+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 58
Reload Thread: Pioneer DEX-P99RS
  1. #16
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Re: Pioneer DEX-P99RS
    Quote Originally Posted by rc10mike View Post
    Just curious, how do you have your speakers setup with a front and rear stage?
    Its an older camry tweeters opposite the side mirrors, subs near the base of the door, with the max frequency range going to them on the passive x-over.
    Rear stage is 6x9 behind the headrests of the back seat...
    Maybe a good idea to pull the rear head rests?
  2. #17
    rc10mike's Avatar
    rc10mike is online now I b sippin on sizzurp
    Nov 2007
    Jacksonville, Fl
    2,557
    Well, running passive front stage with tweet/mid in two different locations is definitely NOT going to play well with TA.
    For TA to work properly, each speaker needs to be ran on its own channel. Since you're running passive, you actually have 4 speakers in 4 separate spots with only 2 channels. This is probably why you see funny distances since the HU "thinks" the front stage is only 1 full range speaker..
    The P99 was designed to run an active 3-way front stage and subs, on all individual channels. It has the capability to do all the crossovers for each speaker, so using passives is pointless.
    Im only using 6 of the available 8 channels. Im only running a two way front stage and no rear fill.
    If I were you I would get a 4ch and run the front stage active, just leave the rears disconnected for now, re-do the Auto TA and see how you like it. The TA would yield much better results like this.
    EDIT: I know its more work to run separate speaker wires for each speaker, but thats how it was designed to be ran. When I installed my system over 6 years ago, Im glad I ran extra speaker wire from the trunk to the front, just in case I decided to run active one day
    Bought From:bad @SS chevy, kmanian, bpres9991, TurdFergueson2, donpisto
    Sold To:pcoff61, JoeSmith502, hemi4me?, weddlz, wp7456, cloudwalka, cx-7heaven
    Ebay: rc10zmoney: 100% +
    HU: P99RS
    HAT L1 Pro R2
    HAT L6SE
    SS HRU.4 and HRU.2
    x2 IDQ 12 Sealed
  3. Thanks West thanked for this post
    Likes av83 liked this post
  4. #18
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    I'll work on getting some more channels in the rear and switching over to active. I appreciate your advice, thank you.
  5. #19
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    After some more critical listinging I had to change how I feel about the deck's autotune. I still use it, but make adjustments to the equilizer to make it sound better...
  6. #20
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    I have found that I kind of enjoy running with auto tune on. I also leave the sound retriever on low for most music... I like the way it sounds that way.
    I also pulled the head rests out on the rear seats, it helps some.
  7. #21
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    2,619
    48 Post(s)
    God, I wish I could be there when you run get the wire ran and hear it active the first time. You are going to lose your mind, lol. Especially considering the quality of your equipment.
    Also.. nice review, and congrats on winning for it.
    HU: Pioneer DEH-80PRS
    Front stage: PHD FB 6.1PRO & Vifa XT25BG60-04
    Sub stage: '05 RE XXX 12" w/Fi recone
    Highs Amp: Kenwood Excelon XR-4S
    Lows Amp: MMATS D300HC
    The Rest: AT 60 mil, Optima Redtop underhood and Yellowtop in trunk, Big 3 and front to rear +/- runs in Monster Cable 1/0
  8. Thanks West thanked for this post
  9. #22
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Quote Originally Posted by av83 View Post
    Thanks man! I really appreicate the encouragement. I expect big changes, with the HAT's I got coming (L1 pro, L4SE, and L6SE)... I wish there were more local people who enjoyed this hobby >.<
    I saw your install thread and that looks really awesome. I am definately going to try to follow suit and try to do this install rock solid correct, no corner cutting.
    On a side note, you and I have got to be on the same wavelength or something, because I was re-reading this theard when I saw your comment come up. What are the chances?
  10. Likes av83 liked this post
  11. #23
    av83's Avatar
    Mar 2012
    Illinois
    2,619
    48 Post(s)
    Quote Originally Posted by West View Post
    Thank you
    ....some x-file's shiz goin on around here...
  12. #24
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,147
    113 Post(s)
    wish i had that kinda money :/
  13. #25
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Thank you
    Anytime!
    The truth is out there... lolz
    I am curious did you start out active on your build or start passive then switch? I hear really great things about that x994.
  14. #26
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Quote Originally Posted by CAT MAN View Post
    $hit's not cheap that's for sure and I am not rich by any means. I am gonna have to lay low on the audio stuff after this build is done... for a while.
    Aside from my sub box and 4 of the 6 HATs, all the equipment I have was purchased used and for about 1/2 the list price.
    The L4se and l6se's are new, but the boxes are dented so I was able to find them discounted on DIY with the help of some members here.
    Saved a few hundered on them.
  15. Likes av83 liked this post
  16. #27
    Fi-brations's Avatar
    Fi-brations is offline This is too much fun
    Sep 2011
    Memphis, Tn
    910
    13 Post(s)
    I'll be living in Knoxville next year for college, a long time from now I know, but I agree not too many people in memphis who actually have this as a hobby
    Head Unit: Eclipse CD7000
    Front Stage: HAT Legatia L6V1, Clarus C1
    Front Stage Amplifiers: Xtant 4180c, 2100b
    Sub Stage: IA Flatlyne 18" For Sale
    Subwoofer Amplifier: Alpine MRV-1507 For Sale
    StarMountainSound Box
    Business with: davidtemple(x2), infamous_e46, Bettrn'Reverse, splaudio, TaylorFade, Tallc, Louisiana_Crx, RidnClean, b.mena, Mike Burke, Gameovercca, Ram_Designs, Double 07
  17. Thanks West thanked for this post
  18. #28
    av83's Avatar
    Mar 2012
    Illinois
    2,619
    48 Post(s)
    Anytime!
    Started passive. Found out by accident that my amp was active capable, so i dug into it after that. The deck is really nice for the $. Its not an active unit, but the Time alignment works well, and it has excellent sound to it.
    Me too, but I am pretty happy with knowing that I have done what I have with so little.
  19. Likes West liked this post
  20. #29
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Quote Originally Posted by Fi-brations View Post
    Right on man, I teach at UT. We should have a beer sometime.
  21. #30
    Sep 2011
    Memphis, Tn
    910
    13 Post(s)
    That's Awesome, what do u teach?
+ Reply to Thread
  1. Pioneer DEX-P99RS
    By jsampsell in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 07-01-2011, 05:57 PM
  2. Replies: 8
    Last Post: 05-19-2011, 02:31 PM
  3. Question about Pioneer DEX-P99RS .....
    By PeerlessAudio in forum Head Units
    Last Post: 09-18-2010, 11:48 PM
  4. Pioneer DEX-P99RS VS Pioneer DEH-800PRS?
    By aquafire in forum Head Units
    Last Post: 08-01-2010, 06:53 PM
  5. Pioneer DEX-P99RS
    By troytag in forum Head Units
    Last Post: 10-18-2009, 02:22 PM
Tags for this Thread
