will probably still fit in, but will be loose cause it's too small
  10. #10
    khail19's Avatar
    Feb 2006
    Reno, NV
    545
    So how would I make it smaller again? There's that hard plastic sleeve around the antenna cable, so I don't think I can just squeeze it with pliers. Any ideas?
    Sold to:
    Bought from:
  11. #11
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    an adapter. they sell them at walmart for a dollar or 2.
  12. #12
    khail19's Avatar
    Feb 2006
    Reno, NV
    545
    OK, I'll check it out after work. Must be a very thin adapter, cause it didn't seem that loose when I plugged the antenna in. Thanks for the help ice.
    Sold to:
    Bought from:
  13. #13
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    if it doesn't seem loose it may not be the problem, but try it and see
  14. #14
    headless's Avatar
    headless is offline CarAudio.com Elite
    Feb 2006
    Florida (Tallahassee)
    1,293
    Definetely a problem. My CD8051 also had great reception and the 8053 has the same radio tuning circuitry from what i understand.
    Eclipse CD7000 - RioCar Empeg 3
    Rainbow Powerline CS 275.27 / Arc Audio 4150 XXK (Woofers) - Arc Audio 2100 XXK (Tweeters)
    Rainbow Vanadium 12 x2 / Arc Audio 1500 XXK
    Quote Originally Posted by TEAM HAMMER
    Your so full of Crap! The last place you want a Midbass or Sub is in front of you Retard Whens the last time you seen a 12in+ sub up front?
    Quote Originally Posted by bdawson72
    Technically, bigger wire has more resistance.
  15. #15
    djman37's Avatar
    djman37 is offline SOLID
    May 2004
    DFW, TX
    8,363
    all you did was change decks? If you changed harnesses, maybe the power antenna wire isn't connected? What amps do you use?
    Doug Blohm
    Team Southern Bass
  1. Calling all Eclipse CD 8053 Gurus...Need Help!
    By greg12a in forum Head Units
    Last Post: 10-14-2005, 12:12 PM
  2. Calling all Eclipse CD8053 Gurus! Need install/tuning help...
    By greg12a in forum Wiring, Electrical and Installation Help
    Last Post: 10-14-2005, 01:55 AM
  3. INSTALLED: Eclipse 8053 w/ balanced out!
    By ngsm13 in forum General Discussion
    Last Post: 06-01-2004, 12:19 PM
  4. Replies: 14
    Last Post: 05-13-2004, 06:54 PM
