+ Reply to Thread
Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 15 of 132
Reload Thread: Sundown U 15 facing up or forward?
    West1's Avatar
    West1 is offline Senior VIP Member
    Feb 2008
    Los Angeles,Ca
    330
    3 Post(s)
    129 Post(s)
    I am not happy with my x10 and I am going to try a Sundown U-15 D2.
    Currently my rear seats have been removed and the x10 is facing down with port towards driver. I've heard on multiple occasions that facing my sub down and port forward is not the best way to setup.
    I want a better kick and reading threads, 12"s and above give the best sound for subs.
    I plan to have the box custom built as I did with the x10.
    Soo...
    port and sub facing ceiling?
    Port and sub facing forward?
    Install will go into a Nissan Frontier Crew Cab
    XS D3400, 270 HO alt, Duracell G31, FSD 2600 and X10 (soon to be replaced).
    I don't have enough friends with my interest of subs so I am limited to hear different setups/sub brands.
    Tyvm
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is offline Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,667
    15 Post(s)
    2263 Post(s)
    Re: Sundown U 15 facing up or forward?
    What don't you like about the x10? What are the box specs-
    volume, port size and tuning?
    Hertz Mafia's Avatar
    Hertz Mafia is offline FEATHER RUFFLER
    Jul 2016
    Michigan
    2,152
    44 Post(s)
    1390 Post(s)
    Get a proper box for the x10 before switching if U ask me
    West1's Avatar
    Feb 2008
    Los Angeles,Ca
    330
    3 Post(s)
    129 Post(s)
    Quote Originally Posted by THATpurpleKUSH View Post
    I'll look for specs. I believe 1.5cu @32hz
    I love the lows it gives but some songs can't keep up with the faster beats. It does what it's designed to do, I just want a little more punch in beat.
    Quote Originally Posted by Hertz Mafia View Post
    I believe I did purchase a proper box. I've seen a lot of nice builds on FB from the builder Acoustical Design Inc.
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,086
    242 Post(s)
    7853 Post(s)
    Quote Originally Posted by West1 View Post
    that kick/punch is 50hz to 70hz response. Good luck getting any of that out of the X-10 if you have the megaroll surround version. Even with a different box, megarolls have sh*t upper end bandwidth.
    Most of the sundown nuthuggers will say "NO thats the range your door speakers need to cover!" i'll be like "motha ***** do you know how much cone area and power is needed to get midbass to keep up with 155+ db???"
    While its 1000x easier just to have a sub that can play that range and roll off to 80hz cleanly. Rather than a sub that drops dead in the water after 50hz.
    Unless you are going for pure lows, always choose the standard surround option over the megaroll surrounds when buying sundown subs.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  6. Likes hispls liked this post
  7. #6
    Jeffdachef's Avatar
    Feb 2013
    16,086
    242 Post(s)
    7853 Post(s)
    Soo...
    Tyvm
    Sub facing down port towards driver is a much less than optimal loading configuration.
    for trucks if the box is big and very close to the roof of the truck, sub up, port up. If its not close to the roof then sub forward port to the passenger side.
    If you get a 15, MAKE SURE you have the proper space to fully build a proper box for the sub. Hell, if you got rid of your seats, you should have a fk ton of room in that crew cab, do two SA 15s or 18s instead and say fk it, lets do it big... ONLY IF YOU HAVE the space, dont cram sh*t if it doesn't fit.
    BTW, you got your box from John the butcher? LOL. The his boxes performs but a lot of his work is shoddy in other installs.
  8. #7
    West1's Avatar
    Feb 2008
    Los Angeles,Ca
    330
    3 Post(s)
    129 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    As a noob, I've now learned to stick with the normal design. I considered 4 sa8 v3's but reading on 8's, they tend to be more loud with minimal lows. Hence the idea of one 15" U series for a more balanced sound.
    I actually thought of a pair of 15's but then that 1K will quickly turn into 2k for a bigger HO alt, amp and battery(s).
    I'm trying to capitalize on a sub(s) with the car power I'm working with (270 mechman, FSD amp and 2 batteries).
    I asked for sub down because I was trying to gut the rear seats and place the seating on top of the box in case the kids needed a ride. That did not work so now I have as much space as the door width allows.
    As for BoxBuilder, I was trying to wait for Cstang but I got impatient as he was working mad hrs for a good length of time.
    @THATpurpleKUSH looking back, all I see is 155cu @32hz.
  9. #8
    Jeffdachef's Avatar
    Feb 2013
    16,086
    242 Post(s)
    7853 Post(s)
    No, you dont see the efficiency of things. You have that FSD which is perfect for two SA 15s. You dont need a U 15. Two SA 15s will be louder than a U 15. You dont have to upgrade anything more. Two low powered 15s will be SIGNIFICANTLY louder than your single 10.
  10. #9
    West1's Avatar
    Feb 2008
    Los Angeles,Ca
    330
    3 Post(s)
    129 Post(s)
    Not sure I could fit a 6-7cu box through a door. I have the space but getting that in seems impossible.
    My rear seat floor is weird because of the spare tire and drive axel. I think 4cu would be biggest I can go while still able to use my rear view mirror and door space.
  11. #10
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline CHEAP A/F
    Jan 2017
    NC
    6,531
    18
    29 Post(s)
    2606 Post(s)
    friend has big truck with fu 1250 15 sub forward port up and it has bad cabin cancellation (a 10 in right box would be louder at least in his case) did same with 2-12" subs and port front.. like jeff said i'd say try port side and yeah the x is made for lows, i let my sub play up to 100hz.. so maybe side ported box with diff sub even 1 15 as long as box is big enough.. be great if u had friend with side port box let u try it in your truck
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit Ill sleep with you if you do that for me..
  12. Dislikes Boomin_tahoe disliked this post
  13. #11
    West1's Avatar
    Feb 2008
    Los Angeles,Ca
    330
    3 Post(s)
    129 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    I had a SD2 with side port prior to the X10. This might be a poor comparison but I did not hear a difference between side and fwd port. With that said, I posted to get feedback so I can get this **** done with one try haha.
    Hmmm... looking at SA site, the Zv3 12's are 2cu and the U series are to mimic Zv3 specs. I might try a pair of Zv3's or U series, then upgrade amp in a few months.
  14. #12
    Sep 2009
    5,667
    15 Post(s)
    2263 Post(s)
    1.5cf at 32hz is what sundown recommends. What Jeff said about the surround limiting the upper freq range is true, the overall bias of the x series is a strong low end which you might not be able to overcome. Using a smaller airspace might help with transient response, you could start with adding some damping material (1inch fiberglass insulation or polyfill) to the inside walls of the box or even add some temporary 2x4s to shrink the internal volume, though it will raise tuning slightly. Thats the easiest way to experiment without building a whole new box.
  15. #13
    West1's Avatar
    Feb 2008
    Los Angeles,Ca
    330
    3 Post(s)
    129 Post(s)
    I'll pass on that. I originally specified the U series because they are on sale @pre order prices. I might go with a pair of u 12 D4's.
    One thing I don't understand is port sizes. When I received my X10 box, I assumed I would have a 2x12 port (random number for visual idea) and instead I had a 2x2. I asked around and was told the port sounds about right for the box, tune blah blah.
    Are the large ports just visual or does it actually benefit the listener?
    Is there a preferred port type for low and loud?
  16. #14
    garychoffmann's Avatar
    garychoffmann is offline CarAudio.com Elite
    Mar 2011
    Missouri
    1,984
    6 Post(s)
    547 Post(s)
    2 inch by 2 inch? So a 4 square inch port?
  17. #15
    West1's Avatar
    Feb 2008
    Los Angeles,Ca
    330
    3 Post(s)
    129 Post(s)
    Quote Originally Posted by garychoffmann View Post
    Yes. Not 100% sure on port dimensions. I can measure later
+ Reply to Thread
