Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: How do I hook up subs to my stock deck?
    slam32b's Avatar
    slam32b is offline Junior Member
    Jul 2004
    New York
    I have a stock bose cd player in my car. I can get a line out converter for the speakers in the car but what do I do for the output to the sub? Is there some type of controller I can buy to output a mono signal that can be adjust that goes to the subs amp?
    BIG_SUPERMAN72's Avatar
    BIG_SUPERMAN72 is offline mother humper
    Jan 2004
    Grand Rapids, Michigan, United States
    30
    2,078
    Re: How do I hook up subs to my stock deck?
    Do you have pre amp out lets? Red and white plug ins? Thats where u connect the RCA cables to the amp.
    99 Chevy Silverado 1500 ext cab
    22" Giovanni rims
    200 amp alt.
    Optima Yellow top in the cab
    Duralast under the hood
    3 other batts.
    Eclipse 3100
    Eclipse Comps. crossfire cfa202
    eclipse 6.75s rear + eclipse 4x6s alpine T-130
    (2) FI 15" BTLs 10cu/ft tuned to 32 hertzzzzzzz
    Massive D400x 5k @ 2 ohm
    Sorry if I make ur girlfriend wet, in advance.
    linksyz's Avatar
    linksyz is offline Senior VIP Member
    May 2004
    Jacksonville, FL
    32
    374
    Quote Originally Posted by BIG_SUPERMAN72
    My stock bose didnt have them, I doubt his either. Mine came out of '99 mazda 626
    2008 Nissan 350Z
    Alpine CDA-9887
    Focal 165 K2P
    DLS Iridium 10"
    Alpine PDX 4.150
    Alpine PDX 1.600
    slam32b's Avatar
    Jul 2004
    New York
    it doesnt have preamp outputs. You can buy a line out converter which converts the speaker wires into 4volt preamp RCA's, for the left and right channels. But how do you get a subwoofer output to control from the player?
    somekook's Avatar
    somekook is offline only 15"s
    Jul 2003
    Daytona Beach, FL
    30
    1,178
    if it doesnt have pre amp sub outlets, it probably doesnt have a subwoofer control....
    slam32b's Avatar
    Jul 2004
    New York
    but is there anything you can buy to hook it up and control it? Like they have a line out converter for the front and rear speakers. Do they have some type of converter that you can use for yuor subwoofer?
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    not that i'm aware of...
    slam32b's Avatar
    Jul 2004
    New York
    ok thanks, i guess im gonna have to go with a new deck
  9. #9
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Quote Originally Posted by slam32b
    Ummm.......all you need to do is use the lowpass crossover on your amp. You can run your subs off of the "front" RCA out on the convertor as long as somewhere down the line you lowpass the signal.
  10. #10
    slam32b's Avatar
    Jul 2004
    New York
    how do i low pass the signal?
  11. #11
    Unreal's Avatar
    Unreal is offline Senior VIP Member
    Oct 2003
    Tucson, AZ
    241
    Using the crossover on the amp like he said.
  12. #12
    Mar 2004
    MI
    35
    How would you do the remote wire? Do you have to take the ceck out and wire it in or is there a way to do it without taking the deck out?
  13. #13
    Apr 2004
    Atlanta, Ga
    119
    does low pass prevent Low frequencies from going to the subs if you use the "Front" like he said?
  14. #14
    Mar 2004
    MI
    35
    Low pass says to subs "Play everything from this frequency and lower"
    High pass says to subs "Play everything from this frequency and higher"
    So low pass prevents highs and High pass prevents lows from going to your speakers.
  15. #15
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Quote Originally Posted by sudrummerboy
    No, a lowpass prevents frequencies above the crossover point from going to the sub. It doesn't matter where the signal originates from (Front output, Rear output, Sub output), it will take whatever signals it receives and attenuate the frequencies above the crossover frequency.
  1. Help Picking Subs...etc
    By 63novawagon in forum Subwoofers
    Last Post: 06-29-2004, 01:36 PM
  2. need help on subs
    By phycophonetech in forum Amplifiers
    Last Post: 05-09-2004, 12:51 AM
  3. Inverted Subs? Subs Facing each other? Why?
    By sungwei in forum General Discussion
    Last Post: 05-02-2004, 06:57 PM
  4. SPL brand name subs any good?
    By maniackilla in forum Subwoofers
    Last Post: 01-15-2004, 09:38 PM
