Results 1 to 5 of 5
Reload Thread: Need High Power Head Unit Suggestions
    nasakid's Avatar
    nasakid is offline Junior Member
    May 2004
    Houston Area
    I'm planning to power my factory speakers with the head unit and bypass the factory amp (Dodge Durango). My friend has recommended Alpine head units for this purpose. Any other brands I should consider with very clean high power outputs? Are Eclipse decks as good as Alpine?
    Thanks.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Re: Need High Power Head Unit Suggestions
    may i ask why?
    just get a small external amp and be done with it...
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,369
    paisonic has 60Wrms x 4. but you still need to hook up seperate power. my bottom of the line blaupunkt is 23Wrms x4 and it pumps out the bass.
    nasakid's Avatar
    May 2004
    Houston Area
    Less wiring to run behind panels for one. I'll just bypass the factory amp, cut the output wires, and splice to the input wires coming from the deck. Seems like a whole lot less work than running speaker wires and RCA's from and running power and remote to the amp.
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    true, but you're only talking about maybe 10-15 watts RMS, those numbers usually quoted on head units are optimistic peak numbers, if that.
    and a lot of those so called "high power" head units need an external power wire run to them anyway...so it isn't that much of a step from there to installing a small amp.
  1. can a stock head unit work well??
    By yayopwr in forum General Discussion
    Last Post: 06-02-2004, 12:57 AM
  2. head unit and speakers for 500$
    By esco in forum General Discussion
    Last Post: 05-24-2004, 01:05 AM
  3. Eclipse head unit
    By TwistedVisions in forum General Discussion
    Last Post: 05-23-2004, 01:14 AM
  4. head unit help!!!
    By pr1dragon88 in forum Wiring, Electrical and Installation Help
    Last Post: 01-27-2004, 05:02 PM
  5. Nissan Maxima head unit installation with bose system!
    By EaC95z28 in forum Wiring, Electrical and Installation Help
    Last Post: 12-19-2003, 02:31 AM
