Results 1 to 8 of 8
Reload Thread: Long List Of Questions
    rouskisman's Avatar
    rouskisman is offline Member
    May 2002
    Greenville, South Carolina
    33
    77
    Icon14 Long List Of Questions
    I'm really a newbie, beginner whatever you want to call it, in car audio. I was offered 2 10' Concepts for about $150 from a audio store, is it worth it? If you have a pretty good amp pushing it? If anyone can take the time to answer some of my questions it will mean alot to me thanx.
    Most of this was borrowed from other threads, i'm sorry if i offended you in any way.
    1 BOSS audio remote level/x-over << what is this?
    - 1 Stiffing Cap << what is this?
    -1 1 Farad Streetwires cap << what is this?
    -2 Stinger T-distribution blocks << what is this?
    -Stinger 4awg wiring << what is this?
    - But not box i was planning on doing something whack with my box using open pipe resonators << what does this mean??
    -what kind of box is best for a Ranger?? what kinds of boxes are there? and what do they do??
    -900 x 4ohms at 0.03%thd << what is this??
    -4 gauge wiring, PPI capacitor << what is this?
    -db efficiency is like 98.6 db i want about 150 -160 does that 98.6 << what is this??
    -what is a terminal cap??
    -I've heard that it depends on your setup in your vehicle to make a good sound difference, if there are so many different setups what does mostly everyone want to do and not want to do.
    On a amp I am really confused.....
    - Mono, is this just a amp to run for just like specific speakers?
    - 2/Channel, is this just a amp to run the subs and the component speakers?
    - multi/channel, is this just a amp to power more then two sets of speakers??
    What does the following mean.
    spl
    db
    dbl
    rms
    hz
    If someone could really help me out with this I would really appreciate it, My s/n is rooskisman.
    CrysTa|is's Avatar
    CrysTa|is is offline Junior Member
    Mar 2002
    Boston
    23
    Hmmmmm.
    Long list of question's..Might wanna get on a messenger with someone for a chat thru it all. Ive got yahoo (crystalis20) and aol (crystalis200).Always up for some car audio shiz talking... = ]
    BooM!
    Mar 2002
    Independence, MO
    33
    63
    I can help you.
    Add [email protected]
    [email protected]
    [email protected]
    Or [email protected]
    Also try bks1122us on aol.
    Lata Brian
    The JL Freak (I use Pioneer also)
    H/U-Pioneer Premier DEH-P640 50W to 4 Channels
    Front Speakers-Pioneer TS-A1767
    6.75" 3-Way Speaker
    Rear Speakers-Pioneer TS-A1767
    6.75" 3-Way Speaker
    Amps- 2 JL Audio 250.1's
    Subs- 2 JL Audio 12W3's
    crzybob77's Avatar
    crzybob77 is offline Member
    Mar 2002
    Richmond, VA
    33
    88
    Icon31
    well, you can IM me on AIM, same as my name on here. Also, my email is [email protected]. Anyways, let me see if i can help you with a few questions on here.
    You mentioned capacitors (cap) a lot in your questions. A capacitor basically goes on the power wire right before your amp and stores up power quickly in between the bass hits and the gives your amp the power when it needs it especially on the really loud and low hits. They arnt absolutly necessary, but can help your electrical system and can give your amp a little extra power on big bass hits. They come in different ratings of power, called farads. Generally, 1/2 farad is for amps up to 500 watts and 1 farad is for up to 1000 watts. Ummmmm... You mentioned a distribution block. That basically just takes a power wire and splits it into multiple wires and sometimes fuses them. Hmmmm, what else. YOu asked what 4 guage wiring is. The guage of a wire is the measure of its thickness. The smaller the number, the thicker the wire. As the wire gets bigger, then it can handle more power. Also, awg and guage basically mean the same thing. And, i will quickly answer some of your questions about what the abreviations meant. SPL stands for sound pressure level and is basically a measure of how loud your system is. Also, you didnt include this in your abreviations, but SQ means sound quality. Systems are usally described as either SQ or SPL or a balance between the both. SPL systems are made to be nothing but loud, and SQ systems are made to sound as good as possible with not as much regard to the volume of the system. I might be wrong, but i think that RMS stands for root mean squared. But, what it stands for really doesnt matter. It is basically the amount of power something can continuously give or take. OK, i guess that is enough for now. I couldnt answer everything, but it would take a lot more to thouroughly answer all those quesitons. It sounds like you just need to either get somebody to do your whole system for your or do lots of reading.
    Check out my system at http://www.sounddomain.com/id/crzybob77
    Mar 2002
    NE
    35
    114
    BOSS audio remote/x-over: well X-Over is an crossover. A audio remote is either a remote for your deck or your amp. 900 x 4ohms 0.03: well 900 is Max Watts NOT RMS and 4 ohms has to do with power in a way. lower ohms means more power in most cases and less sound quality while higher ohms means less power and more sound quality and 0.03% is the percentage of distortion at 900watts x 4ohms. Lower is better in that area. Boxes are varied.. You have Bandpass: your subs are inclosed completley and most times viewable thru a plexglass window. Sealed: The cone of the sub is exposed while the motor stucture and magnet remain in the box, the box is air tight and has no window. Ported: same as sealed except there are round or rectangular holes put in the box for air to pass thru. THose are the most basic boxes although you will see some other types. Some are made for trucks and other small area installs. Those are mostly called wedges or hatchback and even Custom boxes. Well thats all I can contribute as my brain quits at around 3am and its 4 now
    rouskisman's Avatar
    May 2002
    33
    77
    one more question.
    Over all in the category of Subwoofers, what would you say is the best in spl and sq for how much the going rate of speakers are now (brand and price)? also answer about amps too please.
    bean's Avatar
    bean is offline DIP
    Jan 2002
    Dallas, TX
    574
    Why do I always read on this forum..........SQ vs. SPL? You can have both you know. Also awg is the acronym for American Wire Gauge.
    ace7733's Avatar
    ace7733 is offline CarAudio.com Elite
    Apr 2002
    USA
    679
    I suggest http://www.eatel.net/~amptech/elecdisc/caraudio.htm lots of information on the topics you asked about and much more and explained/presented much better than I could.
