Ok I can't figure out how to get to the 3 way crossover on the Alpine CDA-9833. I've tried everything I can think of to get to it, but all it keeps on showing is the 2 way crossover. So how do you get it to go to the 3 way?
there's a lever on the bottom of it... you got to switch it to 3WAY... the front pre outs will be the tweeter, the rear pre outs the mid-range/woofer and the sub will be the sub (duh!)
edit: after you're done, reset the head unit... try resetting the EPROM by holding Power/Source and pressing Band/Tel if it doesnt work
I thought you had to pull the HU and hit a dipswitch on the chasis
yup.
Well thats how all the other alpine decks i owned worked...
Seems like more trouble then it's worth.
Bookmarks
