Results 1 to 4 of 4
Reload Thread: Quick Wattage Question.
    bushtree's Avatar
    bushtree is offline CarAudio.com Elite
    Sep 2003
    San Diego
    547
    Hello everyone,
    I have a quick question.
    Now i know that its kinda a nice rule of thumb to use 4awg wire up to 1000watts and higher than that use 0/1awg wire.
    I have a Hifonics NX880 amplifier right now. Now it is an 880Watt amplifer hence it being called the NX880. However that 880 watt rating is at 20hms load (220x4 @2ohms). I run my speakers at 4ohms. so the rating is 110x4 @4ohms.
    How should this amp be counted at 880watts worth of power or 440 watts?
    I plan on adding in another amplifier very soon so i was wondering about this.
    Also. You can find out your amp draw with this formula. (I know its not exact). Total Watts / Current Voltage.
    So if i were to put my amp into that formula would i say the watts is 880 or 440?
    Thanks.
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    Re: Quick Wattage Question.
    It would be 440 in your case. 8 ga would be more than enough, but since you already know you're going to be adding a 2nd amp you ought to pick up one of the 4 ga amp kits at wal-mart. Cheap and effective.
    bushtree's Avatar
    Sep 2003
    San Diego
    547
    Yea, I actully already have this amp installed. And installed it with a 4awg amp kit. I am going to be adding a 2nd amp though within the next week. That is why i was asking.
    Should i just keep this 4awg wire running it into a fused distro, then run 8awg to each amp?
    Or should i upgrade to 0/1awg wire to the distro then 4awg to the amps?
    Thanks.
    n2audio's Avatar
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    I'd go 4 to 8. Bigger won't hurt anything, but it's not going to help your system any. It would just allow for a hell of an upgrade if you ever decide to.
  1. Quick question bout the kicker S15L74 sub...
    By Jeepaudio in forum Subwoofers
    Last Post: 03-13-2004, 09:39 PM
  2. quick question about 801s
    By Jameseypoo in forum Amplifiers
    Last Post: 02-12-2004, 05:56 PM
  3. Quick Porting Question
    By ryanb9 in forum Enclosure Design & Construction Help
    Last Post: 01-30-2004, 03:45 PM
  4. Quick little question, Yes or NO?
    By Forty-Ouncer in forum Amplifiers
    Last Post: 01-30-2004, 11:03 AM
  5. Sub-Amp Wattage question?
    By Jetta95 in forum Subwoofers
    Last Post: 12-29-2003, 08:23 PM
