Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 48
Reload Thread: home insulation in doors?
  1. #16
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,789
    232 Post(s)
    7683 Post(s)
    Re: home insulation in doors?
    Quote Originally Posted by CandeShop View Post
    Home insulation is going to mold. It's impossible to seal the door. The rubber trim that is on the door edge is designed to let water roll down the window and into the door. That's why there are drainage holes at the bottom of every door. Also why there is a moisture barrier (plastic held with butyl rubber adhesive) on the inner door skin.
    thats why in the guides, it tells you to wrap and seal it with 1 mill painters cloth to shield it from moisture and double up with aluminium tape on weak spots. Done right, there will be no moisture or mold.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  2. #17
    CandeShop's Avatar
    CandeShop is offline Senior VIP Member
    Jun 2013
    East Orlando, FL
    192
    99 Post(s)
    Quote Originally Posted by jeffdachef View Post
    Then there's no dampening going on. Your sound waves are bouncing off of plastic sheets causing the plastic to resonate. Just never found home fiberglass insulation to be useful in a car, especially when they have rubber pads designed for that specific use.
  3. #18
    CandeShop's Avatar
    Jun 2013
    East Orlando, FL
    192
    99 Post(s)
    Dbl post fail
  4. #19
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,489
    804 Post(s)
    Dbl post fail
    well if you use mineral wool it wont mold or you can use ceramic based fiberglass that also doesnt mold.
    in my car adding the insulation makes a tremendous diffence for anything above 100hz.
    i dont have my insulation wrapped though and my doors dont allow much water in at all.
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam
    Memphis viv component run active
    2 alpine pdr-m65
    1 alpine pdr-f50
    2 jl 13tw5-3 in subthump understeat box
  5. #20
    Lockdown801's Avatar
    Lockdown801 is offline Junior Member
    May 2014
    New York
    3 Post(s)
    Wouldn't insolite/closed cel foam have the same effect?
  6. #21
    Jun 2009
    Ponchatoula, La
    26
    3,489
    804 Post(s)
    Quote Originally Posted by Lockdown801 View Post
    Wouldn't have the same effect?
    no as it would just block the rear waves from exiting the car door and send them reflecting back to the rear of the speaker cone possibly making matters worse. open cell foam would work but it grows mold over time since it holds water.
    the idea here is sound absorption not deflection. insolite/closed cell foam makes a good barrier though to keep the rear wave that do reflect back from going through the door card when applied behind the door panel
    2 alpine pdr-m65
    1 alpine pdr-f50
  7. #22
    Jeffdachef's Avatar
    Feb 2013
    15,789
    232 Post(s)
    7683 Post(s)
    rubber and foam have horrendously weak absorption properties from my experiences with them. With the insulation wrapped in plastic, when its only 1 mill thin, its not bouncing off anything, the insulation still does a waay better job waay job of absorbing the rear wave then any foam or rubber crap they mass marketed. Dont knock it unless you've tried it.
    if you want to go into more detail @keep_hope_alive ; can elaborate more.
  8. Thanks keep_hope_alive thanked for this post
  9. #23
    May 2014
    New York
    3 Post(s)
    Ah I got my closed and open cell mixed up. They sure try to market overkill like it absorbs them.
  10. #24
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,584
    42 Post(s)
    1423 Post(s)
    Closed cell foam is meant to be used between vibrating panels. It puts pressure on the opposing panels and prevents them from rubbing against each other. Its not meant to stop sound waves from entering into the cabin or the audio from being heard outside the car. Thats what mass loaded vinyl is for.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  11. #25
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    Try it and see for yourself. The materials are so cheap it's down to your time to acquire them and put the bagged insulation into a vehicle. Surely you're open to a better way to get a vehicle sounding good.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  12. #26
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    I still use sound damping products on the metal, and I still seal the doors up. I use CCF to isolate the door from the panel to prevent rattles, and I even use CCF on each clip so the clips don't rattle in their holder. But you NEED sound absorption inside the door cavity or you have a resonant chamber for the speaker, and sound from the rear of the speaker bounces around inside the door them comes back out through the speaker cone later - presenting phase interference that gets worse the louder you play. speaker cones can push air but cannot block sound well at all. the best speaker enclosures prevent the rear wave from ever coming back to the cone by controlling reflections and providing a lot of absorption. a car is no different in the need, we just haven't seen the application.
    sound transmission is based on the thickness, mass, and material properties of the material relative to the wavelength of sound. 1 mil plastic easily lets midrange and midbass pass through, and though it will reflect high frequencies we don't care about that inside a door. the plastic is just there for water protection. I cover the entire rear door skin and get as much as possible in the door - you cannot have too much because the door is such a large volume compared to the speaker.
    using them in vehicles I have gotten lower midbass response, smoother midrange response, and overall better imaging and a more defined sound stage - all compared before vs. after. the reasons for the improvement are because that much fiberglass will absorb rear midbass which would otherwise cancel out, and better imaging is from getting a single source and not a reverberant source.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  13. #27
    CandeShop's Avatar
    Jun 2013
    East Orlando, FL
    192
    99 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    the reasons for the improvement are because that much fiberglass will absorb rear midbass which would otherwise cancel out.
    Wrong, the reason why you hear any difference is because you have now shrunk the volume of the "enclosure" the driver is playing in.
    In doing house remodels, I've done tests of walls with insulation and without. The difference is minimal as to how much sound can be reverberated to the other side. It's done in the ceilings of houses to avoid heat/cold transfer thus allowing your home to stay at the desired temperature more easily.
    Using home insulation is no different than using poly fill, except for the fact that one can cause itchiness, molds easily and over time deteriorates with various temperature changes, age and weather. The other loses no volume due to deterioration and has no properties that'll cause histamine reactions nor does it mold. Tbh the home insulation idea is just about the same as people presenting peel and seal as a sound deadener.
  14. #28
    Jun 2009
    Ponchatoula, La
    26
    3,489
    804 Post(s)
    One where is your data for your statement Keephopealive has data in has thread supporting his statements
    Two making the enclosure volume smaller would raise the fc of the box and not allow the mids to play as low.
    three making the box smaller also wouldnt smooth the response but rather raise the peak frequencies to a high point in the octaves.
    Four the mold issue is taken care of by uusig the 1mil drop cloth
    Five the frequency band of which the sound wave bounce off of the 1 mil drop cloth is much higher than the 3.5khz lowpass used on midrange drivers
    Six fiberglass works better because the micro fine fractures and slivers that cause itching increase the surface area higher than the same amount of polyfill due to polyfill have a smooth surface.
    2 alpine pdr-m65
    1 alpine pdr-f50
  15. #29
    CandeShop's Avatar
    Jun 2013
    East Orlando, FL
    192
    99 Post(s)
    Quote Originally Posted by winkychevelle View Post
    Uh huh yea ok! I'm not gonna get into a big bickering war.. Go check out an sq comp and ask all the competitors what they're using in their doors and kicks, then report back with your data.
  16. #30
    Jun 2009
    Ponchatoula, La
    26
    3,489
    804 Post(s)
    Ok man ill do that but wait ive already done that and yea maybe you should actually try it before you dismiss it because by what ever way it affects the speaker I can say it works. And you are quick to shur me up because why? You have no proof at all you are just speaking out of your *** because you are a shop.
    really I dont care if you agree with me imma use this method because I know it works.
    2 alpine pdr-m65
    1 alpine pdr-f50
  1. Polyfill in Doors for Midbass Drivers?
    By nrgy in forum General Discussion
    Last Post: 03-04-2003, 10:52 PM
  2. Home amp in car?
    By TRANSAMCHARGER in forum General Discussion
    Last Post: 02-10-2003, 07:48 PM
  3. Speakers in doors- Answer fast please!
    By DjNickCastoro in forum Wiring, Electrical and Installation Help
    Last Post: 02-04-2003, 03:48 PM
  4. Woofer or Coaxial in Door?
    Last Post: 11-26-2002, 08:58 PM
  5. 8" speakers in door
    By SAVAGE SOUND in forum Wiring, Electrical and Installation Help
    Last Post: 08-06-2002, 01:06 PM
