+ Reply to Thread
Page 3 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 31 to 45 of 265
Reload Thread: Skar EVL 18 VS. SSA ICON
  1. #31
    shredder1's Avatar
    shredder1 is online now Senior VIP Member
    Dec 2013
    Phoenix, AZ
    406
    2 Post(s)
    197 Post(s)
    Re: Skar EVL 18 VS. SSA ICON
    You'd think that on the 18 there would be a heavier coil/motor... do all manufacturers do this? I mean the 10's look to have the same motor as the 18's... It would seem that more cone= more mass and a stronger motor is needed... unless box size can compensate?
  2. #32
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    13,108
    129 Post(s)
    5995 Post(s)
    Quote Originally Posted by shredder1 View Post
    more mass affects efficiency however the cone area gained negates all that. You might get a lower FS which can help if you are doing a T line enclosure.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  3. #33
    LosissaTool's Avatar
    LosissaTool is online now DD subs are the best!
    Dec 2006
    Pensacola, Florida
    31
    10,017
    51 Post(s)
    2 Thread(s)
    3984 Post(s)
    You are asking the right questions.. lol
    Fuck you papermaker
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    I'm an expert because I work in a factory!
  4. #34
    Dec 2006
    Pensacola, Florida
    31
    10,017
    51 Post(s)
    2 Thread(s)
    3984 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    Rear air velocity numbers requires knowledge of how much actual power you are getting. inputing in an 8000 watt amp will require more port area than 4000 watts however you dont know how much you are clamping and what kind of rise you are getting so you are just left to guestimate on the input power and the amount of port area you need to not have compression/noise. Port per cube numbers are mostly in line with rear air velocity from all the winisd data i've ran its a reliable enough rule of thumb to get you under 30 meters per second.
    Its pretty typical to get 1.75x to 2.25x the rise. If you do this you will be close enough.. if you are getting anymore tn that aafter 4hz off tuning you simply have a shiity high reactive load and should isolate the inductors or build better speakers.. lol..
    Fuck you papermaker
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  5. #35
    Dec 2006
    Pensacola, Florida
    31
    10,017
    51 Post(s)
    2 Thread(s)
    3984 Post(s)
    Fuck you papermaker
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  6. #36
    Dec 2006
    Pensacola, Florida
    31
    10,017
    51 Post(s)
    2 Thread(s)
    3984 Post(s)
    Jeff dont take it was me trying to correct you.
    Im just telling you theory and from experience.
    This is what i was referring to as far as the 15ks as well as this subject as well.
    This different frequency prohibits our expression of power in an AC circuit using the same complex (rectangular or polar) notation as used for voltage, current, and impedance, because this form of mathematical symbolism implies unchanging phase relationships. When frequencies are not the same, phase relationships constantly change.
    Fuck you papermaker
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  7. #37
    yahhhyahhh's Avatar
    yahhhyahhh is online now Senior VIP Member
    Feb 2017
    Miami, Florida
    152
    3 Post(s)
    90 Post(s)
    I did worry about that... the site says 24 in2 each but that 81 in2 for 2 sure looks like a hole in the box... http://i.imgur.com/BgrwbZT.jpg ... any bigger and I was told it would be peaky... I'd love to learn to use winisd... I tried to download it tonight and the program I got wouldn't let me exit!! Maybe I'll keep trying to learn torres and one day I'll get it! I am still trying to learn...
    What size box width, and height?
    Kenwood X301& Sundown E-15 v3 5.8 CF Ported @34hz on PPI ICE2600
  8. #38
    yahhhyahhh's Avatar
    Feb 2017
    Miami, Florida
    152
    3 Post(s)
    90 Post(s)
    This is the amount of space I'm working with do you think I can put a 13 cf box back there anyone?
  9. #39
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    406
    2 Post(s)
    197 Post(s)
    Quote Originally Posted by yahhhyahhh View Post
    It looks feasible with about 12ft3 and that will leave 3ft3 for port displacement. I'm just using the open area measurements... LOL!.. I'm not going to get into using all the nooks and crannies or above the wheelwells but I'm sure it can be done. Man... I've done similar boxes before but halfway through I wished I'd just paid someone else to do it!..LOL!.. of course that would be port/subs up at 12ft3 net. That's at the window line maybe an inch above it.
  10. #40
    Jeffdachef's Avatar
    Feb 2013
    13,108
    129 Post(s)
    5995 Post(s)
    Fits but it will be above the windowline. If you can build around the wheel wells, you'll get more airspace and will be able to keep under the window line.
  11. #41
    yahhhyahhh's Avatar
    Feb 2017
    Miami, Florida
    152
    3 Post(s)
    90 Post(s)
    Do you think I can fit 2 18s and also keep the box below seats or would I have to bring it above seats. This is current box it's 5.8cf
  12. #42
    yahhhyahhh's Avatar
    Feb 2017
    Miami, Florida
    152
    3 Post(s)
    90 Post(s)
    That adequate for 2 18s correct ? And I'm getting it built tbh by a bodybuilder and u recommend building on top of the wheelwell?
  13. #43
    Jeffdachef's Avatar
    Feb 2013
    13,108
    129 Post(s)
    5995 Post(s)
    actually what sub are you going with? Letting you know that the skar evl 18s work better in sealed or 4th order bandpass enclosures. In order for the skar to really shine it needs 8 to 10 cubic feet per 18 once i ran up the specs and modeled it out. That box design down below fits an Icon more.
  14. #44
    shredder1's Avatar
    Dec 2013
    Phoenix, AZ
    406
    2 Post(s)
    197 Post(s)
    At this point I am stepping back... I don't use the same program as others... I use this... Port Length Calculator ... I know a 12 ft3 will fit... but if your looking for exact numbers let someone with better software help. At 12ft3... yes, it should be at seat height.
  15. #45
    yahhhyahhh's Avatar
    Feb 2017
    Miami, Florida
    152
    3 Post(s)
    90 Post(s)
    I was thinking the skar evl 18 because of the price fits my range and i don't have to wait 4 months to receive them
+ Reply to Thread
  1. idmax vs. ssa icon
    By shutmdown in forum Subwoofers
    Last Post: 12-11-2008, 03:26 PM
  2. Arc Flatline vs SSA ICON
    By dftnz7 in forum Subwoofers
    Last Post: 09-03-2008, 12:38 AM
  3. AQ HDC315 VS RE SX vs SSA ICON pair of 15"
    By eskimochaos in forum Subwoofers
    Last Post: 07-01-2008, 11:54 PM
  4. FI Q 15 vs. SSA ICON 15
    By dakotap in forum Subwoofers
    Last Post: 06-02-2008, 06:41 PM
  5. DC sound Level 4 10" vs. SSA icon 10"
    By blimblam in forum Subwoofers
    Last Post: 04-02-2008, 03:39 PM
