Results 1 to 2 of 2
Reload Thread: STROBE LIGHTS INSTALLATION???
    davidrh7's Avatar
    davidrh7 is offline Junior Member
    Dec 2001
    Nashville, TN
    Does anyone know how to install "in-headlights" strobes by APC? i get it but i have no clue about wiring and connecting it to switch and battery. I have a box with a red and black wire coming out of it and i have a switch. where do i connect the red and black wires? thats all i need. thanks.-David Henley [email protected]
    locomc's Avatar
    locomc is offline Junior Member
    Dec 2001
    RI
    23
    If it was APC it should have had instructions with it. That box is the relay. I don't really want to say anything about wiring since it could be different from what I'm thinking. Try APC's website first. After, the relays black wire is the gorund wire, you groud that, the red wire probably goes through a fuse to the battery. there should be connectors on the box, 2 of them. One connector goes to the switch through another fuse, and the last conector should go to the strobe bulbs and they themselves should be grounded. Be careful before you do anything. I've melted a LOT of switches and know that wiring something wrong leads to molten plastic.
    If you've got pants on, you're doin' alright.
    2 MA Audio dxi 12's<br />2 Excelon 401-M<br />Excelon 915 deck<br />Ma Audio door speakers
  1. strobe lights???
    By mgaidica in forum General Discussion
    Last Post: 01-25-2003, 12:04 AM
  2. Strobe lights with bumping....where to get?
    By 31337hxr in forum General Discussion
    Last Post: 05-04-2002, 09:17 PM
  3. INSTALLING STROBE LIGHTS???
    By davidrh7 in forum Wiring, Electrical and Installation Help
    Last Post: 01-20-2002, 12:38 PM
  4. INSTALLING STROBE LIGHTS???
    By davidrh7 in forum Subwoofers
    Last Post: 12-23-2001, 12:27 PM
