Can you define comp/comps?
thanks
Thanks alot this will be a good reference since I am a newb with car audio lol
hey, guys, I just got dizzy, how can you@@@
This Audio Converter for Mac is an amazing music converter for all Mac users to convert files to popular audio formats like mp3, wma, wav, ogg, acc, etc. Also supports extract audio files from common movies like avi, mp4, mpg, mpeg, 3gp, mkv, mov, etc.
Furthermore, it can help you to change the audio settings, such as reset the channels, sample rates, audio bitrates, etc.
This Audio Converter Mac can be also used to trim audio files. If you like a piece of music in a movie, you can trim and save it. Here batch conversion supported!
How to convert audio files?
1. Free download this Audio Converter for Mac,install and run it on your computer. You will see a friendly interface.
2. Add audio files through “add file” button. Here batch conversion is supported. You can preview your added files in the preview window.
3. Select an output format in the profile combox. Merge different files into a single one by ticking before “merge into one file”.
4. Edit your audio files by open the “effect” window. You can trim the audio files.
5. Press the “start” button to begin the conversion. This only cost you a few seconds.
MediaVideoConverter HD Video Converter
MTS Converter Mac
MTS Converter
Mac QuickTime Converter
My new Touch Pro2 has a built-in rss reader, so Im thinking of downloading local news in Podcast and listening to the while commuting.
What is the best way to route the audio from my Touch Pro2 to my car audio?
I have a bluetooth handsfree from Jabra, so I can listen to the podcast from the FM radio through the FM transmitter function of the BT handsfree, but the sound is not really good.
Is there a better option?
Online forums ed hardy are another Ed Hardy Clothing way of Cheap Ed Hardy finding great Ed Hardy Sale 50’s prom Discount Ed Hardy dress online. Cheap Ed Hardy Clothing You can Ed Hardy Clothing Sale find the right dress Discount Ed Hardy Clothing for you Abercrombie and Fitch by joining Abercrombie & Fitch a forum that Abercrombie Fitch discusses fashion Abercrombie and dresses A&F or posting abercrombie fitch sale questions regarding Cheap Abercrombie Fitch 50’s fashion Discount Abercrombie Fitch or seek Abercrombie and Fitch sale advice in getting Cheap Abercrombie and Fitch 50’s prom Discount Abercrombie and Fitch dress. Testimonials Abercrombie sale and advice Cheap Abercrombie regarding reliable Discount Abercrombie and top-notched Abercrombie Fitch Clothing designers can also be given from the forums. Abercrombie and Fitch Clothing Also they can give you dress shops online where high Abercrombie Clothing quality dresses can be found.
Nice Thread, very clean, lots of content and loved having a look.Extremely loud sound systems in automobiles, which have been nicknamed boom cars, may violate the noise ordinance of some municipalities.
A stock car audio system refers to the OEM application that the vehicle's manufacturer specified to be installed when the car was built. A large after market industry exists where the consumer can at their desire replace many or all components of the stock system. In modern cars, the primary control device for an audio system is commonly referred to as a head unit, and is installed in the center of the dash panel between the driver and the passenger. In older vehicles that had audio components as an option, such devices were mounted externally to the top of or underneath the dash. Car speakers often use space-saving designs such as mounting a tweeter directly mounted over a woofer or using non-circular cone shapes. Subwoofers are a specific type of loudspeaker for low frequency reproduction. Extremely loud sound systems in automobiles, which have been nicknamed "boom cars", may violate the noise ordinance of some municipalities.
__________________________________________________ _____________
SEO Agency
SEO Newcastle
Car stereo - Car stereo installation San Francisco car stereo, car Audio installation, repair of Pioneer, Kenwood etc car stereo. - soundandalarm dot com
The slope is described in dB per octave. The higher the value, the sharper the roll-off, and the more control the listener will have over which frequencies are played by any particular speaker.
__________________________________________________ _______________________
Proofreading
SEO Copywriting
A unit that produces an artificial ambience pattern; one that is used to create the impression of the listener and/or performer being in a particular performance space.
Rebuilt engines for sale
Resonant Frequency – the frequency at which a woofer or subwoofer in a sealed enclosure resonates.
RMS – an abbreviation for Route Mean Square. RMS is the widely accepted metric of measuring and stating continuous power capabilities of audio power amplifiers as well as power handling capabilities of speakers and subwoofers.
* RMS power ratings of audio power amplifiers are typically stated at a specific impedance and at a certain level of distortion. Otherwise, they are meaningless. IE – 100 watts RMS per channel into a 4Ω load with less than 0.1% distortion.
* RMS power ratings of speakers and subwoofers are typically just given. IE – 250 watts RMS power handling.
Pay no attention to PEAK or MAX numbers, as they mean nothing.
Side Bias – side biasing is a result of sitting much nearer to one speaker than the other. The result is that the near speaker’s sound arrives to your ears sooner than that of the far speaker and the image is pulled to the near side. This is not desirable and can cause long term listening fatigue.
Subsonic Filter – a high pass filter with a very low crossover point. For example, a high pass filter at 30Hz would prevent musical information below 30Hz from reaching a subwoofer amplifier (and the connected subwoofer(s) ) connected to this filter. Subsonic filters are designed to prevent damage to subwoofers when used in vented or BandPass enclosures and connected to high power amplifiers.
Subwoofer – a speaker designed to reproduce the lowest frequencies of music, specifically the lowest two octaves*. Typically, this would be from 80 Hz to below the range of human hearing (lower than 20 Hz).
Tweeter – a speaker designed to reproduce frequencies between 5,000 Hz and 20,000 Hz . . . plus or minus a few . . .
Woofer - a speaker designed to reproduce frequencies from 20 Hz – 500 Hz (or even higher). Woofers are commonly used in home and pro audio speakers, where their frequency response has to extend all the way to the lower crossover point of the midrange (300 Hz – 500 Hz or so) in a three way system or to the crossover point of the tweeter (1,000 Hz or higher) in a two way system. car accessories
thanks for the butt load of terms lol...
Nice write up!!
2 12"JlAudio W0v2
JlAudio JX500x1
2 Ported enclosures
135.8dB
Bookmarks
