Quote Originally Posted by nixter080
Ok, awesome, thanks a lot, there's a memphis dealer in my town, so i'll go check those out. Also, to the reply earlier, how do i make sure the 6x9's are in phase? is there a special process for that?
Make sure you have + to + and - to - on both speakers the same. If you have one wired opposite the other, they will cancel each other out. If it is where you can, look across the two speakers and see if you can tell if one is going up while the other is going down. If they are, you are out of phase. Switch the connections on one of the speakers. They should be moving in unison
