Results 1 to 6 of 6
Reload Thread: Rebuilding subs with nasty coil gaps
    Popwarhomie's Avatar
    Popwarhomie is online now Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,294
    64 Post(s)
    2461 Post(s)
    I have 3 AA 3.0 motors that I'm building to 12" subs for a buddy. The gaps are nasty with rust and metal shavings. What is the best way to go about cleaning them out? Air compressor did not work..
    Thinking pressure washer and then WD40 to make sure it doesn't rust.
    Turning into a huge PITA...
    2016 Focus ST - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by XxAndreaxX View Post
    too many freq at once, burn the coil, we all know, over 40-50hz, its all coilburning material.
    kcr357's Avatar
    kcr357 is online now Senior VIP Member
    Aug 2012
    ft laud
    328
    1 Post(s)
    126 Post(s)
    Re: Rebuilding subs with nasty coil gaps
    Ive used vinegar to clean up corroded jet ski parts, not sure if there's anything on a motor that would react poorly tho.
    Sold to
    Bought from
    NinjaBass
    FasFocus00
    "If I was so worried about resistance I'd be unplugging the factory wiring harness, and checking resistance on every wire in my vehicle."
    The_Grimy_One's Avatar
    The_Grimy_One is offline CarAudio.com Veteran
    Apr 2011
    Phoenix, AZ
    4,237
    1 Post(s)
    565 Post(s)
    Best bet is to get some strong tape. Fold it onto itself and run it around the gap. Do this several times. I'm sure there are other (better) methods as well.
    Deck: Pioneer 6900UB
    Highs: Pioneer TS-D1730C, Focal OEM Mids (Clarion NX-3410)
    Sub Stage: None (Sony ES XM-6001GXD)
    Bought From: ge_off_me, Boomsday, Chemmins, impactas, Sleazebagger, NoPh33rRaCiNg, fasfocus00, 50cents, flastrongman, pborcich, ace_800, GAMEOVERCCA, Ciaonzo
    Sold To: Jamesmington, Juicee, Bunkrd you, Donnie Darko, ge_off_me, destined2race, todd131, Imjtnotu, mclerico83, aimology, Audiobahn, kpetree, Souldrop
    Traded With: ge_off_me, Imtjnotu, 04lariat
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,184
    15
    38 Post(s)
    4187 Post(s)
    Quote Originally Posted by The_Grimy_One View Post
    Tape works for me, Might need to uses some sandpaper first if it's actually rusted,
    Slo_Ride's Avatar
    Slo_Ride is online now Take It Easy
    Oct 2005
    Atlanta
    13,381
    35 Post(s)
    3260 Post(s)
    Most people are gonna say tape to remove the shavings. Then I'd hit it with some fine grit sand paper, then blast it with the pressure washer, then hit it with the air compressor to make sure it's completely dry.
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
    Jan 2010
    Jacksonville, FL
    5,294
    64 Post(s)
    2461 Post(s)
    Thanks everyone. I'll try the tape method.
