Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 58
Reload Thread: So bigger amp?
  1. #31
    Jerm1400's Avatar
    Jerm1400 is offline Senior VIP Member
    May 2014
    Orlando, FL
    162
    66 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by winkychevelle View Post
    Most of these guys tunning high wattage dont use there amps total power for long. Yea a short demo is fine but a 2hour trip cross state and you have cooked coils. If I where to use sundown I would run a saz1500d which makes right at 2k of power. The 2.5inch voice coil can only handle so much . And the sa8s mentioned above are completely different motor designs that allow for alot more forced cooling
    Not to thread jack but how much do you think the American bass Tnt 12's can handle daily?
  2. #32
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,419
    141 Post(s)
    1 Thread(s)
    6007 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by Jerm1400 View Post
    1000 rms
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  3. #33
    Jerm1400's Avatar
    May 2014
    Orlando, FL
    162
    66 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by mylows10 View Post
    1000 rms
    So would you say the Sa & tnt are on the same level or nah?
  4. #34
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,419
    141 Post(s)
    1 Thread(s)
    6007 Post(s)
    Re: So bigger amp?
    Yea pretty close
  5. #35
    garychoffmann's Avatar
    garychoffmann is online now CarAudio.com Elite
    Mar 2011
    Missouri
    1,905
    6 Post(s)
    507 Post(s)
    Re: So bigger amp?
    Well I know a guy named Denus that ran 6 sa 12's with 1100-1200 rms to each. I would run a saz 2500 but idk if that's in your price range. I plan on running two American bass tnt 12's in a 4th order blow through on about 800 watts each in a Buick Century
    I don't care about your friend and his penus. Just wrap those pubes tightly around your hands and hug away.
    But please, tell me all about your penus' s system. So he has 6 12's, wired down to what load? What amp is he running? What's his electrical? Now since you have to keep butting in while I'm trying to help somebody get the most out of their system.... I need to hear all about your tnt 12's and your big plans. And please tell me how you are going to insure they see 800 watts. Better make that 4th order smaller so it can handle the wattage....
    And please tell me how any of this is helping the op with his original question. The amp he has is known for doing close to rated. He needs to get as much of that out of it as possible. Right now he is at 62% of rated which is odd for that amp. I also have a pac plug and play output on my stock head unit. It took me a while to get it gained in correctly so that my amp would function at its best. Op, does your pac unit have a gain or any adjustments? If the signal coming off the pac is really weak then the amp has a harder time amplifying that signal. May be why you are getting dirty so quickly. have you scoped your rca's and checked the voltage on them?
  6. #36
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,103
    217 Post(s)
    7260 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by Pyrofan View Post
    Ground behind the seat. Tested it and it check out. Been I awhile since I tested it the voltage drop but it wasn't much. My truck has a big alternator already and the previous owner got a big battery put in. The signal is the Stock HU Bluetooth'ed to a tablet.
    There's your culprit. That mb quart should be doing close to rated rms. You cant get too much output if the source is weak and cannot put a strong enough clean signal to the amp. Most stock head units are close to trash when it comes to producing a clean and strong signal even with an LOC. The only thing to remedy that is a Digital Sound Processor if you really want to keep the stock look. Otherwise, get better aftermarket head unit.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  7. #37
    Pyrofan's Avatar
    Pyrofan is offline CarAudio.com Elite
    Aug 2013
    Ga
    608
    233 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by garychoffmann View Post
    No, my pac unit just has RCA out. The signal was clean but don't remember the voltage. To check that I would assume I just play a 1000hz tone and DMM the leads?
    Quote Originally Posted by jeffdachef View Post
    Well the tabet isn't always synced to the car. I use my phone sometimes but I know that's not the point. Im trying to avoid a new HU. Not familiar with sound processors. Is that like a Bit ten?
  8. #38
    Jerm1400's Avatar
    May 2014
    Orlando, FL
    162
    66 Post(s)
    Re: So bigger amp?
    lol really dude? Are you done being a ****? Did that boost your lil ego more lol. I already said I didn't mean to thread jack so how about u jump off the sack & not wrry about me okay? Have a blessed day & to answer your question three saz 2500's wired to 1 ohm each with two 4 ohm dvc sa 12's & six or 8 xs power d 3100's all O gauge wire with a high alt not sure how many amps tho & if I'm not mistaking subs in a sealed boxes are generally able to handle a little more power. I thought that would apply the same for a smaller box if I'm mistaken then enlighten me don't be a lil ***** about it!
  9. #39
    Pyrofan's Avatar
    Aug 2013
    Ga
    608
    233 Post(s)
    Re: So bigger amp?
    I believe he was being sarcastic about the specs of the car.
  10. #40
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,598
    15
    35 Post(s)
    3803 Post(s)
    Re: So bigger amp?
    You know very little about power handling and I'd encourage you to not be throwing around advice telling people to overpower things.
    People who overpower things don't ask because they know what they are doing and/or don't care of they break things, or they don't know what they're doing and break things. Don't go around telling people to run a product beyond it's design limits unless you are the seller or manufacturer and are willing to replace or repair it when it breaks.
  11. Likes Jerm1400 liked this post
  12. #41
    Jerm1400's Avatar
    May 2014
    Orlando, FL
    162
    66 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by hispls View Post
    Well I'm sorry but forgot about box rise but thanks for the input
  13. #42
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,424
    769 Post(s)
    Re: So bigger amp?
    About a 1000w if you dont play too far under tuning or they are in a sealed box
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam, will add
    A kingpin camera and a trailer rear cam soon
    Memphis viv component run active
    Kicker cx1200.1
    Kicker cx 300.4
    2 jl 13tw5-3 wired to 1.5ohm at about 1000rms
    ****** box that needs to be replaced soon
  14. Likes Jerm1400 liked this post
  15. #43
    dragon.breath's Avatar
    dragon.breath is offline Senior VIP Member
    Nov 2007
    new hope al
    433
    96 Post(s)
    Re: So bigger amp?
    Wait, you are using a 1000 hz tone? Theirs your problem. You need a 50 hz or 60 hz tone to set subwoofer gains.
    digital designs 9512h with cf cap
    sundown saz 3000d at 2 ohms
    meca legal 141.3 db on the headrest with a 34hz tuned daily box
  16. #44
    Pyrofan's Avatar
    Aug 2013
    Ga
    608
    233 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by dragon.breath View Post
    ....1000 for HU
  17. #45
    Freeman's Avatar
    Freeman is offline I TrY
    May 2013
    Watertown, SD
    834
    310 Post(s)
    Re: So bigger amp?
    Like I said it depends on your setup say for instance like putting subs in a smaller box so they can handle more power or etc.....
    are you ******* retarded?
    1986 Nissan hardbody
    Hu:Kenwood Kmm-100u
    front:1 Cheep Kenwood speaker.
    Rear:the 3in of room behind my seat where my amp sits
    Sub:soon
    Amp:polk pa330
    Wiring:1/0 knu kca to 4gauge distribution block and 1/0 kca big 3
  1. so many amps but which one?
    By liqdsm in forum Amplifiers
    Last Post: 12-24-2003, 04:22 PM
  2. so many amps, so little money
    By eviltuna7 in forum Speakers
    Last Post: 12-11-2003, 12:13 AM
  3. I need a bigger amp
    By Nickfireblazer in forum General Discussion
    Last Post: 06-23-2003, 10:59 AM
  4. Replies: 6
    Last Post: 04-13-2002, 01:40 PM
  5. Replies: 5
    Last Post: 03-02-2002, 06:46 AM
