+ Reply to Thread
Results 1 to 12 of 12
Reload Thread: My box meters the same forwards and backwards, why?
    JonM's Avatar
    JonM is offline Member
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    I went to a Meca comp and had my car metered. I have a 99 camery. The subs used to face the tail lights and now they face into the car. With the 6x9s installed it meters at 145.1 with them removed it meters at 145.5, with the box facing forward instead of toward the tail lights it meters at 145.5. With the back seat down the sound pressure is easily twice as much. Why does it meter exactly the same, weather it's forwards or backwards? I thought it'd meter higher with more sound pressure.
    Kenwood 6702s
    Fosgate component 6.5s T2652-s front/T1693 6x9s rear
    Ohio generator 300amp alt
    2 XS power 3100d
    1 run 4 OTT and 1 run 4 gauge OFC power
    HCCA 8000.1 sub amp. audiopipe 2004 mids and highs
    2 dual ohm 12" 2,500 watt HCCAs
    Custom box tuned to 36 hertz
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline NOT TO OLD TO BASS
    Jan 2017
    NC
    4,705
    17
    23 Post(s)
    1904 Post(s)
    Re: My box meters the same forwards and backwards, why?
    normally louder to rear.. removing rear deck speaker allow more bass into car.. either way u lucky as he*l i want to do smaller box but i want wider 1 so i can try firing forward even though i'm 90% sure forward won't work.. is your box as wide as back seats?, is port on side or on front like sub?
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt... FU 750 destroying my spoiler https://www.youtube.com/watch?v=joeeCIZJpUs pioneer 3003 videos https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is offline Smoke weed everyday
    Sep 2009
    twenty past four
    4,610
    3 Post(s)
    1776 Post(s)
    Did you do the 145 with the equipment in your sig?
    Jcsaudio's Avatar
    Jcsaudio is offline Member
    Sep 2017
    Worcester, MA
    123
    1 Post(s)
    63 Post(s)
    Probably because the amplitude of the sound wave or phase is about the same with each subwoofer position you tried. It may be lower with the 6x9 playing because the bass frequencies may be slightly out of phase with each other slightly canceling out each other.
    Try this article about box positioning and phase. Positioning a woofer box in a car trunk - bass cancelation - Houston TX
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,590
    15
    35 Post(s)
    3800 Post(s)
    Are you certain you were using the optimum frequency each time? Peak frequency should be different firing forward or back.
    kr15's Avatar
    kr15 is online now Polluting Residentials
    Feb 2010
    California
    5,772
    18 Post(s)
    1226 Post(s)
    ^that... my saturn peaked 51 firing back, and about 43-45 firing forward
    Team Flex Issues
    JVF Customz
    REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    The box is as wide as the backseats, the port is I between the two subs firing forward. The box takes up my entire trunk
    Kenwood 6702s
    2 XS power 3100d
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Yes, all 3 tests were done with the equipment in my sig.
    Kenwood 6702s
    2 XS power 3100d
  9. #9
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    12,023
    66 Post(s)
    2 Thread(s)
    4929 Post(s)
    Quote Originally Posted by JonM View Post
    thats 145 at the head rest correct? that's not terrible but Id definitely keep it facing inside and seal it off. head rest peaks much lower and can be hard to pressurize since your pretty much pressuring the entire cabin at that point. i prefer mecca because its WHAT YOU HEAR not on the dash.
    i've heard cars do 160 dash and **** at the head rest. i'm doing about 2db down from you at the head rest with half the power so you aren't doing terrible.
    these clowns think the dash is a measure of how loud it sounds. lol
    Insidious Audio
  10. #10
    JonM's Avatar
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    Quote Originally Posted by Papermaker85 View Post
    I didn't think about that. The first meter was at the kick panel at Meca and the second I think was at the headrest. My amp clamps at around 3,200 watts. I'm going to upgrade to a coupl HCCA SPL 15s or ZV5s and see if I can get the box rebuilt because facing it forward makes a lot of bass in rock songs sound hollowed out. I also have a lot of power I don't use and it bumps me up a class I think.
    Kenwood 6702s
    2 XS power 3100d
  11. #11
    tymoto21's Avatar
    tymoto21 is online now CarAudio.com Elite
    Apr 2008
    wisconsin
    841
    1 Post(s)
    204 Post(s)
    Kick scores are generally much higher than headrest
    If you re tune you could gain a good bit
    I don't see anyway you are fitting two of those 15" hccas they like larger boxes
  12. #12
    Dec 2006
    New orleans LA
    32
    12,023
    66 Post(s)
    2 Thread(s)
    4929 Post(s)
    my headrest score is 3db off kick.. kick is 52hz headrest is 38hz. box back for kick forward for dash and headrest.
    Insidious Audio
  13. Likes JonM liked this post
+ Reply to Thread
  1. How far to put my box from the hatch?
    By tohighpsi in forum General Discussion
    Last Post: 12-18-2006, 06:36 PM
  2. Is it wrong to build a box with subs firing forward and ports up?
    By supraman1379 in forum Enclosure Design & Construction Help
    Last Post: 07-12-2006, 10:15 PM
  3. Just got my box in the mai(attempt 2)
    By Jayhawkk in forum General Discussion
    Last Post: 06-29-2005, 01:09 AM
  4. Help me secure my box in the hatchback, its scary!!
    By loudfivepoint0 in forum Wiring, Electrical and Installation Help
    Last Post: 03-31-2005, 03:43 PM
  5. Should my box face the tail lights or the seats?
    By adamawayfrommpa in forum Subwoofers
    Last Post: 04-16-2002, 11:35 PM
