Results 1 to 7 of 7
Reload Thread: Help/Opinions Please
    Pandora's Avatar
    Pandora is offline Junior Member
    Nov 2004
    Waterford, MI
    What I want to know is would it be better to use two L5 subs at 2 ohms instead of 4 and why? also I would like to know if I did go with the Kicker L5's at 4 ohms instead of 2 ohms if the amp being short 100 watts rms would still be enough to get a nice sound.... I am open to suggestions money is an issue though. I allready bought a box for the kicker's so that is what I am going to go with but I am not sure about the amp.
    This is what I plan on using
    Lanzar VIBE268 2000 Watt 2 Channel High Power MOSFET Amplifier
    2 x 500 Watts RMS at 4 Ohms
    2 x 1000 Watts Max at 4 Ohms
    1 x 2000 Watts Max at 4 Ohms Bridged
    2 x 800 Watts at 2 Ohms
    Electronic Crossover Network
    Bass Boost Circuit
    Bridgeable at 4 Ohms
    2 Ohms Stereo Stable
    Tri-Mode Capable
    Gold RCA Inputs
    Line Outs For Left & Right Channels.
    Power & Protection LED Indicators
    Advanced Protection Circuitry
    Soft Turn On/Off
    Remote Control Bass Booster
    Frequency Response: 15 Hz - 35 kHz
    S/N ratio: 90dB
    Dimensions (W x H x L): 11.5" x 2.3" x 19"
    2x Kicker Solo-Baric L5 S12L5
    copolymer cone
    Santoprene rubber surround
    dual 4-ohm voice coils for wiring flexibility
    frequency response 20-100 Hz
    power range 50-600 watts RMS (300 watts per coil)
    peak power handling 1,200 watts
    sensitivity 87.3 dB SPL
    top-mount depth 6-5/16"
    sealed box volume 0.88-2.0 cubic feet
    ported box volume 1.75-3.25 cubic feet
    I drive a 97' Mercury Grand Marquies LS with leather seats so im worried that the sound will not make it into the car as well as it should.
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,369
    Re: Help/Opinions Please
    1. Welcome
    2. How much is the lanzar ?
    3. Ohms depend on the VC's set up. One is no better then the other.
    You usually get an amp, then pics the VC for the subs to get maximum wattage
    MasterBlast's Avatar
    MasterBlast is offline ChevyForce94
    Dec 2003
    IL
    31
    764
    I have no clue what you should do but im glad you are going to run kicker subs.
    Subs-(2) Kicker l7 10"
    Amp-Kicker kx1200.1
    H/U-Alpine cda-7893
    Front- Pioneer 4'6'' junk
    By me. Bull **** is everything in between of working and dying
    Pandora's Avatar
    Nov 2004
    Waterford, MI
    Im seeing the lanzar around for about 150-190$$$ or so, The kickers im getting for 150$$$ per speaker.
    pks71's Avatar
    pks71 is offline Senior VIP Member
    Jun 2004
    nova scotia
    202
    You must select the proper woofers(ohms) for the amp. They must work together to get the most out of you set up. For instance. I run a amp that is 1000 [email protected] ohm and the amp is 1 ohm stable. I have a dual voice coil sub. each v.coil is 2ohms. If you paralel the v.coils, that makes 1 ohm. If i used a dual 4ohm sub par. then the sub would recieve about 1/2 the power(500watts). If this doesn't make sence to you you should go to someone you know that can show you on paper. Or you can find a link. Rochford fosgate has good wiring diagrams on their site.
    good luck
    Pandora's Avatar
    Nov 2004
    Waterford, MI
    Well ive never owned a system and dont know very much about them but if somone could break down how I should wire the L5's up and if they would work good with the lanzar amp if they will have enough power, if I will need somthing else along with the subs and the amp such as a capacitor or somthing like that, what size wire I should use
    Also im looking to get my HU installed but I want it profesionally done with the pocket and what not and have them run the wires to the back to feed the amp. If its too pricey I will probably just try to do it myself, I would hate to mess up though..
    Aug 2004
    Concord, Ca
    27
    335
    runun them at 4ohms would be good, if you get the dual2vc you could get a 4ohm load and 500 to each would push them good.
    1994 Chevy Caprice 9C1
    350 LT1
    DP Video 7" flip-out touch panel
    Infinity 4x6
    4 - Polk 5 1/2's where my 2 6x9's should be
    RE SE 15 w/ US amps xt1000d 4cu ft @ 34hz
