Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Reload Thread: new to a lot of things need help with ohms
    ihaveallama's Avatar
    ihaveallama is offline Member
    Sep 2004
    tx
    39
    Ummm I am new to pretty much all of the car stereo stuff. I am hopefully going to try and install a 15 inch 8 ohm sub with either 2 ten inch 4 ohms or 2 eight inch 4 ohms. I have one amp it is a kenwood 1000 w says it is 500 x1 RMS. I heard that if i was to try and run that one amp to the 15 and the 8's or 10's that i would screw up my amp because the ohms are different. is that true? Because if it is then Im gonna try to sell my 15 as soon as possible. Are there any ways around it?
    thanks,
    sorry for such a newbish question
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    Re: new to a lot of things need help with ohms
    1.) Yes
    2.) Is that the Kenwood8101D amp? I have that one too.
    3.) Can I pet your llama?
    Sep 2004
    tx
    39
    yes it would screw my amp???......so i would need to get all my subs with the same ohms??? my amp is like a kacx520
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,368
    Yes.
    Keep them all the same ohms
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    26
    15,596
    22
    you'll get weird results when:
    hooking up different ohm load subs to one amp
    using subs of different sizes
    petting Mike's llama
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
    Sep 2004
    tx
    39
    so now i ask another question... would it even be worth it to have a whole 8 ohm system? or should i just sell the 15 and get new everything???
    Sep 2004
    tx
    39
    also when u say u get wierd results when u mix subs of different sizes....are u saying it isnt smart to do it or what because i wanted to mix a 15 kicker compvr with 2 8s kicker compvrs
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Quote Originally Posted by ihaveallama
    If using 8ohm drivers will get the power you need from the amps, then more power to you. Nothing wrong with it, as long as it works for you.
  9. #9
    astrallink's Avatar
    astrallink is offline Junior Member
    Aug 2004
    Akron, Ohio
    17
    I suppose you could wire the 8/10's in series for a 8ohm load, then wire this in parallel with the 15" for a 4ohm total load. I have no idea if this would sound good.
  10. #10
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Quote Originally Posted by astrallink
    Keep in mind then that the 10s would get double the power that the 15......there would be uneven power distrobution.
    But, it is honestly a really bad idea to mix and match different sized subs.
  11. #11
    DBfan187's Avatar
    Jan 2003
    46,516
    1 Post(s)
    Quote Originally Posted by DBfan187
    Well?!?!?!?!?!?!?!?!
  12. #12
    supa_c's Avatar
    Apr 2004
    In a chair
    19,368
  13. #13
    Sep 2004
    tx
    39
    ok so why is it bad to mix subs of difft sizes ......i can just push 250 watts RMS to the 15 and like 100 watts RMS each to the 2 eights. .... everything will be in 8 ohms.
    would this not work? or if it would work, what do i have to make sure i dont do so i dont screw anything up...??
    Again I am a newb ....sorry
  14. #14
    Sep 2004
    tx
    39
    and i would use one amp which has like 500 rms X 1 total
  15. #15
    themainjam's Avatar
    themainjam is offline CarAudio.com Elite
    Jul 2004
    Minden, nv
    969
    ok
    1. if you hook 2 15" 8ohm speakers wired in parralel they will be 4 ohms. This is prolly what you want.
    2. if you try and wire the 2 10 in series to make 8 ohms and a 15 at 8ohms then wire those in parralel you will get 4 ohms. but because of the differing power need each sub (IE 15" needs "250Watt RMS" while 10" needs "100Watts RMS") the 10" might be maxed out and the 15" will be barely moving. it would work but you wouldnt get the full potential.
    3. the higher the ohms on most amps will lower the power output. (IE. kicker 500 Watt amp only puts out 125W X 2 @4ohms while it will only put out 62.5W X 2 @ 8 ohms )
    let me know if you need abetter explaination......
    '99 Toyota 4Runner
    _____________________________Condition_____Price Paid
    H/U: Pioneer Premier DEH-630 ____(Installed)_____$100 Used
    Front: Orion P6.2 Comps_________(Installed)_____$150 New
    Rear: Alpine Type R 5.25 Comps_ (Not Installed)___$50 New
    Subs: (1) 10" Alpine Type X Sealed. (Installed)____$50 New
    Sub Amp: Hifonics BX1500D ________(DOA)______$80 Used
    Comp Amp: Orion 8004 100 RMS X 4 (Installed)____$230 New
    AIM = TheMainJam
    MSN = Joshuaminz@hotmail.com
    YIM = all_star09
  1. Wiring JL 10w6v2 D4 into 4 ohms
    By jeeb75 in forum Subwoofers
    Last Post: 09-21-2004, 02:31 PM
  2. 8 ohms or 2 ohms????????
    By ferret7cs in forum Wiring, Electrical and Installation Help
    Last Post: 12-30-2002, 04:21 PM
  3. Ohms with amps and subs...need some help
    By Chris02NeonSXT in forum Amplifiers
    Last Post: 08-13-2002, 06:10 PM
  4. brahma ohms???
    By 85ss in forum Subwoofers
    Last Post: 08-09-2002, 12:39 PM
  5. should I go 2 ohms, or 4 ohms with speakers
    By spmachina in forum Subwoofers
    Last Post: 04-27-2002, 01:41 AM
