+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: Just blew my head unit, speaker impedance or wiring issues?
    thechoochyman's Avatar
    thechoochyman is offline Junior Member
    Jul 2017
    Central KY
    7 Post(s)
    Hey there, first post here. I finally decided to reach out to a group of audio-specific guys rather than my normal Volkswagen folks. I've been having weird problems with this system ever since I got the car.
    In May 2015 I bought my 1997 Volkswagen Passat TDI. The audio sounded terrible, so thinking it was the head unit I swapped out the stock unit with a Sony CDX-GT550UI I already had. Sound was still terrible - turns out all the speakers were blown.
    Next thing I did was replace just the front speakers with a pair of JBL GTO628s. On their website and on Amazon these were listed as 4 ohm speakers (stock value), but according to the spec sheet have a nominal impedance of 2 ohms. For what it's worth, the speakers ohm out at 3.1 when I check them with a voltmeter.
    Immediately after installing these speakers the difference was incredible. The bass was great, and I was highly impressed. Over the following year it seemed like the radio was responding worse and worse. I had the bass cranked up all the way and it wasn't nearly as good as it was in the beginning. The buttons on the face eventually quit working and I had to replace it.
    In June 2016 I bought and installed a Kenwood HD262U. Again, bass response was back to about where it was and all was great. Just yesterday I was driving home when I heard a loud pop out of the left speaker, and the radio gave me a "wiring short" error message. After cycling the power a couple of times and checking the door connection, it finally said "protect mode" and now it won't do anything. It will not let me reset it.
    Earlier today I pulled the Kenwood out of my wife's car and it worked great in mine. So great, in fact, once more I noticed that the bass was back to where it should be. Obviously there isn't a short in my speakers. I double-checked them to make sure they weren't wired backwards, and I had it right to begin with.
    I always faded my audio all the way to the front so it wasn't pushing power through the rear speakers. I have not upgraded the wiring at all, and I really do not want to install an amp. The sound would break up on relatively low volumes. Am I just using junky head units, is my speaker impedance too low, or is it being starved for power?
    youdoofus's Avatar
    youdoofus is offline Well, hello Mr.Fancypants
    Dec 2014
    the void of space called the midwest
    1,976
    5 Post(s)
    876 Post(s)
    Re: Just blew my head unit, speaker impedance or wiring issues?
    Quote Originally Posted by thechoochyman View Post
    does it have the monsoon sound system as stock? what imp do the speakers read at rest? and yeah, you might have purchased a monday/friday unit (meaning that it was put together under the stress of a hangover (monday) or the rush to go start the makings of a hangover (friday) )
    2002 Honda Accord sedan V6 (automatic slushbox)
    2 Rockford p3 12s (dual 2 ohm)
    Pioneer AVH-2300NEX
    2 PPI PC275's running 1 sub each atm, waiting to put the SQ 2200.1 back in and add the PhoenixGold Elite.4 once my electrical is up to snuff
    Stock front and rears (theyre actually squirrels listening to headphones that ive trained to sing what theyre hearing)
    I just added 5 SoundQubed stickers, and despite having no equipment upgrades, it added 76 DB!!!
    Jul 2017
    Central KY
    7 Post(s)
    Never heard of Monsoon before, but there is no external amplifier built in, if that's what you're wondering.
    At rest, the JBLs pull about 3.1. The rears 4.1ish.
    I did go ahead and order two pairs of these guys yesterday. Supposed to be here tomorrow. Everything I'm reading says they really are supposed to be 4-ohm speakers, not whatever those JBLs were doing. I also ordered another identical head unit, considering it was only $66 this time around and I can use my old harness. Another thing I'm planning on doing is running at least a 10ga wire to the harness straight off the battery (fused, of course). That's actually what I did in my wife's car when I bought it due to thinking it was shorted out somewhere. Maybe that's why it's lasted so long.
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,831
    235 Post(s)
    7701 Post(s)
    simple solution. add an amp. done deal.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    youdoofus's Avatar
    Dec 2014
    1,976
    5 Post(s)
    876 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    Jeff has a point
    Pioneer AVH-2300NEX
    Jul 2017
    Central KY
    7 Post(s)
    Since I'm rather vulnerable at the moment... can you guys make suggestions for a quality unit? Maybe even one I can add a sub to later. Like to keep it under $100 if possible.
    youdoofus's Avatar
    Dec 2014
    1,976
    5 Post(s)
    876 Post(s)
    quality and under $100, thats gonna be tough man.
    Pioneer AVH-2300NEX
    Jul 2017
    Central KY
    7 Post(s)
    Quote Originally Posted by youdoofus View Post
    Very well - a quality unit that meets my criteria at minimum expense.
  9. #9
    youdoofus's Avatar
    Dec 2014
    1,976
    5 Post(s)
    876 Post(s)
    this doesnt look like a terrible option
    https://www.amazon.com/Pioneer-DEH-X...dp_ob_image_ce
    fairly basic, but should get the job done. What do you think about this one @Jeffdachef ?
    Pioneer AVH-2300NEX
  10. #10
    Jul 2017
    Central KY
    7 Post(s)
    I was referring to an external amp - I already ordered another head unit. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  11. #11
    youdoofus's Avatar
    Dec 2014
    1,976
    5 Post(s)
    876 Post(s)
    that should do the trick for a pair of fronts
    https://www.amazon.com/Rockford-Fosg...hannel+car+amp
    Pioneer AVH-2300NEX
  12. #12
    Jul 2017
    Central KY
    7 Post(s)
    ...I did go ahead and order two pairs of these guys yesterday. Supposed to be here tomorrow. Everything I'm reading says they really are supposed to be 4-ohm speakers, not whatever those JBLs were doing.
    Looks like it would work, but fortunately I'm going back to all four speakers this time around.
  13. #13
    youdoofus's Avatar
    Dec 2014
    1,976
    5 Post(s)
    876 Post(s)
    oh yeah, my bad. This guy should work then. I was thinking of the part where you said that you fade to the front
    Pioneer AVH-2300NEX
  14. #14
    Jeffdachef's Avatar
    Feb 2013
    15,831
    235 Post(s)
    7701 Post(s)
    thats a horribly crappy unit. Dont expect good sound out of it.
  15. #15
    Jul 2017
    Central KY
    7 Post(s)
    What makes you say that? Both my previous Kenwood units have sounded great. Have a better recommendation?
+ Reply to Thread
  1. Can my head unit remote-turn-on wire service both power amp and power antenna?
    By Chisei in forum Wiring, Electrical and Installation Help
    Last Post: 09-29-2012, 11:15 AM
  2. Is my head unit wearing out or is there another explanation?
    By noms78 in forum General Discussion
    Last Post: 09-19-2011, 10:05 PM
  3. Did I just fry my head unit??!!
    By focused313 in forum Wiring, Electrical and Installation Help
    Last Post: 06-01-2011, 07:56 PM
  4. Speakers and/or head unit not working properly (wiring issue?)
    By jpinkston in forum Wiring, Electrical and Installation Help
    Last Post: 10-14-2009, 06:17 PM
  5. I think I blew my head unit...Help please
    By s5pitfire in forum Wiring, Electrical and Installation Help
    Last Post: 08-09-2007, 06:17 PM
