Results 1 to 12 of 12
Reload Thread: Liquid Deadner - Spectrum vs eDead v3
    crea78's Avatar
    crea78 is offline Senior VIP Member
    Apr 2005
    Charlotte, NC
    155
    I was planning to use eDead v.1.SE, but seeing how several ppl have witnessed their's falling off, I've decided to use liquid deadner instead. Are there any major differences between Second Skin's Spectrum vs eDead v3?? Since I have a $10 off coupon from Elemental Designs, 1 gallon of v3 will cost me ~$60 with shipping and will cover 50 sq. ft compared to Spectrum's 40 sq. ft. Will the extra $20 for the Spectrum (figuring in shipping at this price) be enough to justify the cost over eDead v3??
    Also, is it worth applying Second Skin's Rattle Pad on the doors as well. $100 for 18 sq. ft seems like alot of $$, but if it helps out ALOT, then I guess it's worth it. I'm also wondering should I place the Rattle pad on the inner or outer door panels.
    Upcoming System: Alpine CDA-9887 w/ Imprint + 80GB iPod | Rainbow Germaniums (bi-amped) | Zapco 200.2 (tweeters) | Zapco 360.4 (mids) | (2) IDQ10v3 | Zapco 500.1 (subwoofer) | Second Skin deadening
    References: CA.com: 3.5Max6Spd | lyttleviet | R05Nismo ; DIYMA: Puffhead | simplicityinsound | sonic_purity | BooneinCO | blacklabel | F150 Truckin'
    Bigrick31's Avatar
    Bigrick31 is offline Carpe Diem
    Mar 2004
    Mid*Cal
    3,557
    Re: Liquid Deadner - Spectrum vs eDead v3
    the best person to ask would be ANT hell answer any and all of your questions weather it be about his produsts (second skin) or any other companies products. ive used spectrum and it works great i was very pleased with it. be very carefull though when applying liquid deadoner that you dont cover any nuts scresw or bolts you may need to access some time in the future. i did it and trust me its not fun trying to get liquid deadoner off a bolt.
    LightningStryk7's Avatar
    LightningStryk7 is offline Senior VIP Member
    Mar 2005
    Colorado
    279
    Ive noticed that alot of peopels edead falls off also. Do they just slap it on there? wouldn't a spray ahesive / clean the surface well keep it on for like ever? (kind of off topic and dont meen to jack the thread, im just wondering).
    Car: 1999 Plymouth Neon
    Head Unit: Alpine CDA-9853
    Components: RE RE comps in some custom kick panels.
    Subs: 1x Alpine Type R 1242D In a vented 33 hz 3cuft box. (redesiging)
    Sub Amp: 1x Alpine MRD-M301 mono amp (400 rms/14.4volts @ 2ohms)
    Speaker Amp: Infinity 7520a (97 rms x2 /14.4volts @ 4 ohms)
    zachzchw's Avatar
    zachzchw is offline CarAudio.com Veteran
    Dec 2004
    ohio
    6,647
    Quote Originally Posted by LightningStryk7
    Ant explained it all in another thread. Good point on the spray adhesive, might be an idea.
    cappy72's Avatar
    cappy72 is offline CarAudio.com Elite
    May 2004
    NY
    907
    I did everything that I could do to prevent the deadener from falling off... and it fell off
    crea78's Avatar
    Apr 2005
    Charlotte, NC
    155
    Quote Originally Posted by zachzchw
    I emailed ANT already and I will also do a search for this particular thread.
    crea78's Avatar
    Apr 2005
    Charlotte, NC
    155
    If the "Product Specials" are still in effect over at Second Skin's website, I may think about doing a mat based deadener for my doors and use liquid later on for my trunk. What I've decided on now, I can use 40 sq. ft of Damplifier + Rattle Pad for ~$155 or 36 sq. ft of Damplifier Pro for ~$165. The former will give more more deadener to do my trunk lid and will include an absorber pad, but the latter is a much higher grade mat. Tough decsion!!
    I plan to upgrade my speakers to eDi 6500 and I know the midbass will be significantly more than what I have now. Of the two options, which one would be better for my Civic Coupe?
    zachzchw's Avatar
    Dec 2004
    ohio
    6,647
    Id go with the cheaper one for now, then you can always add a second layer if need be.
  9. #9
    acousticguitar's Avatar
    acousticguitar is offline Law and Order
    Feb 2005
    Somewhere in Cali...
    653
    i would do damp + rattle if you go w/ mat. consider b stock as well if you *really* need to save $.
    References
    CA Forums: SecondSkinRep, DesertHeat, Twoohfour, Hellomota, 99StangGt, Ashaman, 95prober, Snb778, 318bavsporti, Iceteebone, Sundown1989
    Other: Radeon [SiN], Ibanezcollector [ECA], kepone [ECA], TN_Audiophile [ECA]
    eBay feedback: Taylorguitar [57 positive]
    System
    Alpine CDA-9887
    Alpine MRV-F302 / Alpine PDX-1.600
    Focal 165KX Mistral / JBL GTO 5.2c / pair Rockford HE2 8" sealed
    Crutchfield referral code: pvtxk-80tpx-ke4ws
  10. #10
    crea78's Avatar
    Apr 2005
    Charlotte, NC
    155
    How much better is the new Damplifier compared to the B-stock?? If it isn't that much of a difference, then I'll look into that as well.
  11. #11
    Anthony Collova's Avatar
    Anthony Collova is offline Supporting Vendor Anthony Collova is a Supporting Member of the forum!
    Anthony Collova is a Supporting Vendor of the forum!
    Jan 2005
    Scottsdale
    37
    1,352
    45 Post(s)
    Quote Originally Posted by crea78
    Both products will work well in most applications.
    Edea v3 is made by a solid company (not ED, made by another company I used to work with)
    Spectrum is good as well. either will do the job.
    ANT
    BTW
    When applied at 1mm thick you will get 40 sq feet of coverage wherther you use Second Skin or edead or even water. it is all mathmatics. no way around it.
    ANT
  12. #12
    Mar 2005
    Where you live (Ex. Los Angeles, CA)
    2,264
    Icon14 Re: Liquid Deadner - Spectrum vs eDead v3
    Quote Originally Posted by Second Skin Rep
    ANT
    BTW
    ANT
    I <3 ant...
  1. Deadner Liquid Alternatives
    By DP&MD11 in forum Subwoofers
    Last Post: 05-10-2005, 11:29 PM
  2. eDead v3 TEASER PICS
    By AcidicDreams in forum General Discussion
    Last Post: 03-07-2005, 01:41 PM
  3. Taking edead v3 off
    By littlebuddy34 in forum General Discussion
    Last Post: 02-23-2005, 10:36 PM
  4. Spectrum V3
    By Colin P in forum General Discussion
    Last Post: 02-08-2005, 03:15 PM
  5. Second Skin Spectrum V3. ____ vibration putty
    By ifandorbuts in forum General Discussion
    Last Post: 12-16-2004, 01:12 AM
