Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Reload Thread: I need help.
    srobinson's Avatar
    srobinson is offline Junior Member
    Apr 2017
    Pomey Town, SC
    1 Post(s)
    I need help.
    Hey, good people. I have a question. So, I'm in the process of putting a Pyle PLMR18 aftermarket radio into my 2001 Pontiac Grand Am but hit a little snag. I need to remove the outer part of the faceplate in order to put the radio in a harness. This is the only problem I'm having right now. I've been trying on and off for about 2 hours without any luck. What is this part called and how do I take it off?
    ilikeradios's Avatar
    ilikeradios is offline Senior VIP Member
    Sep 2011
    Pigeon Forge, TN
    361
    1 Post(s)
    209 Post(s)
    Re: I need help.
    1) That $46 radio is going to sound worse than the factory radio you are replacing.
    2) just pull the trim ring off, it is just press fitted on there.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,234
    41 Post(s)
    6023 Post(s)
    Re: I need help.
    Quote Originally Posted by ilikeradios View Post
    Gonna add to your comment: The two tabs(in between red arrows), the 9'oclock position and 3'oclock position is whgat it looks like just gently snaps off or use a small flathead.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    srobinson's Avatar
    Apr 2017
    Pomey Town, SC
    1 Post(s)
    Re: I need help.
    Yup. Those tabs were the first thing I tried with a flathead. It still refuses to budge an inch.
    garychoffmann's Avatar
    garychoffmann is online now CarAudio.com Elite
    Mar 2011
    Missouri
    1,978
    6 Post(s)
    545 Post(s)
    Re: I need help.
    It's a marine radio so either the bezel is part of the housing or it is sealed on there so water can't get in.
    srobinson's Avatar
    Apr 2017
    Pomey Town, SC
    1 Post(s)
    Re: I need help.
    Well, that would explain why the manual doesn't explain how to take off the faceplate and outer trim ring.
    EDIT
    Ok. I managed to take it off! FINALLY!!!!
    srobinson's Avatar
    Apr 2017
    Pomey Town, SC
    1 Post(s)
    Re: I need help.
    One last question. How am I supposed to connect the red wire to this wiring harness? Why did it come not connected?
    EDIT
    Hmm... Ok. So, I noticed that the wiring adapter this GMRC-01 connects to also does not have the red wire. And I don't see any loose red wires in the console. So.... Does this mean I don't have to worry about it?
    Jul 2005
    WA
    14,234
    41 Post(s)
    6023 Post(s)
    Re: I need help.
    There should be a red wire already from the harness. From the looks of it, doesn't appear so. Why so many harnesses? You sure you have the correct one?
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  9. #9
    srobinson's Avatar
    Apr 2017
    Pomey Town, SC
    1 Post(s)
    Re: I need help.
    The two black wiring adapters came with the radio. The GMRC-01 adapter is the white one. When I looked into the dash I noticed that the wiring adapter doesn't have a red wire either.
  10. #10
    YukonXL04's Avatar
    YukonXL04 is online now Senior VIP Member
    Apr 2017
    Arlington,TX
    211
    95 Post(s)
    Re: I need help.
    You run the red wire to the fuse box for acc power. And it hooks to the acc of the radio
  11. #11
    Jul 2005
    WA
    14,234
    41 Post(s)
    6023 Post(s)
    Re: I need help.
    Take a pic of the opening of the radio in your car.
    Something isn't adding up. I thought that all radios/aftermarket harnesses just use 1 harness, not two.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  12. #12
    YukonXL04's Avatar
    Apr 2017
    Arlington,TX
    211
    95 Post(s)
    Re: I need help.
    Pretty much all of the normal brands do. But pyle, boss, lanzar.... I have seen plenty of theirs with 2 plugs. Basically 1 plug for power and ground. The other plug for speaker wires. Which if your running a 4ch then you could leave it unplugged and have 8 less wires behind the radio....
  13. #13
    srobinson's Avatar
    Apr 2017
    Pomey Town, SC
    1 Post(s)
    Re: I need help.
    Quote Originally Posted by YukonXL04 View Post
    Ok. Is that a difficult job or should I consider getting the GMRC-01 with a chimebox?
  14. #14
    YukonXL04's Avatar
    Apr 2017
    Arlington,TX
    211
    95 Post(s)
    Re: I need help.
    Quote Originally Posted by srobinson View Post
    That's entirely up to you. I prefer to delete all the chimes. Don't like them, don't want them...
    As far as difficult, just get a add a fuse thing from the auto store, and plug it into a fuse that has 12v key on only power and your good to go.
  15. #15
    srobinson's Avatar
    Apr 2017
    Pomey Town, SC
    1 Post(s)
    Re: I need help.
    I went ahead and ordered a new GMRC-01 wiring harness with red wire and chimebox because I don't want to goof anything up. I want the installation to be as simple as possible.
