+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Reload Thread: Is this a good setup?
    raider89's Avatar
    raider89 is offline Member
    Nov 2009
    OH
    60
    32 Post(s)
    I have a 2015 Lancer.
    Stock speakers don't get loud at all, sound crappy and any bass just crackles and cant handle it.
    Here's what I have come up with so far.
    Infinity Kappa 60csx
    6-1/2" component speaker system in front and rear doors.
    Infinity KAPPAFOUR 125W x 4 Full Range Class D Amplifier
    Kenwood DDX374BT
    DVD receiver
    Anything else I should consider or recommendations ?
    Budget is $1000 for everything.
    moparnut's Avatar
    moparnut is offline Member
    Nov 2017
    Wagoner, OK
    132
    48 Post(s)
    Re: Is this a good setup?
    Are you wanting any kind of a sub for the low end?
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,189
    245 Post(s)
    7917 Post(s)
    Quote Originally Posted by raider89 View Post
    Kenwood DDX374BT
    DVD receiver
    If you dont plan on doing massive door treatments turning the doors into a proper speaker enclosure with proper custom baffle to redirect the sound wave into the car along with having a solution to absorb the rear wave, then I'd suggest you just swapping out the head unit and adding a subwoofer instead because unless you do a real legit install, aftermarkets will have way less bass and warmth in the vocals than stock speakers purely due to the install purposes Its not totally the stock speaker's fault, the stock head unit is the main culprit for overall sh*t sound since its only 3-5 watts a channel. Stock speakers on real power with a head unit to tune and process are a completely different beast.
    I'd highly recommend you getting a subwoofer setup and letting your door speakers play mid/midbass frequencies rather than trying to force door speakers to play actual bass. This will already help your speakers get much louder because they arent forced to do something they arent good at and can focus on doing their jobs better once you implement a high pass filter.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    raider89's Avatar
    Nov 2009
    OH
    60
    32 Post(s)
    Quote Originally Posted by moparnut View Post
    I am wanting to add a sub, if I have the extra funds I would just get this amp.
    Pioneer GM-D9605
    5-channel car amplifier — 75 watts RMS x 4 at 4 ohms + 600 watts RMS x 1 at 2 ohms
    Then like a single 10 or 12 inch sub like a JL Audio 10W3v3-2
    raider89's Avatar
    Nov 2009
    OH
    60
    32 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    Im not really looking for bass from the door speakers, and I didnt plan on doing any sound dampening, so the factory speakers will sound better and be loud with a better head unit that has more power output versus the stock head unit when the speakers start distorting and sounding like garbage when turning up the volume.
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,744
    17
    30 Post(s)
    2693 Post(s)
    Pioneer GM-D9605
    that amp better fine.. speakers need hp xover that'll help more than anything as far as stopping distortion and let sub make the bass.. u can get better sub same or less $ than jl.. u can also just replace front speakers run rears on hu or not at all (most of us don't use them) use a 4 channel amp for the fronts and bridge 2 channels to a sub.. u can use $ u save on rear speakers + spend less on sub and spend more on amp get more power to sub.. Sundown Audio SAE-1100.5 5 channel amplifier - EMF Car Audio formerly Sundown Only
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
    bigblank69's Avatar
    bigblank69 is online now CarAudio.com Elite
    Oct 2006
    Huntley, IL
    1,284
    45 Post(s)
    696 Post(s)
    Kenwood DDX374BT
    DVD receiver
    Could always just get a Infinity Ref 704A and a 551A... Those two combined would probably cost less than the K4. The K4 is a good amp... Also I would just get the Comps for the front speakers and get Coaxs for the rears
    Head Unit: Pioneer Avic-5201NEX
    Amplifiers: Orion XTR1000.4, Alphard DB-2000.1D
    Front Speakers: Infinity Perfect 600 Components
    Rear Speakers: Image Dynamics ID6.5
    Subwoofers: 2 JL Audio 12TW3-D4
    bigblank69's Avatar
    Oct 2006
    Huntley, IL
    1,284
    45 Post(s)
    696 Post(s)
    It depends on the Stock Head Unit/ Audio systems... Not many are only 3-5 watts anymore. Shoot some of them have pretty good wattage behind them.
  9. #9
    bigblank69's Avatar
    Oct 2006
    Huntley, IL
    1,284
    45 Post(s)
    696 Post(s)
    Will it sound better? Yes... Will it sound good? No. I disagree with Jeff, a set of components with an amplifier the sound will be cleaner than non amplified regardless of sound deadening. Adding in Sound Deadening would be a smart move, but I dont think should be the determining factor ... but no your not going have a lot of bass. That's why I recommend going down slightly on the amp output for the 4 channel, and adding a subwoofer.
    Infinity Ref704A and 551A = $200 shipped
    Capable HU <$350
    Wiring $100 roughly
    Subwoofer - $100-200
    Enclosure <$100
    Comps = $120-180
    Coaxs- <$90
    Total=<$1070-$1230
    You can save money on the HU and enclosure as well....
  10. #10
    raider89's Avatar
    Nov 2009
    OH
    60
    32 Post(s)
    Quote Originally Posted by bigblank69 View Post
    Will it sound better? Yes... Will it sound good? No. I disagree with Jeff, a set of component with an amplifier and the sound will be cleaner... but no your not going have a lot of bass. That's why I recommend going down slightly on the amp output for the 4 channel, and adding a subwoofer.
    Capable HU <$350
    Wiring $100 roughly
    Enclosure <$100
    Comps = $120-180
    Coaxs- <$90
    Total=<$1070-$1230
    Infinity Ref704A and 551A = 200
    Infinity Reference REF-6520Cx - Front - 120
    Infinity Reference REF-6522EX - Rear - 62
    Kenwood DDX374BT - HU 177
    Subs - 150
    Enclosure - 70
    Wiring - Already Have
    Do you have some recommendations on subs or sub that would be nice in that range little more than 150 is okay (That will work with that amp)
  11. #11
    bigblank69's Avatar
    Oct 2006
    Huntley, IL
    1,284
    45 Post(s)
    696 Post(s)
    Here are better comps for less money
    https://jet.com/product/detail/11814...RoC0swQAvD_BwE
    I have a set sitting around the house and they are good sounding and still a Harman product (Infinity Kappa is the same set.)
    For subs.. I mean it depends on what you want. At 600W Clean like that amp puts out, I think the FU300 would be a good fit, Also W3's are right there, Infinity Kappas sound good. Also you could look at Dayton HO DVCs. Those sound great and are right in that 150 range for a 12. Gramps cant wait to chime in and say the Pioneer 3003 for $80... At $150 the list could be endless
  12. #12
    Jan 2017
    NC
    6,744
    17
    30 Post(s)
    2693 Post(s)
    yes here i am., the pioneer 3003 is a great sub for less than 1k if u are going with 1 12 and u really need ported box.. everyone would say u need custom box if going ported but if u stick with the pioneer u can get 1 for $75 or less thats sounds great and port is big enough for the power u will have., mine was pretty loud in that box.. if u gonna get 2 subs it'll be hard to beat 2 fu 300's but idk how they sound sealed and dual ported box will cost more.. cheaper to get 1 12 and ported box and run all the power to 1 sub.. if u wanta stay sealed get the 1 dayton 12 like blank said they would in pretty small box, with 600rms maybe 1.25 cf would be good..
    2 ohms rule
  13. #13
    Jan 2017
    NC
    6,744
    17
    30 Post(s)
    2693 Post(s)
    that kenwood hu has hp xover like mine so leave factory rears just get nice 75rms-125x2 amp for fronts run rears off hu.. big blank just tested those amps he may still have them for sale but i'd look for 2 channel for fronts **** less power from alt, power just the speakers that matter..
    2 ohms rule
  14. #14
    Jeffdachef's Avatar
    Feb 2013
    16,189
    245 Post(s)
    7917 Post(s)
    Capable HU <$350
    Wiring $100 roughly
    Enclosure <$100
    Comps = $120-180
    Coaxs- <$90
    Total=<$1070-$1230
    it really depends, i've fixed too many bad setups to count where people said their stock setups sounded better. You are completely under valuing the sound treatment part. Literally makes the biggest difference when done right.
  15. #15
    bandit_kb's Avatar
    bandit_kb is offline Senior VIP Member
    Mar 2014
    austin,tx
    263
    1 Post(s)
    110 Post(s)
    Add 100-200 for basic sound deadener. At least do that
+ Reply to Thread
  1. Is this a good setup
    By twisted_clown02 in forum Amplifiers
    Last Post: 02-14-2005, 01:49 PM
  2. Is this a good setup
    By jmiller0526 in forum Subwoofers
    Last Post: 09-10-2004, 05:55 AM
  3. is this a good setup
    By jL_Audio in forum General Discussion
    Last Post: 03-15-2004, 10:27 PM
  4. is this a good setup?
    By lpman18 in forum General Discussion
    Last Post: 01-27-2004, 07:53 PM
  5. Is this a good setup?
    By Moocow16 in forum Wiring, Electrical and Installation Help
    Last Post: 10-06-2002, 12:43 PM
