Results 1 to 3 of 3
Reload Thread: MB quart 12" PWD with Chrome CAP!!!!
    Free_Style's Avatar
    Free_Style is offline Member
    May 2002
    Chicago
    63
    Ok guys this is first post and I think you in for it.
    WHAT I HAVE
    1. 98' Tahoe
    2. Eclipse Head Unit
    3. Phoenix Gold TI 575.4 running 2 sets of MB quart 6.5's
    4. Phoenix Gold TI 400.2 Running 1 12" PWD Quart Just got this
    5. 1 Farad cap
    6. Sealed RED TOP Battery 0 gauge wire.
    I already have door speakers set up and running. I need to set up the SUB, AMP, and CAP.
    1. Should I use the cap for both amps or Just the sub amp?
    2. Should I split the power wire with 2 blocks with 2 outlets or just 1 with 4 outlets?
    3. Can I tap into the singnal wire to turn on both amps?
    4. Should I ground the cap to the same spot under the rear seat were the 575.4 is grounded useing a block. Or sould I just ground the cap to the rear cargo area were the sub will be?
    5. The CAP instructions say don't use blocks with fuses. Just a fuse by the battery is this true?
    Hope you can help I will have pics soon. Thanks
    Free_Style's Avatar
    May 2002
    Chicago
    63
    Well I want to install today but I can't figure it out. HELP!!!
    Free_Style's Avatar
    May 2002
    Chicago
    63
    I have lit a joint and was sitting in my heated garage just thinking what this beast will sound like. Can't wait.
