Results 1 to 8 of 8
Reload Thread: Going Active....
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,737
    20
    Going Active....
    Looking for help from some of the SQ people or People who are experienced with active xover setups.
    My plan:
    Adire Audio Extremis Mids (To be fiberglassed in the doors)
    Vifa 1" Neodymium Tweeter (suggested to me as a good match for the Extremis by Adire)
    Currently, I have a Phoenix Gold 400.4 It gives me 230 x 2 rms @4ohms bridged as the birthsheet states.
    I need to know what else I need to make this setup a reality. Obviously an xover, do I need an external EQ? Some specific suggestions would help as well...I'm looking for something that will be good quality and get the job done (NO extreme audiophile...expensive stuff needed ).
    Thanks for the help fellas!
    NG
    http://crunktimes.com/ct/
    nG - BSEE
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    40
    14,802
    Re: Going Active....
    i got a crossover for you man-$30 shipped its a memphis 16-cx25a. although i cannot find any info on it anymore i assure you its a good crossover. i only actually used it in an sq set-up for less than 2 months--then i traded in the sq for sql and changed everypiece of equipment i had.
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    27
    15,432
    21
    your gonna need to bandpass the mids and hp the tweet. eq would be nice, but your HU should have some of that in it.
    active with that DIY set is a good way to go for sure.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Just remember that going active you're going to have to run one speaker per channel, so bridged power is pretty meaningless
    Other than that; as req said, you'll need something that will allow you to bandpass your mids and highpass your tweeters (then lowpass your subs if you are going to also run them through the active xover). Coustic XM6 is a great unit for the price. Pretty much what all the "budget" DIY'ers use. Just be sure to find something that uses pots for the frequency settings and not those switches that can only be set to predetermined frequencies. Also make sure that the xover you choose will allow you to obtain the xover points you are wanting to use.
    An external EQ isn't necessary, but helpful
    What HU do you have?
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    so pretty much going active is just using your own crossover for your different components (midbass, midrange, tweeter, etc.) and not using the passive crossover that comes with a comp set? if so i have been active all this time and didn't realize it. the way i gather it, if you got an eclipse deck you can go active.
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,737
    20
    Thanks req...I knew that's what I needed to do...just wondering if I needed anything else
    Quote Originally Posted by squeak9798
    I'll look into the Coustic XM6, and I guess I'll need to find a new amplifier then
    I have a Clarion vrx945vd 7" In-dash DVD HU... no internal xovers that I know of
    NG
    nG - BSEE
    UndercoverPunk's Avatar
    UndercoverPunk is offline Super Mod
    May 2004
    Dayton, OH™
    15,663
    Quote Originally Posted by ngsm13
    NG
    I have an amp thatll do 210 X 2 and 75 X 2 for the tweets.... but it's chrome... for now...
    Caraudio.com - Where the average member couldn't wire a SPST toggle if they had to.
    More proof.
    Quote Originally Posted by Andrew_as View Post
    I need a program or something that will help me find mounting depth without having to build box and such...
    No, Andy, I'm sure the context is fine.
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,737
    20
    I'm also now going to need suggestions on an amplifier that will properly power the TWO Extremis Mids (8ohm) as well as the TWO Vifa Tweeters (6ohm I do believe). Thanks!
    NG
    nG - BSEE
  1. Setting an Active x-over
    By wannaskizx3 in forum Wiring, Electrical and Installation Help
    Last Post: 08-01-2002, 03:08 PM
  2. full active system
    By boogieman909 in forum General Discussion
    Last Post: 05-31-2002, 01:15 PM
