Results 1 to 7 of 7
Reload Thread: Head unit + in-dash EQ question/help
    Xtra's Avatar
    Xtra is offline Member
    Jul 2005
    MD
    54
    I just got a Excelon x789. It apparently has a built in 4 band EQ for fronts, rears and a sub. For the past 5 years or so i've ran a Kenwood 4042a in dash EQ along with my HUs for more of a convenience thing than anything else. I like the ability to adjust the sub on the fly.
    Now my question is, would running this EQ in my new setup be a bottleneck? Will it negate the 5v preouts on the HU? Am I sacrificing anything by using it with the new HU?
    Thanks in advance.
    May 2005
    Bay Area, CA
    61
    Re: Head unit + in-dash EQ question/help
    i have also been using an eq with my deck, an alpine, but only because it has a 2 band eq, but if u are just runing ur deck and amps, with no other processors, wounldnt do u any harm usin ur eq...
    Eclipse 8454
    JL Audio 6.5/4 3Way XR Components
    JL Audio 6.5 2 Way Coax
    PG Xenon 100.4
    PG Xenon 600.1
    2 12" PG Xenon Subs
    Audiocontrol Epicenter
    Dynamat
    Custom Xover Mount In Doors
    *Check My Cardomain*
    http://www.cardomain.com/ride/2202600
    adam71's Avatar
    adam71 is offline P9 = Ultimate SQ
    Jul 2003
    Michigan
    5,795
    Well, what is the pre out voltage rating of your eq?? If that is rated at 2 volts or something like that then 2 volts is all your amps will see. A deck with a higher voltage preout cannot change the voltage level of the eq, just doesn't work that way. Not to mention you need to make sure your eq will accept the higer voltage your deck puts out.
    Source Unit: Pioneer P9 combo
    Tweeters: CDT DRT-25 Silk
    Mids: CDT ES-5 (5.25")
    Midbass: CDT M6 (6.5")
    Subs: Pioneer TS-W12PRS
    Mid & Tweet amp: Pioneer PRS-X340
    Midbass Amp: Pioneer PRS-X720
    Sub Amp: Pioneer PRS-X720
    Xtra's Avatar
    Jul 2005
    MD
    54
    Just a guess but I doubt the pre-out voltage on the EQ is anything higher than 2-3. I ran my old 5v pre deck to the same EQ with no apparent problems.
    I'm just wondering would SQ (or anything else) be noticeably affected running via the EQ vs w/o and if so in what way.
    adam71's Avatar
    Jul 2003
    Michigan
    5,795
    Quote Originally Posted by Xtra
    If I were you I would try it both ways and see which way sounds better to you. THat is the only way to find out for sure.
    The changes would probably be the following.
    - higher preout voltage which would give you a higher noise floor since you would be able to turn your amp gains down
    - if your s/n ratio on the eq was not very good then that would be a good thing to remove from the system
    - last but not least........you would be removing a component from the signal chain and that is almost always a good thing
    Xtra's Avatar
    Jul 2005
    MD
    54
    I hate logical answers when i'm looking to have my handheld
    Thanks .
    adam71's Avatar
    Jul 2003
    Michigan
    5,795
    Thanks .
    Read the edited post again
