Results 1 to 7 of 7
Reload Thread: why cant i hear the singing from my speakers?
    lotas's Avatar
    lotas is offline CarAudio.com Elite
    Nov 2004
    Washington
    512
    Ok for some reason the singing is not real loud coming from my speakers, on some CD's you cant even hear the singing and other high notes, while on others you can hear the singing faintly. My amp is a JL 300/4 ... it has nothing to do with the speakers and I have an old cheap amp that I hooked up to them and the speakers sounded fine.
    Could something be wrong with my amp? I just had all the outputs replaced..the amp is brand new, i dont know why i cant hear the singing.
    its on HP filter and its set at about 95, although it doesnt matter, even if i turn it down it does not change.
    you guys ever heard of anything like this?
    Pioneer, JL Audio, Bravox, Peerless
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: why cant i hear the singing from my speakers?
    Sounds like either a setting is wrong (gains, EQ in heaunit if any, etc) or the amp is faulty.
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    30
    873
    either that or you may have your crossover set too low for the speakers and it is trying to play the mid-bass notes and high notes simutaneously. Does your amp have a bass boost feature? If so check to make sure it's off. That's all i can think of right now that could possibly be a problem
    vosschs's Avatar
    vosschs is offline Banned
    Oct 2004
    just east of STL
    26
    5,658
    check your head unit and see if the trebble <sp?> is down
    B@SSAN8OR's Avatar
    B@SSAN8OR is offline plexiglass is tha shiznit
    Nov 2004
    sacramento, ca
    394
    sounds like a crossover problem
    myspace
    AIM: bassan8or
    YAHOO: bassan8or
    lotas's Avatar
    Nov 2004
    Washington
    512
    Quote Originally Posted by squeak9798
    well i thought the amp was broken so i took it and it was tested at an electronics store and they said it was fine except the front right output was bad, so i had all the outputs replaced
    I cant figure out what is wrong, i have tried every configuration of settings on the amp...and i dont see why it would matter what the HU is set at because with any other amp with the same HU settings it works fine
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Quote Originally Posted by lotas
    Have you tried a direct swap of the JL with another amp (after it was "fixed")? If so, and the other amp worked fine, then you just found your problem
  1. Funky sound from speakers @ no volume
    By Rukuzz in forum Subwoofers
    Last Post: 12-20-2004, 10:05 AM
  2. Fuzz sound from Speakers!
    By Rukuzz in forum Wiring, Electrical and Installation Help
    Last Post: 11-08-2004, 09:30 AM
  3. Question on speakers...You may know
    By PickupBass in forum General Discussion
    Last Post: 10-14-2004, 08:26 PM
  4. looking for opinions on four inch speakers
    By guest2345 in forum Subwoofers
    Last Post: 05-25-2002, 08:37 PM
