FS: Arc Audio DXE (4-way active xo/eq/line driver)
Arc Audio DXE
Brand new, still sealed
In short it's a 4-way active xover/eq/line driver with a bunch of extras.
See manual linked below for everything there is to it.
In the future all audio products will have the flexibility of a fully Digital Control System with the sweet smooth sound and perfect sound stage of an Analog Device. This was our goal when we set out to build the DXE. We use an advanced digital controller to operate all the features of a sophisticated Analog Crossover. The result is the channel tracking and frequency control of a fully digital crossover without the harsh mechanical sound that can accrue. For years home audiophiles have enjoyed Hi End Analog Systems that produce stunning sound stages and smooth harmonics. Now the DXE brings this level of performance to the car with the control of a fully digital crossover.
This truly Audiophile Crossover is coupled with a 5 Band Parametric Preamp EQ with fully balanced output and a Digital Control
Max input level: 8 volts RMS
Input sensitivity: 8V (0dB), 2V (10 dB), 700m(20 dB)
Max output level: 10 volts RMS
Input impedance: 47.5 K ohm
Minimum output impedance: 600 ohms
Harmonic distortion + noise: <.005
Frequency response: +/- 0.2dB
Separation at 1KHz "A" weighted: >78 dB
Signal to Noise "A" weighted: >108dB
Current requirements: 1.2 amps
5 Filters with +/- 15 dB at
20Hz-50Hz with Q of 2,
50HZ-100Hz with Q of 1.4,
100Hz-1KHz with Q of 1.1,
1KHz-10KHz with Q of 1.1,
10KHz with Q of 1.1.
Manual:
http://www.arcaudio.com/product-pdf/DXE_manual.pdf
$850 shipped
Will be shipped with FedEx (unless you want me to use other carrier)
Don't have any itrader feedbacks on CA but have them on diyma, caco and nissanclub all under the same name - Vital
Re: FS: Arc Audio DXE (4-way active xo/eq/line driver)
Very Nice!!! Someone should scoop this up!
^^^ thanx.
Offers anyone?
The only thing this unit doesn't do is TA and blow jobs. Someone has to want this!
Tags for this Thread
- You may not post new threads
- You may post replies
- You may not post attachments
- You may edit your posts
Forum Rules
Bookmarks
