Results 1 to 6 of 6
Reload Thread: big fat stuff
    burton56911's Avatar
    burton56911 is offline Junior Member
    Dec 2001
    United States
    big fat stuff
    2 questions<br />Can you hook more than 1 amp up to a sub?<br />Can you bridge the front right channel and rear right channel on an amp or do they both have to be either front or back in order to bridge?
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Originally posted by burton56911:<br /><strong>2 questions<br />Can you hook more than 1 amp up to a sub??</strong><hr></blockquote>
    Depending on the sub yes you can.
    <strong><br />Can you bridge the front right channel and rear right channel on an amp or do they both have to be either front or back in order to bridge?</strong>
    <br />Also dependant on the amp. But most amps can only have the front channels or the rear channels bridged.
    5 % equipment
    90 % install
    5% beer
    Dec 2001
    United States
    what i mean with the sub is can your hook up more than 1 amp on a single voice coil
    Dec 2001
    United States
    what i mean with the sub is can your hook up more than 1 amp on a single voice coil?
    PS: Ive seen a dual voice coil sub with 4 amps hooked up to it in comps
    CherokeeSounds's Avatar
    CherokeeSounds is offline Junior Member
    Dec 2001
    home
    It may be possible if you run both amps in series with the sub i.e. (pos.+ of first amp to pos.+ of sub./ neg.- of first amp to pos.+ of second amp/ neg.- of second amp to neg.- sub.) Seems to me like it might work, however I have never heard of anyone trying to do it. If the other guy that responded saw mutiple amps to a coil, like he said 4 amps to two coils, then that is the only way I can see it possible. Keep checking to see if my theory works, or try yourself at your own risk.
    Dec 2001
    United States
    would running the amps in series affect the impedence of the sub?
  1. Adamj You Get A Big Fat F'in F!
    By jalverson in forum *Negative* Feedback
    Last Post: 03-06-2006, 03:35 PM
