Results 1 to 14 of 14
Reload Thread: (thd)total harmonic distortion
    djjdnap's Avatar
    djjdnap is offline FreakyFreaks ofall Freaks
    Mar 2002
    indy-nap-lis
    1,971
    Icon32 (thd)total harmonic distortion
    Now I now what ehe definiton is but does this actually matter in choosing my amp or subs I'm really not shure. But it said 900 x 4ohms at 0.03%thd
    Now it definitely doesn't sound like 900 whats to me, So if anyone could posiibly explain this concept or tell me if it makes a difference or not. I read it can also be read as DB decibels and I know thats for subs and 90 is like average for that I do believe.
    I don't know Help Comemments whateva you got...
    KArAudio.COM
    OMGROFLHI2ULOLLERZTITSHAHAHAHASEALEDMTWTFSTFUKTHXB YENO0B
    -Nick
    wesleysh's Avatar
    wesleysh is offline Senior VIP w/large Member
    Apr 2002
    Michigan
    795
    You can deal with higher harmonic distortion levels out of your sub amp. Harmonic distortion is harder to pick up on at lower frequencies. And from what I understand, THD typically doubles when you move from 4 Ohm to 2 Ohm. I think THD under .10 is inaudible.
    I'm never wrong, EVER! Just ask me.
    djjdnap's Avatar
    Mar 2002
    indy-nap-lis
    1,971
    well that doesn't make any since since it said 900 watts at 0.03%thd so how can I not hear 900 watts. OR does it not mean anything coherent to my problem??
    KArAudio.COM
    -Nick
    djjdnap's Avatar
    Mar 2002
    indy-nap-lis
    1,971
    by the way I had to llok up inaudible then it sent me to audible bewcause it said not audible but audible means to hear so inaudible must mean not able to hear.
    This is for other readers who have no Idea what inaudible meant .
    KArAudio.COM
    -Nick
    wesleysh's Avatar
    Apr 2002
    Michigan
    795
    it just means that any level under .10 can not be detected by hearing it, only testing it. You would not hear anymore harmonic distortion at .07 than you would at .00007.
    Mark_ab's Avatar
    Mark_ab is offline The Alpha Male
    Feb 2002
    Edmonton, Alberta
    31
    4,210
    I believe the audible THD is higher than that (0.1). Every piece of equipment in your system has some distortion, added together to get the total. HU, amp, eq's, xover's etc. I could be wrong.
    Is this not a reasonable place to park?
    wesleysh's Avatar
    Apr 2002
    Michigan
    795
    I think RC once said that in practice the number was 2% or so.
    I also remember it being ALL of your equipment added together, like you said. I just can't remember how much your amps THD rises when you bridge it or go 2 ohms. I think we don't know certain details about it Mark because its never been a factor for us, lol. It really only matters when your using many processors, equalizers and amps with high THD ratings. Or just one REALLY cheap amp pushed too hard.
    mr_unreal's Avatar
    mr_unreal is offline Junior Member
    Mar 2002
    Horsham, Victoria, Australia
    23
    When your amp is running at 2 ohms, instead to 4 ohms, your THD is said to double, but you also get twice as much power. THD is not always double, but it is always pretty close to it.
  9. #9
    Mar 2002
    Texas
    27
    111
    correct
  10. #10
    Jan 2002
    The XXX Lounge
    32
    4,477
    I believe THD over 1.0 is audible. I would have to look it up to be sure, but I know most of your class D amps are at or above 1.0.
  11. #11
    djjdnap's Avatar
    Mar 2002
    indy-nap-lis
    1,971
    thanks guys or whatever you r..
    KArAudio.COM
    -Nick
  12. #12
    taylor's Avatar
    taylor is offline THUNDER TUNES IS A FLAMER
    Jan 2002
    can
    30
    1,509
    2 Post(s)
    planet audio 1200d, thd. 0.33
  13. #13
    Jan 2002
    The XXX Lounge
    32
    4,477
    I said most. I think the 8100D is pretty high, I can't remember but I thought I saw 3.0 THD on one class D amp a while ago, I can't remember which one though.
  14. #14
    Jan 2002
    The XXX Lounge
    32
    4,477
    Okay I did some research..........THD below .10 is inaudible. So wes, you are right, I checked a few amps out some RF, MTX, Kicker, Sony, etc. and a few others and they were mostly around 1-2 THD. So if that planet audio 1200d is .33 Thd, that's pretty good compared to some of the other class D amps.
