Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Reload Thread: Budget Friendly Northstar SMSAGM80 NOW AVAILABLE
  1. #16
    GPcarAudio.com's Avatar
    GPcarAudio.com is offline Supporting Vendor GPcarAudio.com is a Supporting Member of the forum!
    GPcarAudio.com is a Supporting Vendor of the forum!
    Jun 2012
    Missouri
    1,032
    19 Post(s)
    243 Post(s)
    Re: Budget Friendly Northstar SMSAGM80 NOW AVAILABLE
    Quote Originally Posted by NoLoud4U View Post
    Got anything that will fit a group 90?
    the closest we have to those dims is an agm35, but youd have to see if you cxan go 1.5" taller
    http://gpcaraudio.com/northstar-agm35/
    Be sure to be logged in when viewing
    Coupon Code: caraudio.com For Member Discount
  2. #17
    Jun 2012
    Missouri
    1,032
    19 Post(s)
    243 Post(s)
    more pics
  3. #18
    Jun 2012
    Missouri
    1,032
    19 Post(s)
    243 Post(s)
  4. #19
    Jun 2012
    Missouri
    1,032
    19 Post(s)
    243 Post(s)
  5. #20
    Lschevelle's Avatar
    Lschevelle is offline Senior VIP Member
    Apr 2009
    LA.
    263
    65 Post(s)
    I'm interested in northstar batts. I have two ampere 5k's what batteries should I go with
  6. #21
    adulbrich's Avatar
    adulbrich is online now Lock up your daughters!
    May 2014
    Ames, Iowa
    20
    13,851
    119 Post(s)
    6123 Post(s)
    Quote Originally Posted by Lschevelle View Post
    Depends on what you have for an alternator
    My Silverado is under construction AGAIN http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/621466-alexs-silverado.html
    Quote Originally Posted by massivespl View Post
    Love is when she licks your butthole and try's to kiss you and u smack her but she doesn't get mad because she know that nasty and she in the wrong
    Quote Originally Posted by Slo_Ride View Post
    Fuck me running. Even I wouldnt eat stripper snatch.
    Quote Originally Posted by ilikeradios View Post
    I would rather beat you to death with a garden rake then talk politics with you due to your overwhelming ignorance.
    Quote Originally Posted by Joseph7195 View Post
    A three legged hooker walks into a bar. Yadda Yadda Yadda, I ended up sucking a dick.
    Quote Originally Posted by gckless View Post
    When that hooker turns out to have a cock. That's bigger than yours.
    Quote Originally Posted by LongThrow View Post
    If I had $2,000, I wouldn't be running kicker comps.
  7. #22
    Lschevelle's Avatar
    Apr 2009
    LA.
    263
    65 Post(s)
    Quote Originally Posted by adulbrich View Post
    Going for a 370 from singer or mechman
  8. #23
    Jun 2012
    Missouri
    1,032
    19 Post(s)
    243 Post(s)
    Whats up man, with that alternator and depending on how underrated the ampere 5k's are, I'd do 2 to 3 Northstar SMSAGM400
    A local was running an ampere 7.5k on 2 Northstar SMSAGM400 with a 300 amp alt and would typically hold just under to over 13 volts non stop demoing on music.
  9. #24
    Lschevelle's Avatar
    Apr 2009
    LA.
    263
    65 Post(s)
    I'll be running the 5k at a little bit over .5 ohm so I'm guessing I'll be seeing about 5800-6k per amp
  10. #25
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    20
    13,851
    119 Post(s)
    6123 Post(s)
    Not after rise. Maybe close to 5k each on music.
  11. #26
    massivespl's Avatar
    massivespl is offline Banned
    Sep 2008
    Bay city, MI
    1,094
    7 Post(s)
    600 Post(s)
    Quote Originally Posted by GPcarAudio.com View Post
    All that's means was his ampere 7.5k wasn't even pulling 300a of current.
  12. #27
    wew lad's Avatar
    wew lad is offline wew lad inc
    Mar 2015
    Des Moines, IA
    5,308
    50 Post(s)
    2850 Post(s)
    here's the specs on the smsagm80 if you're like me and too lazy to open up an external webpage ('mericuhh)
    40AH
    1500 amp SS Current
    820 pulse amps
    400 cca
    Will last 900+ cycles in extreme recharge and discharge conditions.
  13. #28
    Jun 2012
    Missouri
    1,032
    19 Post(s)
    243 Post(s)
    LOAD TEST RESULTS
    Youtube video link below
    https://www.youtube.com/watch?v=yndq8QM26Gk
    Northstar SMSAGM80
    Specs, 40 AH
    3.8" x 9" x 10"
    35 lbs
    Only loading it down to 11 volts was the target, because when you throw an alternator into the scenario while a car is running/ at charging voltage and amperage you'll be in the mid to high 12s ballpark typically. Will vary based off of the size of the alternator, but regardless, this battery is a beast.
    3) 15 second load tests back to back. in about a 1 minute span of time.
    1st pull, 11.00 volts holding a 450 amps
    2nd pull, 10.95 volts holding just over 450 amps
    3rd pull 10.84 volts holding right at 500 amps.
    not bad for a budget battery.
    This battery is the EXACT same build design and technology as the Northstar SMSAGM400, only it is 1/4 the size, and under $200. We worked very hard with Northstar to make this happen and the results are outstanding! Enjoy the video.
  14. #29
    Jun 2012
    Missouri
    1,032
    19 Post(s)
    243 Post(s)
    Heres how small and compact this little bad boy is
  1. March RAFFLE: Tickets now AVAILABLE
    By swimfreak26 in forum General Discussion
    Last Post: 03-06-2005, 12:38 PM
  2. Team Caraudio.com stickers now available!!!!!
    By ridered36 in forum Car Audio Competition, Shows and Events
    Last Post: 03-17-2004, 05:16 PM
  3. Denongate deck now available..
    By Shugarra in forum General Discussion
    Last Post: 01-06-2004, 04:05 PM
