+ Reply to Thread
Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 15 of 127
Reload Thread: Can anyone help me find a good grounding spot?
    ekah's Avatar
    ekah is offline Senior VIP Member
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
    For a 2006 mazda 6 hatch?
    Can I use seat belt bolt downs as my 2 grounds for both amps?
    wew lad's Avatar
    wew lad is offline wew lad inc
    Mar 2015
    Des Moines, IA
    5,308
    50 Post(s)
    2847 Post(s)
    Re: Can anyone help me find a good grounding spot?
    anything over 2kw id run dedicated grounds
    Quote Originally Posted by JohnKuthe View Post
    I AM The Future of personal transportation, NOW!!
    Quote Originally Posted by Loudz View Post
    Pretty sure everyone on this site hates you (@JohnKuthe) more then me and that's very hard to accomplish.
  3. Likes tc300 liked this post
  4. #3
    ekah's Avatar
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
    Quote Originally Posted by wew lad View Post
    Cab1600 so under 2k. So this spot ain't good? I was using spare tire well but it ain't cutting It
    Sent from my SM-G935T using Tapatalk
  5. #4
    wew lad's Avatar
    Mar 2015
    Des Moines, IA
    5,308
    50 Post(s)
    2847 Post(s)
    Quote Originally Posted by ekah View Post
    the cab1600 takes a good amount of current, if your car is not ideal for running chassis ground id run dedicated grounds.
    did you read my post about checking voltages? a lot of us dont like helping if you dont do some testing yourself
  6. Thanks Souldrop thanked for this post
  7. #5
    ekah's Avatar
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
    I'm checking different grounds just because the last spot it's not securely bolt down like you can move the wire a bit if you put enough force. When youbguys say check voltage do you mean use my dmm and put it in with the power and ground from the amp and see if it's getting 13 or more?
  8. #6
    ekah's Avatar
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
  9. #7
    los33's Avatar
    los33 is offline Car Audio G
    Apr 2014
    Houston, TX
    3,524
    29 Post(s)
    2249 Post(s)
    Find where the frame touches the body where the hatch is and use a long self tapper for a ground
    Sent from my N9560 using Tapatalk
  10. #8
    ekah's Avatar
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
    Quote Originally Posted by los33 View Post
    Going home depot now to find some self talking bolts.
  11. #9
    Hertz Mafia's Avatar
    Hertz Mafia is offline FEATHER RUFFLER
    Jul 2016
    Michigan
    2,109
    42 Post(s)
    1360 Post(s)
    Self tapping screws are not a good ground
  12. #10
    los33's Avatar
    Apr 2014
    Houston, TX
    3,524
    29 Post(s)
    2249 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    For what his power it shouldn't be an issue so long as it is staright to the frame.
    He will lose .01 volts from the metal on the screw.
  13. #11
    ekah's Avatar
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
    I fixed the ground to where it's hard as **** to move and it seems to fix the problem so far. For checking the voltage do I just put my dmm on 20v then positive to positive and negative to negative from the amp while playing heavy bass music and see if it dips?
  14. #12
    ekah's Avatar
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
    I found a new ground but it did the same thing using bluetooth spotify. I then turned to my CD and it seems to play high volumes fine. My gains are set at quarter. Should I lower it? Is there a difference when using bluetooth and cd or something?
  15. #13
    los33's Avatar
    Apr 2014
    Houston, TX
    3,524
    29 Post(s)
    2249 Post(s)
    CD is playing max volume via set gains.
    Bluetooth adds more gain when you turn it up from your phone. Redo your gain on the amp playing via bluetooth.
    Unless you have a gain control on your hu
  16. #14
    ekah's Avatar
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
    Only thing I have on the headunit is the speaker level for all speakers including subwoofer but the subwoofer is at 0. I didn't know about the whole gain level thing via Bluetooth and cd player but weird thing is when I play music on CD the bass is a lot more louder etc compared to bluetooth and it only shuts off with music from bluetooth unless it's coincidence or something. If anything I just looked behind my hu to see it anything was out of the loop like the ground or the rca were touching metal or anything of the sort and it's fine so I'm really leaning towards it has to be my battery but when I use my dmm on my battery it's at 13v and my amp is playing 13 unless I turn it loud then it drops to 12.
  17. #15
    ekah's Avatar
    Mar 2015
    hawaii
    309
    2 Post(s)
    154 Post(s)
    The rca and speaker wire is in the right place right?
+ Reply to Thread
  1. Replies: 0
    Last Post: 11-09-2009, 10:59 AM
  2. Can anyone help me find a manual for this amp?
    By doomsayer in forum Amplifiers
    Last Post: 07-25-2009, 07:57 PM
