+ Reply to Thread
Page 5 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 61 to 75 of 265
Reload Thread: Skar EVL 18 VS. SSA ICON
  1. #61
    shredder1's Avatar
    shredder1 is online now CarAudio.com Elite
    Dec 2013
    Phoenix, AZ
    1,559
    20 Post(s)
    718 Post(s)
    Re: Skar EVL 18 VS. SSA ICON
    Quote Originally Posted by LosissaTool View Post
    A flat curve is NEVER FLAT.
    I highly recommend a +3 bump atound 35hz in a smaller truck with 10% more port area and a slightly larger box.
    In a larger car or suv. A slighy smaller box with a higher tune 38 or so give you a peak from around 50 to 60 and the larger cabin aids the sligtly faster roll off of the higher tuning smaller box with its natural trasnfer function..
    For spl its just the oppsite. Large box lower tune in larger cabins tune lower 33. Or so just enought port area for vent match..
    For walls/trucks small box HUGE port tuned no lwerr than 37.
    You mean to tune for SPL that is to tune lower than 33 hz in a large cabin?.. I always thought that for SPL you want to tune around cabin resonance and keep it smallish if you can to improve power handling?
  2. #62
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    1,514
    27 Post(s)
    924 Post(s)
    Quote Originally Posted by yahhhyahhh View Post
    That adequate for 2 18s correct ? And I'm getting it built tbh by a bodybuilder and u recommend building on top of the wheelwell?
    Kenwood X301& Sundown E-15 v3 5.8 CF Ported @34hz on PPI ICE2600
    No u have the wood at .75" and for two 18s u should have doubled every wall so 1.5" and that will take up space. I think u should build a new box for your 15s u have... put those 15s in a 9cubed box and they will come alive... that 5.8cube box u have now is suffocating them
  3. #63
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    11,473
    58 Post(s)
    2 Thread(s)
    4713 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    it looks even WORSE lmao.
    **** im sick today. Qes drops and qms rises.
    Sorry. its pretty nasty once things heat up.
    Now you know why a lot of sound q drivers have a lower fs.
    Insidious Audio
  4. #64
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    14,422
    192 Post(s)
    6823 Post(s)
    Now you know whu alot of sound q driver have a lower fs.
    still looks bad.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  5. #65
    Dec 2006
    New orleans LA
    32
    11,473
    58 Post(s)
    2 Thread(s)
    4713 Post(s)
    Quote Originally Posted by shredder1 View Post
    Larger cabins peak lower. The better the cabin is sealed the higher the res.
    For example. Tahoe stock with typical 4 15 stock install typically peak between 34 and 38. So lets say you reinforce the roof floor and deaden the roof and seal up the leaks in the cadin. This increases the acoustical dampening, lowers airspace and shrinks the cabin. SO Ihe air is denser and stiffer and resonates higher and has less pressure losses to the atmosphere.
    Think about it like this. Say you build a box And put it in a much larger box. The much larger box leaked and you sealed the whole thing really well. Now less pressure cannot escape creating more compression over that volume of air..
    Sorry about the terrible grammar i was feeling almost bad enough to check into the ER.
    Insidious Audio
  6. #66
    Dec 2006
    New orleans LA
    32
    11,473
    58 Post(s)
    2 Thread(s)
    4713 Post(s)
    still looks bad.
    Thats my point though bud. Retune. Larger box and tune lower..
    Insidious Audio
  7. #67
    Jul 2016
    Michigan
    1,514
    27 Post(s)
    924 Post(s)
    So much bullfvck in this thread. It's crazy.
  8. Likes Slo_Ride liked this post
  9. #68
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,559
    20 Post(s)
    718 Post(s)
    AH... I see... then I guess I'm tuned OK and that is why it gets so rowdy inside! Roof is sealed/deadened the doors are sealed/deadened but need to get rid of roof flex to really to maximize the cabin pressure?
  10. #69
    Dec 2006
    New orleans LA
    32
    11,473
    58 Post(s)
    2 Thread(s)
    4713 Post(s)
    Type in these parameters
    Qes .71
    Qts.62
    Fs 28.8
    vas 62
    Re 1.1ohm
    Qms 4.8
    Mms 368grams
    Xmax 32mm
    Xmag 50mm
    Xsus 44mm
    Now do 4.5 tuned to 34..
    Insidious Audio
  11. #70
    Dec 2006
    New orleans LA
    32
    11,473
    58 Post(s)
    2 Thread(s)
    4713 Post(s)
    Yes
    Insidious Audio
  12. #71
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    1,559
    20 Post(s)
    718 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    I'm just tryin' to learn... Had a stroke, can't work and love them lows!
  13. #72
    Dec 2006
    New orleans LA
    32
    11,473
    58 Post(s)
    2 Thread(s)
    4713 Post(s)
    Oh yea. Its 350f not kelven hehe
    Insidious Audio
  14. #73
    Dec 2006
    New orleans LA
    32
    11,473
    58 Post(s)
    2 Thread(s)
    4713 Post(s)
    In my car its nearly flat down to 34 and to 60 street beats a 143 on the dash and is probably the best sounding driver ive heard to date.
    Insidious Audio
  15. #74
    Jul 2016
    Michigan
    1,514
    27 Post(s)
    924 Post(s)
    Your car sounds like dlck hole! There was a SQ show that the real losisatool told you about close to you and u didn't even go. You never put your money where your mouth is!!! Your allllll talk
  16. Thanks Slo_Ride thanked for this post
  17. #75
    Jeffdachef's Avatar
    Feb 2013
    14,422
    192 Post(s)
    6823 Post(s)
    depends. to be honest. Hunter martin's 6th order gained when he took off his 45s and also gained half a db taking off several pole bracing. A good amount of people lost output after deadening while a good amount gained so you really dont know what to expect.
+ Reply to Thread
  1. idmax vs. ssa icon
    By shutmdown in forum Subwoofers
    Last Post: 12-11-2008, 04:26 PM
  2. Arc Flatline vs SSA ICON
    By dftnz7 in forum Subwoofers
    Last Post: 09-03-2008, 01:38 AM
  3. AQ HDC315 VS RE SX vs SSA ICON pair of 15"
    By eskimochaos in forum Subwoofers
    Last Post: 07-02-2008, 12:54 AM
  4. FI Q 15 vs. SSA ICON 15
    By dakotap in forum Subwoofers
    Last Post: 06-02-2008, 07:41 PM
  5. DC sound Level 4 10" vs. SSA icon 10"
    By blimblam in forum Subwoofers
    Last Post: 04-02-2008, 04:39 PM
