Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: what’s the average amp’s of a good alternator ???
    robbie_turner's Avatar
    robbie_turner is offline Senior VIP Member
    Oct 2004
    Birmingham, UK
    32
    221
    my stock alternator is rated at 85amps. i have no idea if this a really poor one or not. I’m finally going to get around to do the Big 3 tomorrow. just wondering if that doesn't work judging on the 85 amps do you think i will be dipping in to my back pocket for more money on Car Audio??????
    Oh and as my thread asked what size is a good alternator
    Dont buy Sony like i have!!!!
    saosin's Avatar
    saosin is offline CarAudio.com Elite
    Oct 2004
    Chicago, IL
    567
    Re: what’s the average amp’s of a good alternator ???
    i would like to say 200 amps, that's what i see alot of people running but i could be wrong....
    head unit = Alpine 9830 <--- for sale
    Sub amp = orion 2500d
    subs = 3 13ov.2 in 6cf box tuned to 32hz
    <--- da aZn guy in da DW Crew
    |] \/\/ krew "We keep the hearing aid business alive"
    Oct 2004
    Birmingham, UK
    32
    221
    and my 85amp is a normal stock alternator or not.
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    85 amps is pretty normal for a stock alternator. mine is 90 amps. a good size depends on what equipment you plan to run on it.
    jacko's Avatar
    jacko is offline CarAudio.com Elite
    Mar 2005
    rogers, MN
    24
    584
    i find it really wierd that i have been reading that my '97 bonnevilles alt is 124-130 amps, that is more than a lot of trucks out there.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    All my stockies have been GM 105A alts. 85A isn't the weakest on the market, but it definitely isn't a very strong alt.
    Oct 2004
    Birmingham, UK
    32
    221
    the thing is at the moment im getting pretty big power dips and im running a small set up;
    one Sony 250 watt max for a 12" sub
    One Sony 600watt max for 2 6*9's
    i have had these for ages now and i haven't bothered to up grade because my electrics are band enough now
    Oct 2004
    Birmingham, UK
    32
    221
    with the big 3 should i be able to run these and nearly full wack with out any power dips or will i have to look into getting a new alt? also what would you do first buy a alt or a deep cycle battery???
  9. #9
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    Quote Originally Posted by robbie_turner
    i would go alt. then battery. i'm suprised you are having troubles with those 2 amps. my 2 PG amps slightly stress my stock 90 amp electrical system. i'll be throwing in a 200 amp alt. and big 3 upgrade soon. i went with the 200 amp in case i plan to uprgade amps later.
  10. #10
    Oct 2004
    Birmingham, UK
    32
    221
    thats what i can not get my head around. could it be as simple as the battery is not good or could the alt be faulty? the car is 4 years old. its a Rover 25 BTW do you guys have this in the states its also the same as a MG ZR???
  11. #11
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    my stock alt is 110amps.......i think that cool being that its stock......i plan on running an orion 2500 and orion 7005,,, i know i'll be pulling current out the aaassss...but i'll do the big 3 soon to see if it will help...already got the batts so i'm good
    80
    red top batt 4 starts and yellow top 4 music....with the stinger isolator in the middle of all the maddness
  12. #12
    Oct 2004
    Birmingham, UK
    32
    221
    Quote Originally Posted by 80INCHES
    80
    Good for you mate, oh and cheers for the help
  13. #13
    80INCHES's Avatar
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    ok no problem
    80
  14. #14
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    what size power wire you have going to your amps?
  15. #15
    RCwhat's Avatar
    RCwhat is offline CarAudio.com Elite
    Dec 2004
    Se, MA
    584
    upgrade your ground wire from the negative terminal to chassis to at least 4awg. This is the most important wire in the big3 as electrons flow from neg to pos. The engine is also bolted to the chassis using metal motor mounts (most cars) so the other ground isn't as neccessary. Upgrading the wire from the alt to the battery shouldn't do too much unless you've upgraded the alt as the stock wire is SUPPOSED to be able to flow as much current as the stock alt can put out. The amp will only be able to pull as much current as the ground wire can feed.....make sense????
  1. Which Alternator would you choose?
    By LIGHTBEING in forum General Discussion
    Last Post: 01-05-2005, 08:25 PM
  2. Iraggi Alternator
    By clarity413 in forum Subwoofer and Speaker Reviews
    Last Post: 01-02-2005, 02:09 PM
  3. Replies: 20
    Last Post: 11-30-2004, 12:43 PM
  4. Need Help! Good System for rock? 2 10's and a good amp!
    By corruptedkid in forum Amplifiers
    Last Post: 11-28-2004, 11:45 PM
  5. need help, whats a good rock system? amp and 2 10's
    By corruptedkid in forum General Discussion
    Last Post: 11-28-2004, 11:33 PM
