Results 1 to 2 of 2
Reload Thread: LOAD TEST RESULTS, Northstar SMSAGM80
    GPcarAudio.com's Avatar
    GPcarAudio.com is offline Supporting Vendor GPcarAudio.com is a Supporting Member of the forum!
    GPcarAudio.com is a Supporting Vendor of the forum!
    Jun 2012
    Missouri
    1,036
    19 Post(s)
    243 Post(s)
    Youtube video link below
    https://www.youtube.com/watch?v=yndq8QM26Gk
    Northstar SMSAGM80
    Specs, 40 AH
    3.8" x 9" x 10"
    35 lbs
    Only loading it down to 11 volts was the target, because when you throw an alternator into the scenario while a car is running/ at charging voltage and amperage you'll be in the mid to high 12s ballpark typically. Will vary based off of the size of the alternator, but regardless, this battery is a beast.
    3) 15 second load tests back to back. in about a 1 minute span of time.
    1st pull, 11.00 volts holding a 450 amps
    2nd pull, 10.95 volts holding just over 450 amps
    3rd pull 10.84 volts holding right at 500 amps.
    not bad for a budget battery.
    This battery is the EXACT same build design and technology as the Northstar SMSAGM400, only it is 1/4 the size, and under $200. We worked very hard with Northstar to make this happen and the results are outstanding! Enjoy the video.
    Coupon Code: caraudio.com For Member Discount
  2. Likes Jeffdachef liked this post
  3. #2
    Jun 2012
    Missouri
    1,036
    19 Post(s)
    243 Post(s)
    Re: LOAD TEST RESULTS, Northstar SMSAGM80
    One thing i'd like to note, is this batteries starting voltage was at 12.6 volts due to being benched over and over again at northstar to clear quality control before i took it to the competitor brand to have load tested.
    This battery rests right at 13 volts. If i took it there fully charged up we would see even better numbers than this video shows,
    And as you can see, this tiny 40AH northstar at 35lbs even starting out partly discharged beats or meets the performance of any 70lb group 31 110AH+ sized agm battery on the market, and at under $200.
    Northstar FTW
  4. Likes Jeffdachef liked this post
  1. Test Results: hAvoc vs. SX
    By I want SExxx in forum Subwoofers
    Last Post: 01-03-2007, 03:16 PM
  2. based on these test results with a dmm, where to set my HU volume
    By frankiebones in forum General Discussion
    Last Post: 10-16-2006, 07:38 PM
  3. test results 4000d
    By 1loudsuv in forum Amplifiers
    Last Post: 01-09-2006, 01:07 AM
  4. brutus bx1500d bench test results
    By SPL140.2 in forum Amplifiers
    Last Post: 03-10-2005, 03:34 PM
  5. Amp test results
    By helotaxi in forum Amplifiers
    Last Post: 02-22-2004, 07:10 PM
