Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 58
Reload Thread: So bigger amp?
  1. #16
    garychoffmann's Avatar
    garychoffmann is online now CarAudio.com Elite
    Mar 2011
    Missouri
    1,921
    6 Post(s)
    514 Post(s)
    Re: So bigger amp?
    So your loc'd out? I would start there. On your wave was it fuzzy or was it cutting the peak off?
  2. #17
    Pyrofan's Avatar
    Pyrofan is offline CarAudio.com Elite
    Aug 2013
    Ga
    608
    233 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by garychoffmann View Post
    Loc out? What do you mean? I got a nice clean sine wave. Turn the gain till it distort then backed off till it cleaned up
  3. #18
    Mar 2011
    Missouri
    1,921
    6 Post(s)
    514 Post(s)
    Re: So bigger amp?
    What are you running the rca's from? I assumed a line out converter hooked up to the factory head unit. Or are you running rca's from the tablet into your amp? What I'm getting at is if the amp is not receiving a good signal as it starts to amplify that signal it gets dirty quick.
  4. #19
    Pyrofan's Avatar
    Aug 2013
    Ga
    608
    233 Post(s)
    Re: So bigger amp?
    Pac unit. The rca cables gave a clean signal. They are near no power wires. They are shielded too. Signal seems clean all around. I think the amp is just inefficient and need to be replaced.
  5. #20
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,431
    769 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by Jerm1400 View Post
    Just seen your'e running two sa 12's then yeah I would get a bigger amp some where between 2000-3000 watts. Those sa 12's can handle some power.
    ummmm no the sundown sa 10 12 and 15 are thermally limited to 1000w each after that the coil starts to melt. on music you could get away with a bit more but with dubstep or tones you would ruin the sub quick.
    my guess is he has two d2 subs wired to 2 ohm reason for low out put on amp either that or he doesnt realize a soft clip doesnt hurt the subs.
    or that the loc is limiting the clean signal
    if the subs arent moving they either arent broke in or they are in the wrong enclosure. ive dealt with alot of sundown subs and it doesnt take much to get them moving.
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam, will add
    A kingpin camera and a trailer rear cam soon
    Memphis viv component run active
    Kicker cx1200.1
    Kicker cx 300.4
    2 jl 13tw5-3 wired to 1.5ohm at about 1000rms
    ****** box that needs to be replaced soon
  6. #21
    Pyrofan's Avatar
    Aug 2013
    Ga
    608
    233 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by winkychevelle View Post
    You mean 1000 watts. They are DVC 4 wired down to one. The subs move. Just not at their full XMAX. Dont get me wrong the truck bumps now but i think it can get louder. Enclosure should be good.
  7. #22
    Jerm1400's Avatar
    Jerm1400 is offline Senior VIP Member
    May 2014
    Orlando, FL
    162
    66 Post(s)
    Re: So bigger amp?
    I've seen videos of people running a pair of sa 8's on 2500 watts plus. It can be done it just depends on your setup
  8. #23
    Mar 2011
    Missouri
    1,921
    6 Post(s)
    514 Post(s)
    Re: So bigger amp?
    running of a 2500-3000 watt amp and taking 1250 to 1500 a piece are 2 completely different things.
  9. #24
    Jerm1400's Avatar
    May 2014
    Orlando, FL
    162
    66 Post(s)
    Re: So bigger amp?
    Like I said it depends on your setup say for instance like putting subs in a smaller box so they can handle more power or etc.....
  10. Dislikes Freeman, hispls disliked this post
  11. #25
    Pyrofan's Avatar
    Aug 2013
    Ga
    608
    233 Post(s)
    Re: So bigger amp?
    What do you recommend. They can take 1k each cant they?
    Whats you're opinion then?
    Well the box is already on the small side for two SA-12s ( that's what I was told). I think a PH 4000 may do the trick. Does about 2k at 1 ohm.
  12. #26
    Jerm1400's Avatar
    May 2014
    Orlando, FL
    162
    66 Post(s)
    Re: So bigger amp?
    Quote Originally Posted by Pyrofan View Post
    Yea there's a guy I know named Denis he had six sa 12's feeding them 1200 watts each daily no prob so yea go for it just set your gains right.
    Yes
  13. #27
    Mar 2011
    Missouri
    1,921
    6 Post(s)
    514 Post(s)
    Re: So bigger amp?
    Small boxes don't increase power handling. Your box is actually maxed out by sundowns specs. 2 cubes per is max recommended. So your box should be pretty efficient. I would possibly check out another amp in your truck and see if your wave is getting sloppy prematurely. It could possibly be the amp. The ph4000 is a decent amp. Personally if I was going to get another amp I would look for a constant power amplifier. That american bass amp is rated at 150 amp fusing the quart 140. So not much of a jump.
  14. #28
    Jun 2009
    Ponchatoula, La
    26
    3,431
    769 Post(s)
    Re: So bigger amp?
    The american bass ph4000md makes 1880ish watts at 1ohm I would recommend the vfl hybrid 4480
    Kicker cx1200.1
    Kicker cx 300.4
  15. #29
    Jerm1400's Avatar
    May 2014
    Orlando, FL
    162
    66 Post(s)
    Re: So bigger amp?
    Well I know a guy named Denus that ran 6 sa 12's with 1100-1200 rms to each. I would run a saz 2500 but idk if that's in your price range. I plan on running two American bass tnt 12's in a 4th order blow through on about 800 watts each in a Buick Century
  16. #30
    Jun 2009
    Ponchatoula, La
    26
    3,431
    769 Post(s)
    Re: So bigger amp?
    Most of these guys tunning high wattage dont use there amps total power for long. Yea a short demo is fine but a 2hour trip cross state and you have cooked coils. If I where to use sundown I would run a saz1500d which makes right at 2k of power. The 2.5inch voice coil can only handle so much . And the sa8s mentioned above are completely different motor designs that allow for alot more forced cooling
    Kicker cx1200.1
    Kicker cx 300.4
  17. Likes Jerm1400 liked this post
  1. so many amps but which one?
    By liqdsm in forum Amplifiers
    Last Post: 12-24-2003, 04:22 PM
  2. so many amps, so little money
    By eviltuna7 in forum Speakers
    Last Post: 12-11-2003, 12:13 AM
  3. I need a bigger amp
    By Nickfireblazer in forum General Discussion
    Last Post: 06-23-2003, 10:59 AM
  4. Replies: 6
    Last Post: 04-13-2002, 01:40 PM
  5. Replies: 5
    Last Post: 03-02-2002, 06:46 AM
