Results 1 to 12 of 12
Reload Thread: Where is this alt noise coming from?
    btnhfan's Avatar
    btnhfan is offline Hail to the King Baby!!!!
    Jan 2004
    CT/ GA Tech, Atlanta
    31
    7,067
    I just put everything back in, except I added a dvd player, so now my dash has soo many wires back there. I never had any noise before, and I know it is coming through the RCAs. It comes through all 3 sets. Could it be something came loose back behind the dash, or are all wires adding to this?
    It was fine before, now its not.
    Best receiver ever?
    I think so
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,449
    11 Post(s)
    Re: Where is this alt noise coming from?
    Is anything metal touching the RCA's?
    btnhfan's Avatar
    Jan 2004
    31
    7,067
    Havent checked. It might be. Its sooo crowded back there. Civic dashes arent big to begin with.
    Best receiver ever?
    I think so
    Decipha's Avatar
    Decipha is offline www.EFI Dyno Tuning.com
    Mar 2005
    New Orleans, LA
    30
    3,265
    2 Post(s)
    make sure its grounded good, a poor ground can cause noise, also is it alternator whine or does it do it when the cars off too ??
    btnhfan's Avatar
    Jan 2004
    31
    7,067
    No ground are fine. Re did all of them, very low resistance. Its definatley alt whine. It changes with engine rpm. Not when car is off.
    Best receiver ever?
    I think so
    btnhfan's Avatar
    Jan 2004
    31
    7,067
    Bump for other suggestions
    Ill check all this out tm
    Best receiver ever?
    I think so
    Ignatowski's Avatar
    Ignatowski is offline CarAudio.com Veteran
    Mar 2005
    Dirty South
    6,854
    104 Post(s)
    was your HU powered up when you disconnected the wires?
    Pio's need to be unpowered while you work on your system
    sometimes they have some BS internal GND that goes bad when
    wires are moved while powered up
    bean's Avatar
    bean is offline DIP
    Jan 2002
    Dallas, TX
    574
    video pieces (like your DVD players) are noisy. You said you "checked" all the grounds. What does that mean? here is the checklist I typically go through when trouble shooting noise......
    Head unit (all sources) Grounded at the same spot the amps are grounded ... Yes you have to run a new cable
    Amps. All grounded to the same spot?
    Is the *ONE* ground location clean? Free of paint and corrosion?
    How big is the battery to chassis ground cable? Is it bigger than any other power/ground wire in the car? It should be...
    Are your RCA's run as far as possible away from the power wires?
    Try these.
    Get XM Radio, it's awesome!
    Alpine/Xtant/Boston
  9. #9
    jacko's Avatar
    jacko is offline CarAudio.com Elite
    Mar 2005
    rogers, MN
    29
    584
    You said there was noise, and now there's not? It's your deck, just get it serviced. It happened to me too, Pioneers are known for bad internal gorunds.
  10. #10
    btnhfan's Avatar
    Jan 2004
    31
    7,067
    Yes I already did all the above for the grounds.
    I think its hte dvd player, because it was fine without it for noise, or metal could be touching. I couldnt look at it today, Ill do it tm.
    I pulled the hu out for a few weeks, then put it back in w/ dvd player. Changed nothing else.
    Best receiver ever?
    I think so
  11. #11
    skmfkr's Avatar
    skmfkr is offline CarAudio.com Veteran
    Jan 2005
    Savannah, GA
    31
    6,309
    i just installed my dvd player and i got the same problem, but its only when the dvd player is playing not the cd player, but i cant hear it over the music
    '08 Ford Escape XLT
    2 12" DC XL's + 2 RD D9s
    Selenium and Crescendo on AQ4X90
  12. #12
    btnhfan's Avatar
    Jan 2004
    31
    7,067
    I cant hear it over the music, only when the volume is really low, because its coming throufh the non-fading (sub) preouts. I bet its the dvd. Is there anything I could do for shielding?
    Best receiver ever?
    I think so
  1. odd noise coming from comps...
    By cjj2d in forum Speakers
    Last Post: 03-18-2005, 12:58 AM
  2. subs that people will hear
    By Big-Cat in forum Subwoofers
    Last Post: 09-17-2004, 01:42 PM
  3. A strange clicking noise coming from my speakers
    By YuH8N in forum Wiring, Electrical and Installation Help
    Last Post: 06-04-2002, 06:31 PM
  4. how can i get rid of the car noise?
    By Grand Am in forum Wiring, Electrical and Installation Help
    Last Post: 05-31-2002, 07:47 AM
